05-08-2011, 10:27 AM
#16
jag00035,
I have the 2006+ projectors because it came w/ the vehicle, but if I didn't have it, I wouldn't bother getting them.
Because they are expensive, the projection isnt that great & the beam pattern isn't sharp.
I would do a retrofit. I've done a TSX projector retrofit on a Lexus SC300 before.
And I'm sure you want them to look OEM like nothing was done to it...I'm the exact way!!
I included some links for you to check out...
[pictures]...TSX Retrofit On Lexus SC300
[pictures]...TSX Retrofit On Lexus SC300 - Toyota 4Runner Forum
...there's also pictures of HID Kit, TSX, S2K & LS430 projectors on 4Runners.
. -Kenny- (formerly icantsee) .
• **SOLD** 2007 Toyota 4Runner V6 SR5 4WD - Titanium Metallic
Daystar Spacer Lift 2.5/1.5 (Preload/Topout)|P265/70R17 Bridgestone Dueler A/T Revos|XenonDepot H11 4300k Xtreme HID Kit|Weathertech Floor & Cargo Liners|Rear Axle Diff Breather Extension|Color Matching Grill|Debadged Emblems|FatCat6|Soon/Wishlist|CB Radio|BL 1"|Demello Bolt On Sliders|Icons or Radflo|BajaRack or Rola Rack
#17
05-08-2011, 10:50 AM
#18
Thanks for the advice, K.C.
Unfortunately, I don't have the know-how or skills to retro-fit the projectors into my headlights. My plan was to get the 06 headlights and then get an HID kit so it wouldnt have the glare the 05 headlights would with the same HID kit. Does that make sense? And is there any way to cut down glare from the HID's on the 05 headlights?
05-08-2011, 11:02 AM
#19
Putting an HID Kit into 2003-2005 & 2006-2009 headlights both give you glare.
For both, you need to lower the headlights.
For the 2006-2009, not only do you lower the headlights, you have to do the Squirrel Eliminator Mod.
#20
And since you have Halogen Projectors & NOT HID Projectors,
you'll end up having a Squirrel Finder.
Not a problem if you have Halogens, but a problem if you have an HID Kit.
Squirrel Finder
Squirrel Finder is the little box above the cutoff line when you turn on the headlight.
The Squirrel Finders will produce glare to oncoming traffic specially if you put HID kit in the 06+ projector style housing.
On-coming cars will flash you, because they think you have your high beams on.
* Pictures & Descriptions were a courtesy by lawwailok *
05-08-2011, 11:03 AM
#21
HID project write up detail (pics) - Squirrel Finder Eliminator
via lawwailok
05-08-2011, 11:08 AM
#22
How To Aim The Headlights On An 2007?
How to aim the headlights on an '07?
05-08-2011, 12:58 PM
#23
Originally Posted by gaterose
Yeah there is a ton of info if you search around, basically the coils just improvement the ride & handling. You'll find more info if you search for coils vs spacers or something like that.
btw 03_4x4 I clicked the link, there was actually no info there!
not sure what keywords you searched but I guess the searchid's only last so long or are only accessible to the users who enter the search.
I did not realize it would only last so long or only work for the original search person. I was just trying to get people to use the search feature more.
