Originally Posted by Master Yoder
It sounds like another possibility is the O2 sensor/s. That seems like a lot to fix. Is it possible to clean the O2 sensors and fix the problem or is it most likely going to need to be replaced?
How hard is it to DIY? Do you have to take the exhaust off to get to the sensor or is it external? It seems like it would be an easy thing to replace but I don't know
Check out this link for 3rd GEN O2 sensor replacement.
4x4Wire - Tech: Time to Replace the O2 Sensor on your 3rd Gen Toyota? I did mine at 100K as a preventative maintenence. Bought the DENSO brand on Amazon. Denso makes the OEM sensor that Toyota will sell you for twice as much. Good Luck.
