Originally Posted by haddix
Bolt on would be good if you were only doing it for looks.
There are many components that are bolted to the frame that are not for looks. The front bumper beam and the tow hitch are two that I can think of off hand.
As for design, Shrockworks bolt on wraps the frame on 3 sides with steel, therefore the bolts only carry a portion of the weight of the slider. They are not going anywhere.
There are risks to welding on sliders, such as applying too much heat to an area causing a weak point on the frame.
