Old 11-18-2011, 11:11 AM #1
traxman25's Avatar
traxman25 traxman25 is offline
traxman25 is on a distinguished road
traxman25's Avatar
96-02 4Runner Plate Front Bumper
  • Made in America
  • ¼” and 3/16” High Grade American Made Steel
  • Complete Bolt On Bumper, no modifications required to install
  • 10 mounting points
  • Ultra heavy duty D-ring shackle recovery points
  • Integrated winch mount for any standard 9500lb or less winch
  • Internal support system for maximum strength
  • Unique front winch access holes for easy winch clutch and control socket access
  • Winch drum view port above winch drum
  • Internal winch hook storage location
  • Internal D-ring shackle storage location
  • Hi-Lift jack lifting point with anti-slip griping lip
  • Mounts with factory and aftermarket skid plates that use factory mounting location
  • Light and antenna mounting holes predrilled
  • New turn signals included
  • Mounts for standard 4 inch driving lights Included
  • Rigid Industries Dually LED offroad driving lights available
  • 2 bend stinger optional
  • Most holes and ports are optional, pick and choose for that custom bumper you've always wanted!
  • Save $$ when you order a Front and Rear Bumper combo pack!
You have been searching high and low for a new front bumper for your Toyota 4 Runner but now your search is over! 4x Innovations is proud to manufacture the highest quality front plate bumper available for your third gen 4Runner. From the ground up this plate bumper has been engineered for strength and convenience. A single piece of metal forms this bumpers mounting system and winch plate, using 10 factory bolt holes on the front and sides of your frame, providing superior mounting strength. Welded directly to this mounting plate are two high strength recovery shackle points that are also locked directly into the front face of the bumper. Most standard winches 9500 lbs and below without an integrated solenoid pack will fit directly to this bumper. To protect your winch hook and cable an integrated internal winch hook loop is provided. When the time comes to use your winch you have easy access to the clutch and control cable connections through the unique front access holes. If you need to lift the front of your truck you can use one of the two built in Hi-Lift jack locations with integrated anti slip lip.
Internal mounts for 4 inch driving lights come standard. Install your own or upgrade to Rigid Industries Dually LED offroad driving lights, available from 4x Innovations. Holes are predrilled for two additional driving lights in front of the grill. Had enough? Well we also give you a predrilled CB antenna mounting hole on the driver and passenger corners so you can choose which to use. Replacement turn signals are included.
Bumper ships as a straight bolt on unit, you will not need to modify your truck in any way to fit this bumper. However some small sheet metal tabs can be cut off to improve aesthetics. Mounts with factory hardware. Bumpers are $731 plus shipping.
Are you running a body lift? We can build your bumper to fit 1 and 2 inch body lifts also (additional charge)
Click here for more information and to place your order today!
Like us on Facebook!
96-02 4Runner Plate Front Bumper-fb1140c-jpg  96-02 4Runner Plate Front Bumper-fb1140d-jpg  96-02 4Runner Plate Front Bumper-fb1140j-jpg  96-02 4Runner Plate Front Bumper-fb1140l-jpg  96-02 4Runner Plate Front Bumper-fb1140a-jpg
4x Innovations - Adam
Hardcore Toyota Rock Crawling Armor
traxman25 is offline   Reply With QuoteReply With Quote
Old 01-22-2012, 09:53 PM #2
clys clys is offline
clys is on a distinguished road
Do you make a wider version to fit the limited's flares? Do you offer powdercoating?
clys is offline   Reply With QuoteReply With Quote
Old 01-22-2012, 10:41 PM #3
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
4x Innovations
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 01-23-2012, 09:58 AM #4
traxman25's Avatar
traxman25's Avatar
It is built to fit both with the flares and without the flares. I don't powder coat as there is no affordable way to ship a powder coated bumper and guarantee that it will not get scratched in transit.
Old 03-08-2013, 12:16 PM #5
traxman25's Avatar
traxman25's Avatar
Bump for great 4Runner bumpers that now have new features!
There is now a new winch view port on the top side of the bumper so you can see and access the winch drum. Also by popular request most holes are optional! The fog/driving light holes, front winch access holes and the top winch view port can all be deleted/removed if you do not want them.
We have a couple here on the shelf, get yours ordered today!
Old 03-29-2013, 12:14 PM #6
traxman25's Avatar
traxman25's Avatar
3rd Gen 4Runner Front Plate bumpers are a great way to protect your front end, order yours before your next wheeling trip!
Old 04-07-2013, 05:31 PM #7
Sr5_runner Sr5_runner is offline
Real Name: John
Sr5_runner is on a distinguished road
Real Name: John
How much are these? Shipped to 44134 business address
Sr5_runner is offline   Reply With QuoteReply With Quote
Old 04-08-2013, 09:39 AM #8
traxman25's Avatar
traxman25's Avatar
PM Sent for both the front bumper and sliders, thanks!
Old 04-12-2013, 10:40 PM #9
mac424205 mac424205 is offline
Real Name: Mat
mac424205 is on a distinguished road
Real Name: Mat
how much for the bumper with the hoop shipped to 35043
mac424205 is offline   Reply With QuoteReply With Quote
Old 04-15-2013, 10:44 AM #10
traxman25's Avatar
traxman25's Avatar
PM sent, thanks!
Old 05-08-2013, 11:28 AM #11
dustin Keeler's Avatar
dustin Keeler dustin Keeler is offline
dustin Keeler is on a distinguished road
PMD you guys.
2000 4Runer SR5 3" Rough Country lift on 265/75/16
dustin Keeler is offline   Reply With QuoteReply With Quote
Old 05-08-2013, 11:38 AM #12
traxman25's Avatar
traxman25's Avatar
Replied, thanks!
Old 05-29-2013, 09:44 PM #13
4X4snowRunner's Avatar
4X4snowRunner 4X4snowRunner is offline
4X4snowRunner is an unknown quantity at this point
Body lift
Do you make it for SR5 3rd gen with 2" body lift?
1998 4Runner SR5 V6 A04A 4:56
front suspension:OME882 OMEn91s topout spacer sonoransteel tapered 1" diff. drop rear suspension:LC OME851 Bilstein 5100 sonoransteel adjustable trac/panhard bar Daystar KU09014BK Bump Stop 285/75/16Toyo Open Country MT 16x8 Painted Gun Metal American Racing Wheels Borla Exhaust Cat Back Braided Stainless Rear Brake Line Extended Rear Differential Breather 4Crawler 2" BL
4X4snowRunner is offline   Reply With QuoteReply With Quote
Old 05-29-2013, 10:02 PM #14
traxman25's Avatar
traxman25's Avatar
I'm putting together a list of people that want one. Because of how well supported this bumper is we have to actually make all new shell pieces. There will be an increased cost involved but I do not know what that will be exactly. If you'd like to be added to the list shoot me a PM with your name and phone number or email.
Old 05-30-2013, 03:03 PM #15
Brian757's Avatar
Brian757 Brian757 is offline
Brian757 is on a distinguished road
Brian757's Avatar
Shoot, if you guys made a possibility for your bumper to work with a 3" Body Lift, you would have a customer for sure.
2002 "Stormtrooper" 4Runner
Tacoma Bilstein 5100s | Eibach/Toytec Springs (Front) | FJ Springs (Rear) | Tundra 13WL Brake Swap | Much More...
Brian757 is offline   Reply With QuoteReply With Quote
HTML code is Off
WTB rear and/or front tube or plate bumper(s) Viking97SR5 Classifieds - buy & sell (no commercial ads please) 0 03-25-2011 06:58 AM
WTB: Plate style bumper for 3rd gen 4Runner DNH T4R Want to Buy/Trade 0 03-15-2011 02:30 PM
WTB 93-95 4runner Sapphire, Saphire Blue PS Front Fender & Front Chrome Bumper My Boy Blue Classifieds - buy & sell (no commercial ads please) 0 02-06-2011 02:39 PM
between the front bumper and skid plate TC4Rnr 4th Gen T4Rs 20 04-26-2010 11:12 PM
WTB: Front bumper liscence plate bracet 03-05 phishtaco Want to Buy/Trade 4 01-02-2009 11:39 AM
