Old 05-17-2011, 11:59 AM #1
Ducman's Avatar
Ducman Ducman is offline
Ducman is on a distinguished road
Ducman's Avatar
Thumbs up Just did rear brakes and they were easy
I replaced the rear pads and rotors this past weekend at 78,000 miles.
I went with Napa Ultra Premium Rotors and Toyota OEM pads just like I had used up front last year.
The faces of the rotors I removed were not in too bad of shape although the rotors themselves were pretty crusty rusty. The pads were down to around 30% or so.
Anyway, they were easier to do than the fronts. The rotors pulled off easily, I did not have to mess with the dreaded 'star wheel' adjuster for the ebrake drums. No pins to drive out like on the fronts either.
Also, for $6 I decided to replace the slide pins in the front brakes again while I was at it. After just 1 winter they were rusted in place and had to be driven out with a hammer.
Although the fronts do most of the work, there was a VERY noticeable improvement in braking performance after I was done doing the rears. My wife even commented on how much better the truck stopped.
Rotors were $120 for the pair and pads and backing plates were $60.
I'll post up pictures and a quick run through in the maintenance section in the next day or two but it was EASY. I decided to rotate all 5 tires and that probably took me nearly as long as the actual brake job itself.
And....somehow I've lucked out I guess no frozen calipers... yet.
05 SR5 V8 4WD | Cracked Exhaust Manifolds| Magnaflow Catback | Bilstein 5100s | Kenwood DNX5120 Nav | Rear DVD | OEM 06+ LED Tails | Heated Leather | A/T Revos
Ducman is offline   Reply With QuoteReply With Quote
Old 07-10-2011, 07:26 AM #2
jstutz101 jstutz101 is offline
jstutz101 is on a distinguished road
Almost easy....
I had the same experience you did with the rotors and pad removal. Rotors fell off on there own when I removed the calipers. For some reason I had a heck of a time put the new pads in. I installed duralast gold pads from autozone, not sure if that makes a diffrence?? I was happy the rear calipers werent frozen, i've been down that road with the fronts.
jstutz101 is offline   Reply With QuoteReply With Quote
brake , brakes , pads , rotor
Rear brakes DIVNWND 3rd gen T4Rs 10 07-05-2017 08:04 PM
DIY HELP: rear brakes mole177 Maintenance/Detailing 9 07-18-2010 08:12 AM
Don't be fooled! Front lift spacers, diff drop kit, rear coils no easy task!!! Slippery24 3rd gen T4Rs 25 11-03-2009 11:47 PM
New rear brakes steved 4th Gen T4Rs 8 06-23-2007 11:30 AM
rear brakes hulk311 4th Gen T4Rs 0 05-28-2007 10:07 PM
