Question about setup for the fix
If I am reading this correctly, I will take two wires (my plan is 12G romex) and insert them into the correct spots in the OBD II connection port. I will stand outside of the vehicle and touch the opposite ends of both wires together "4-8 times". I will go through a series of on and off procedures and this should work.
My question is, is my devices, a set of two wires plugged into the correct pin positions, then touching the opposite ends the correct procedure. I want to be sure before I attempt this and destroy my truck.
2004 Sport Edition 4WD V6
JBL, Sunroof, DD Cargo, all the standard options for the SE and...
Silverstars
SPP 80W Fogs
10.2" widescreen DVD drop-down
PIE-AUX hardwired into JBL
All-weather floor and rear cargo mats
Goodyear Wrangler Silent Armors
265-70-R17s
