Originally Posted by camion
Hi guys. I know this is kind of an old thread but I'm having the same issue. Fuse blows right away. I took out the driver side sun visor and it still blew. That was the only spare fuse I had. I subsequently took the passenger side visor and tested both on the bench by supplying power and they both function properly. The light comes on when I slide the cover. Wiring looks intact.
I ordered a 25-pack of 10A fuses that arrives tomorrow so I can do more testing.
Could it be the running board lights? I can test by disconnecting them.
Any other common cause for this?
The common cause is a short in the circuit.. Also, just because you pulled the visors off and tested that the work on a bench doesn't necessarily mean there isn't a short when the visor is in the closed position. However, with the amount of wire paths there are in this circuit I would start looking elsewhere.
Just as a note of advise, don't do what was suggested 2 posts up and install a larger fuse. lol
