Great thread gang, I appreciate all the information as I am chasing a reoccuring P0430 code on my 2005 V6, 186k miles truck.
I picked up a code reader so at least I can reset it and not panic when the Christmas tree lights up.
I replaced the gas cap already with a new OEM one., just a precaution. Light went away for a while, then came back last night after a couple of weeks of clear dash. Cleared the light last night when it came back on and it didn't come back on my short drive today.
So I think whatever is causing it is just on the edge of a problem. The right temps, or maybe the wrong puddle, or whatever. No MPG or Power issues so I think it's probably the downstream O2 sensors going OR a small leak somewhere.
I had some exhaust work done about 3 years ago from my excellent local independent. It's possible I've got a pipe or joint farther up stream from the new stuff with a hole or gasket leak of some sort. I'll have them check this first.
Originally Posted by lightfreak
Th upstream A/F sensors should be interchangeable but the downstream O2 sensors are different length harness.
Here's what I put in my V6
DENSO 2344804 Downstream Left
DENSO 2344805 Downstream Right
Thank you for these!! If my muffler shop doesn't find a leak I'll start by replacing these 2 myself.
I initially searched up this thread to see how long I could go with this light occasionally coming on. Presumably if it's not happening during my State required yearly inspection, and it's not causing power/mpg issues then it's not something I need to panic about, right? I can clear it when it happens and continue to pick away at possible fixes.
