Old 07-06-2011, 06:03 PM #16
tnark tnark is offline
tnark is on a distinguished road
Originally Posted by Sonicpilz View Post
TnarK is yours a V6 or V8? Can you also take some measurements for us pre and post the 1.5 rear spacer?
I used FJ springs + 5100s all the way around set at .85 (2nd notch) on a 2003 V8 4x4. I ended up with about 1/2" more lift in the rear than I expected (1 full inch of lift). So with my .85 setting I got a total of 1.5" FRONT and 1" rear lift and I'm still at 1.5" rake (2" stock). I'd like to be between 1/2"-1" so I'm still debating on going up 1 notch in the front.
On paper......my measurements are 35.5 FRONT and 37 REAR. If I go up 1 notch in the front it should add 1" and give me 36.5 FRONT and 37 REAR. Sounds about right.
I can barely tell you have the "bro lean" or reverse rake. Can't be that much. I'm thinking I can go up 1 notch up front and get by without adding a rear spacer but im not sure.
Most of these swaps are difficult to compare because the majority of people I've seen doing the swap are 2wd or v6. The v8 is a little heavier up front and we get less lift.
Sorry, but I neglected to get measurement before the install. I was in a hurry to get this done before leaving for vacation with my runner loaded down with about 400lbs of gear plus 4 people. Currently with the 5100's stock springs all around and a Daystar 1.5" coil spacer here's my measurements. My runner is a limited V8 model
Front - 35.5"
Reaer - 37"
Here's a pic as she sits now.
After 5100 install-bilstien2-pics-002-jpg
tnark is offline   Reply With QuoteReply With Quote
Old 06-15-2016, 09:16 PM #17
alhang alhang is offline
alhang is on a distinguished road
looks nice
2003 V8, Bilstein 5100's / OME 886/898 ,Kenwood Head unit, methods 255/80r/17 lots of other things
alhang is offline   Reply With QuoteReply With Quote
Old 06-16-2016, 02:20 PM #18
smorabito19 smorabito19 is offline
smorabito19 is on a distinguished road
Can someone tell me what the rake is?
smorabito19 is offline   Reply With QuoteReply With Quote
Old 06-16-2016, 02:31 PM #19
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
when the front is lower than the rear and noticeable.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 06-16-2016, 02:33 PM #20
Thank you sparky. That makes sense now to why most people want to get rid of the rake
Old 06-16-2016, 02:47 PM #21
Real Name: Mark
Real Name: Mark
I prefer a 1inch - 1.5 inch rake. front 1-1.5" lower. That's me though. other like dead even and the select few like the reverse rake or bro lean. "front higher than rear"
'04 Sport V8
Old 06-16-2016, 02:48 PM #22
So with 5100s on 2.5/1.5 will there be a bro lean or just dead even?
Old 06-16-2016, 03:23 PM #23
JD914's Avatar
JD914 JD914 is offline
JD914 is on a distinguished road
JD914's Avatar
You'll still have some rake with that setting. I've got the same setup and while it's not as bad as stock, there's still a bit of rake.
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
JD914 is offline   Reply With QuoteReply With Quote
Old 06-16-2016, 03:30 PM #24
Real Name: Mark
Real Name: Mark
like @JD914 said, slight rake which looks perfect to me. If your dead even, it will appear you have rake.
'04 Sport V8
5100 , coil spacer , daystar , shocks
Front Bilstein 5100 install tips and tricks to help you out! Border411 Engines / Suspension / Wheels / Tires / Audio / Accessories 36 06-30-2018 12:13 PM
Getting ready to install Bilsteins 5100's....a few ?'s Border411 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 08-28-2014 03:19 PM
Bilstein 5100 Front and Rear Install Height on the 5th Gen ct221933 5th gen T4Rs 5 02-22-2011 12:59 PM
Weird *dragging* after 5100 suspension install and alignment Border411 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-30-2010 08:27 AM
