04-30-2011, 02:19 PM
Cargo Power Port Part Number needed
Does any body have the part number for the cargo area power port /power outlet (aka cigarette lighter plug)? I can't seem to find it in my part number book. Specifically, I need to replace the cover assembly which has broken off. I'd also like the number for the port itself because I may stick another one in someplace else.
Thanks.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods: Spoiler, HIR bulbs, Kenwood DNX6960 Nav, Back Window Up with Remote Mod, Rear Camera, LED Tails, Key Reminder Disable, OEM Automatic Headlights, Rear USB Ports, Seat Heaters, Aftermarket Third Row, Heated Side View Mirror
Locations: VA
04-30-2011, 08:39 PM
It may be easier and cheaper if you just replaced it with an aftermarket. I've used these, and they are very nice. It can be mounted with or without the square faceplate.
12v Flush Mount Receptacles & Plugs Single
John
'03 Limited 4.7 4WD - Overland 2.5
Camburg Uniball Uppers - 285-70/17 Toyo Open Country AT II
http://www.toyota-4runner.org/galler...er-thread.html
04-30-2011, 10:08 PM
I've seen that one before but I generally like to keep everything looking OEM. The other thing that I don't like about that one is that it doesn't have a real hinge like the factory one. I'm not sure how much the cargo power port cover is but the hinged power port cover in the center console was only $6.50 (which, admittedly, was shocking).
Locations: VA
05-01-2011, 10:40 PM
Found a dealer with diagrams online
Just to close out this thread. Here are the part numbers.
Cover, Power Outlet 85535-35080C0 approx. $6.50
Socket Assy, Power O 85530-42010 approx. $28
Locations: VA
03-27-2012, 08:33 AM
I know this thread is old, any steps on how you replaced the rear cargo "cig lighter" outlet? Thanks
FJ Shocks & Springs -- AFE Filter -- LED Interior including Gauge Cluster -- Removed mud flaps & running boards -- 265/70/17 Hankook DynaPro AT's -- 5th Gen Trail Edition Wheels --
03-27-2012, 11:45 AM
I'd suggest checking out the west marine 12v plugs. Nice retro and extra power
Mojav
cheers, Mojav
2008 T4R SR5 Silver V6 90k miles. SharpHID for driving and fog, some LEDs, Stubbs sliders. Project work on Rear Window Remote hack. Added Pioneer x4500 double din, Thule box and rhino half rack, Firestone airlift, Siri usXM, FN Wheels TR like, 1/4” rcimetalworks skids, and 2nd set of Bridgestone Revo3s —Gettin' ready for the Spring DVNP, Southern Utah and Mojave Desert.
