Hi, have about 125k miles on a 2003 4-runner limited. Several months ago I noticed each wheel shows the finish bubbling and certainly peeling. Vehicle is mostly used for normal driving and out in the elements but in lower mid-atlantic where weather is not particularly harsh. Is this normal wear and tear? Anyone experiencing the same issue? Thanks
Do you have pics? It sounds like the clear coat coming off.
RickC
2003 Toyota 4runner Sport V6 4x4, Daystar 2.5/1.5, Enkei ST6 18x8.5, Toyo Open Country AT2 285/60/18, Scion FRS Touchscreen head unit with NAV and backup camera, LEDBARZ 41" light bar.
Yep, I had the exact same issue with the spare tire rim the worst of the lot but all were starting to look bad.
So I found a local place that media blasted the old finish off & had the rims powder coated flat black for $300 for all 5. The have since held up fine in the 2 years I have had em like this & that includes lots of wheeling too.
Same issue here on my 03. I'm going to fix by getting TRD Rock Warrior rims though
Black 2003 Sport, V8, 4WD, 115K miles - as of June
2016, AMSOIL lubed, JVC Headunit 925BT, Rockford Fosgate Amp, Rockford Fosgate 10'' P2's in custom box
That is a good looking wheel!
RickC
I have the same issue on my '03. Stock rims are pealing and rusting. Not sure what to do. May try to find someone to sandblast and repaint or may just wait till the tires need to be replaced and then replace the rims as well. Would like to hear how the bed liner solution works out.
Been there! My 03 stock rims were oxidizing and peeling when I bought my T4R used in 2007. I decided to buy another set of rims (from a fellow T4R.org member) that were in way better condition. Once I got them, I cleaned them really well and applied a coat of wax. They've made it through our Canadian winters with all of its road salt no problem.
I had also considered, as already suggested, sandblasting and powdercoating the original rims. I just didn't want to have my T4R tied up with the wheels off.
Both of these options are less expensive than new rims through Toyota.
