Originally Posted by MikeinNH67
I dunno about all day but easily can go over an hour unless you've done many that have rusted in place. You also have to line it up right or the wheel will be off. I think I adjusted mine one spline at a time 4 times before I got it right. Had to drive it each time to verify it.
I found that I didn't need to worry about that. Got it right the first time. The upper spline had master teeth on the shaft, yoke & the shaft going to the steering wheel and would only go on one way.
The bottom spline didn't but, the spline on the shaft on the steering unit had a built up line of corrosion under where the compression slot was on the old steering shaft. That line of corrosion acted as a master tooth and the only way I could fit the new steering shaft on was by lining up the compression slot on the new shaft with that line of corrosion left by the old shaft.
