Old 07-14-2011, 11:01 AM #16
ggunn9's Avatar
ggunn9 ggunn9 is offline
ggunn9 is on a distinguished road
ggunn9's Avatar
Update!!! I looked at several other forums and found recommendations to simply replace my gas cap and disconnect the battery.
SUCCESS!!!
I did that on Monday and no CE light. Gas cap cost about $12 at the local autoparts store. The members the other forums stated the expected life of the gas cap is 5-7. My 4rnr is a 2004.
ggunn9
2004 SR5 V6 2wd 2008-2015(sold)
2013 SR5 2wd Current ride
ggunn9 is offline   Reply With QuoteReply With Quote
Old 07-14-2011, 11:17 AM #17
TrailRebel TrailRebel is offline
TrailRebel is on a distinguished road
DTC P0430 CATALYST SYSTEM EFFICIENCY BELOW THRESHOLD (BANK 2)
I don't think replacing the gas cap is going to fix this code. Reason being, it will be a completely different code altogether (like a P0455 or P0456--Evap. emission control leak detected).
This code is getting set off because the PCM doesn't like what it's seeing from the oxygen sensors(which are the rear ones, the front ones are air/fuel sensors, just to detect lean/rich running conditions). So that means either the O2 sensor is bum, or the converters aren't doing their job.
My suggestion is if you don't have an actual scanner, to either replace the bank 2 rear O2 sensor and try it, or pay any reputable shop to scan it for you, so you can do the work at home.
My 06 had the same light on, but it was under 80k miles, so it was Federally Mandated Emission Warranty. I got three new catalytic converters out of it
TrailRebel is offline   Reply With QuoteReply With Quote
Old 07-14-2011, 11:44 AM #18
ggunn9's Avatar
ggunn9's Avatar
I already replaced the bank 2 rear sensor. So I will wait and see how this works. If it does not work then I will get a shop to scan it and do like you said do the work at home.
Thanks.
ggunn9
Old 07-14-2011, 02:56 PM #19
ggunn9's Avatar
ggunn9's Avatar
Like my wife says "Once again I am wrong" lol
I left the office for lunch 30 mins after my last post above this one and the CE light came back on. I am thinking I am going to have to replace the catalytic converter on bank 2.
Thought any one?
ggunn9
Old 07-14-2011, 11:05 PM #20
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
As was stated before, you gas cap will not cause a P0430, it is a completely different monitor than your Catalyst Efficiency. I posted some helpful information in an older thread regarding catalytic converters and diagnosing codes such as these. Instead of taking the time to rewrite the post I am just going to go ahead and pull it for you and post it here.
Most if not all car manufacturers use the same testing parameters for catalytic converter efficiency, they will use a Pre-Cat O2 or AFR Sensor and a Post-Cat O2 sensor to measure the effective "oxygen storage" and from that it gives its result on what it thinks the catalytic converter's health is. That's it plain and simple, the ECU will look at Pre-Cat O2 levels and then Post-Cat O2 levels to determine if the catalytic converter is actually working. This presents a small plethora of possible problems and scenarios ranging from complete catalytic converter failure to biased O2 Sensors. The reality is that this is nothing more than a Go, No Go test, because the catalytic converter does not deal only in O2. The only proper and 100% accurate way to test a catalytic converter's efficiency is to preform an intrusive test, where you drill into the cat and use a 4 or 5 gas analyzer to verify functionality. But, most people don't want to drill into the cat and most customers don't like that idea either...
In any case, if one of these codes is tripped you should always assume an "innocent until proven guilty" frame of mind towards the problem. First test the O2 sensors individually and then compare to what the scantool is providing as information. After verifying that the sensors are working properly and that the scantool data is in-line with the sensors I would hook up a 4 or 5 gas analyzer to the exhaust and measure the gases. This won't give you a 100% accurate view of what is going on, but it will help you figure out what the catalytic converter is doing. Without going deeply into the operation and chemical reactions that occur inside of the catalytic converter, the gases will vary according to what is actually happening. For example, if your catalytic converter was working well there would be little Oxygen coming out the tailpipe because it is used in reaction to modify quantities of NOx, CO, CO2, and HC. Keep in mind also that the catalytic converter is NOT the problem, a catalytic converter should last the life of the vehicle or at the very least a whole hell of a lot longer than most people will keep the vehicle. If the vehicle is operating as it is supposed to your catalytic converter should not fail prematurely, this is a SYMPTOM of another problem, not a problem in it self. Something to keep in mind when dealing with these codes/repairs, because I have seen guys slap a set of sensors and cats on a car and have it come back with the same problem months down the line because the real problem trashed the cats again.
There are other things to consider, such as if the vehicle has been driven with faulty sensors for a long time sustained damage to the catalytic converter may have occurred and it will need to be replaced anyways. The sensors may have damaged the cat but it could be "brought back to life." I have seen catalytic converters be brought back to life before, but really its a 50/50 shot in the dark.
Here are some links:
HowStuffWorks "How Catalytic Converters Work"
http://www.converterwarehouse.com/te...rter-&News=100
Catalytic Converter Tech Tips : Catalytic Converter Replacement : ConverterWarehouse.com
All Catalytic Converters - How do I know if my catalytic converter is defective?
Hopeful this will help you out.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 07-15-2011, 12:25 AM #21
ur7x ur7x is offline
ur7x is on a distinguished road
A great write up...
All I can add is that there are some cars and manufactures with known and common Cat problems... is you get this code in any GM from 2001-2003.. You can save all of these tests... You can bet your left one that you have a bad Cat... Very common (with TSB's to back it up).
One DIY test that you can do with a 0430 code is a WOT run at highway speeds... If this generates a misfire or lousy performance, then you know you have a bad Cat.
ur7x is offline   Reply With QuoteReply With Quote
Old 07-25-2011, 02:04 PM #22
mdaaboul313's Avatar
mdaaboul313 mdaaboul313 is offline
mdaaboul313 is on a distinguished road
first off i have 2 questions haha
1. what is a WOT run at highway speeds?
2. would i be able to take my manifold off and put a universal cat on it?
mdaaboul313 is offline   Reply With QuoteReply With Quote
Old 07-25-2011, 10:43 PM #23
Sorry about that... I thought that most every car guy would know what a WOT run is...
WOT = Wide Open Throttle... Get the truck up to 55 MPH and then bury the hammer. You will know long before you get to 75MPH if it is misfiring. If you aren't sure try this going up a hill. If you're not sure, its not misfiring...
Old 07-25-2011, 10:52 PM #24
lol ok now i feel stupid, oh well im in my last week of college and its killing my brain..thanks for clarifying, hopefully someone can answer my second question!
Old 03-20-2013, 12:57 PM #25
saaggie saaggie is offline
saaggie is an unknown quantity at this point
I am having the same issue in my 03 V8 with 193K. I replaced the front sensor on the drivers side about 6 mos ago. CK Engine light left for a while. Comes off and on intermentiently. I am hoping its not a cat since I have not lost fuel mileage or performance. Any and all suggestions are welcome.
SAT
93 Sport V8 4x4
265/70/17 YOKO Geolander A/TS
Voliant Cold Air Intake
Magnaflow Muffler
saaggie is offline   Reply With QuoteReply With Quote
Old 03-20-2013, 06:35 PM #26
BOSMECH's Avatar
BOSMECH BOSMECH is offline
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
BOSMECH is on a distinguished road
BOSMECH's Avatar
I had the same problem and replaced all 4 O2 sensors then 2 months later I got a CE and replaced the one bad sensor and now it is good. Those sensors are made cheap so they can be bad even when new.
I am going to send my 2 month old one back to Denso to try and get it replaced.
BOSMECH is offline   Reply With QuoteReply With Quote
Old 03-20-2013, 11:15 PM #27
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Lightbulb Unrelated p0420
I had installed the urd y-pipe on mine & about 90 mi. n threw 0420 so checked all the old posts on here & 120 ,bought both r sensors on amazon . Just as a lark also bought new gas cap as it is sorta one of the 1st things THEY say to check (probably f ing myself here) cleared with obd 2 & no cel for 2 tanks of gas ! Some really good old posts if search under "sensor" helps explain alot some is previous Blackworksinc & others with more knowledge than me !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 03-21-2013, 12:34 AM #28
Stuck CAPS's Avatar
Stuck CAPS Stuck CAPS is offline
Real Name: Alex
Stuck CAPS is on a distinguished road
Stuck CAPS's Avatar
Real Name: Alex
Originally Posted by fdte320 View Post
I am in California & can't imagine the cost of a new cat. Have you resolved your issue?
If it comes down to it, you could always get some high-flow cats
Stuck CAPS is offline   Reply With QuoteReply With Quote
Old 03-21-2013, 12:45 AM #29
Must be 50 st legal n Kali ! Most after-markets don't have correct material n them ,unless you re-install all 4 of them
Old 03-21-2013, 01:15 AM #30
Stuck CAPS's Avatar
Real Name: Alex
Stuck CAPS's Avatar
Real Name: Alex
I'm sure you can find some.
P0420 & P0430 Codes, When will it end??? a77boy Problems & Warranty Issues 16 01-19-2011 12:05 AM
P0430 and P0420 at the same time! Runner4u Problems & Warranty Issues 7 12-09-2010 12:49 AM
P0102, P0430, P0420 error codes a77boy Problems & Warranty Issues 3 03-09-2007 06:27 PM
