Originally Posted by runrunner
Very nice write-up. This should be stickied and put under the maint section.
I installed my Hayden 677 pretty much the same way. As a few others have mentioned I had to cut the lines to get them off, it was a biatch!
The problem I had with my install was the supplied line was too small and I didnt figure that out until after I cut off the old lines. Had to ride my bicycle to the parts store to get the larger line (felt like a tweaker).
Getting the new rubber lines over the existing metal lines was a PITA too. One went all the way and the other almost made it, but it fell a little short.
The supplied lines are tight but you can get them on. I dipped a qtip in ATF and lubed the inside of the line. It was still tight but I got the lines on.
