05-19-2011, 07:49 AM
Climate Control Issue After Kenwood DDX418 Install
I had Best Buy install a double din unit last night, DDX418, and i got it in on the way to work this morning to use the climate control and it is not working properly. Everything from one click above low is full blown heat and Lo is full blown cold. Any ideas what could have been done for this to happen or how to fix it? If i cant do it ill end up taking it to Best Buy but figured i would try to fix it myself first. Thanks for any help.
2007 Salsa Red 4Runner Sport Edition 4WD. Icon Stage 1 Lift. Good Year Wrangler Dura Tracs 285/70/R17. Interior LED Swap. Demello Bumper. ACRO Yellow Fogs. HID Head Light. Pro Comp LED light bar. 12,500lb winch. Rock Sliders. CB Radio and PA. TRD Cold Air Intake. Kenwood DDX470 Headunit. White Front and Rear Turn Signals and LED corner markers
05-19-2011, 09:23 AM
Check your tailpipe for dirt (inside joke).
2000 4Runner SR5 4x4,Volant CAI,5.29 gears, ARB lockers frt & rr, ARB Bumper w/ IPF lts, Warn M8000
All-Pro sliders, Skid Row Offroad Skids, ToyTec Ultimate Lift,2" BL, BFG KM2 315-75-16s,Cobra 75WXST CB
Headrest DVD x2 w/ XBox 360, 800W inverter,4x55W lts frt,2x55W lts rr on rack, Dual Optima Yellow Tops, VIAIR on-board air
05-19-2011, 09:53 AM
LOL, from this point on that is step one no matter what the symptoms are!
Let me know when you can send those pictures. I'm going to put them in the album on here. Thanks Jason.
05-19-2011, 01:32 PM
Anyone?
Nobody? No one has experienced this?
05-19-2011, 01:53 PM
HMMMM. first mistake was going to best buy. ahaha jk.
i havnt seen or heard of it. but maybe unplug the CC and plug it back in? reset it kinda thing? i did mine with the key on acc to reset it when it wouldnt turn my defroster on, and worked. sooo maybe?
2004 4Runner SR5 V6 2wd
My Build/Mod/Repair Thread
My Beauty Shots
05-19-2011, 02:15 PM
Check your Yahoo email. I sent a link the other day. Let me know if you didn't get it.
Jason
05-19-2011, 02:31 PM
Prob just didn't plug a wire back in after taking off the dash!
2006 4runner sport 4x4 V6- Shadow Mica, charcoal leather, 265/70R17 BF Goodrich Rugged Terrain T/A, Daystar 2.5 /1.5, ....
Past Toyota family, 93' Pickup 22RE, 99' Tacoma 3" lift 33x12.5 MTR's much more, 97' 4runner LTD w/ OME lift 285/75/16 Baja MTZ's
05-19-2011, 03:14 PM
I wouldn't waste any time trying to figure it out...unless the Best Buy is far away...take it back and make them fix it!! But, I'm lazy!
05-19-2011, 03:42 PM
Ill have to take it back up there tomorrow and find out what the heck happened.
05-19-2011, 03:57 PM
Real Name: Nick
Real Name: Nick
I think I've heard about this happening before. Check to make sure they plugged the temp sensor behind the lower dash panel below the steering wheel in. Location of sensor should be behind the area with little horizontal slits in the plastic.
A/C only blows cold air on "LO" setting Post #6
05-20-2011, 10:13 AM
Excellent, thank you! I will pull the dash apart tonight and see if this is the problem. I appreciate your help!
05-22-2011, 11:47 PM
Just an update, pulled off the panel below the steering wheel and they forget to plug in the sensor. Plugged her up and she is working good as new.
