Old 09-25-2011, 02:51 PM #1
Chrisrw Chrisrw is offline
Chrisrw is on a distinguished road
Please help me get this bulb out!
So I'm a noob to stunners but not at all to cars...
I'm trying to remove the drivers side FRONT signal light. How the F does this thing come out?? It does to seem turn like all the other cars lights that I've worked on...
And also, what kind of bulb is it?? (the small one in the corner) I've tried searching and can't find anything but rear bulb replacement stuff...
Thx a lot guys!
Chrisrw is offline   Reply With QuoteReply With Quote
Old 09-25-2011, 03:37 PM #2
sr5hi sr5hi is offline
sr5hi is on a distinguished road
Thx a lot guys!
Sylvania Bulb Replacement Guide. Click on the link.
OSRAM SYLVANIA - Replacement Guide - Start
Turn the bulb socket counterclockwise. You may have to gently pull and wiggle it as the rubber o-ring often gets stuck in the housing.
2003 SR5 V8
sr5hi is offline   Reply With QuoteReply With Quote
Old 09-25-2011, 03:44 PM #3
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
And don't be surprised if the bulb burns out again in a short time. Often the socket needs replacing.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 09-25-2011, 06:29 PM #4
ran ran is offline
ran is on a distinguished road
ran ran is offline
or just spray the connector with contact cleaner. No problems with mine the last 6 months.
_________________
'07 SE V6 Titanium
ran is offline   Reply With QuoteReply With Quote
Old 09-26-2011, 07:38 PM #5
Ok, thx. But on the drivers side the batt is really in the way. I cant even really get my hand in there! Any tricks/tips to getting in there?
Old 09-26-2011, 08:00 PM #6
ran ran is offline
ran ran is offline
I did not disconnect the battery, just loosen the hold down and tilt the battery away. that was enough for me to reach in there. Go with contact Cleaner first, saves you a lot of time.
Old 09-26-2011, 08:17 PM #7
JD914's Avatar
JD914 JD914 is offline
JD914 is on a distinguished road
JD914's Avatar
I was able to reach in from the front (where the grill would be) to reach that socket. When you finally get the bulb replaced, give it a firm push into the socket. I was surprised how hard I had to push to get it to click in.
JD914 is offline   Reply With QuoteReply With Quote
Old 09-26-2011, 11:18 PM #8
Thx a lot guys!
If you can't get your arm/hand in there because the battery is in the way then you will have to remove the battery hold down and move the battery a little until you have room for you arm/hand. If there is still not enough room, you will just have to disconnect the battery and remove it completely from the vehicle.
2003 SR5 V8
Old 09-27-2011, 01:38 PM #9
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
Access is pretty easy from underneath.
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 09-27-2011, 09:50 PM #10
Underneath?? Like from under the vehicle? Wtf? That's just weird. But I'll give it a try!
Thx guys!
Old 09-28-2011, 01:24 AM #11
krupnation's Avatar
krupnation krupnation is offline
krupnation is on a distinguished road
krupnation's Avatar
Thx guys!
Yes, underneath. Guess what? You can replace other items by getting underneath the vehicle (yes, said with heavy sarcasm ) I've replaced both my sockets in the past month and did it in the stealership parking lot in 2 minutes. No battery removal, that's crazy talk...
"I'm addicted to speed but not the drug..." - Swollen
2005 SR5 V8 | OEM LED tail lights | Wheelskin leather steering wheel cover | Scion T1808 HU w/ iPod adapter | 35% tint (match rear) | FJC coils w/ Bilstein 5100's (2.25 setting) | Toytec Superflex rear coils | WeatherTech digital-fit mats | Mini Morimoto HID projector retro-fit | Spidertrax | AFE drop in | GY Duratrac's (285/70-17) | headlight blackout DIY |
krupnation is offline   Reply With QuoteReply With Quote
Old 09-28-2011, 01:32 AM #12
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
Maybe there's an easier way, but that worked so well I didn't even consider anything else. Headlamp is nice.
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 09-28-2011, 02:31 AM #13
Thx guys!
What year is your 4Runner? From reading your first post I assumed that you were talking about your "Turn Signal" bulbs, which on 2003-2005 models are in the bumper and accessed from under the front of the vehicle.
When you referred to the battery being in the way, it now appears you are talking about a 2006-2008 model where the turn signals are mounted in the headlight housing.
2003 SR5 V8
Old 09-28-2011, 06:34 AM #14
Desert Fox's Avatar
Desert Fox Desert Fox is offline
Real Name: Bill
Desert Fox is on a distinguished road
Desert Fox's Avatar
Real Name: Bill
There is a yellow bulb in the 2003 headlight assembly. I am having the same problem trying to get it out. I did not think to try from underneath so I will give that a try.
My fat stubby hands just dont fit in that confined space.
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
Desert Fox is offline   Reply With QuoteReply With Quote
Old 09-28-2011, 03:39 PM #15
This is indeed the problem. It's my girlfriends 4runner and so I can't exactly look at it all the time. I DID NOT KNOW that the signal light was in the bumper, I thought it was the small orange bulb that is in the top outside corner of the headlight.
I will now get the correct bulbs and get it done in about 2 seconds I believe.. haha. Thanks for the help guys. It's hard to figure out when she's out of town with the 4runner....
light bulb crawyota Classic T4Rs 1 05-21-2011 12:52 PM
921 bulb mod chaz Engines / Suspension / Wheels / Tires / Audio / Accessories 3 02-28-2010 02:40 PM
I know that I am not the brightest bulb in the box...BUT.. coltonk Classic T4Rs 11 09-07-2009 10:16 PM
Dash computer light bulb out - bulb type? Futrewoods 4th Gen T4Rs 3 01-03-2009 01:12 PM
Fog Light Bulb nytefog 4th Gen T4Rs 4 12-06-2008 08:00 PM
