No problem, glad I could help!
Getting the four pins lined up is the trickiest part of this fix. That's why initially I barely soldered them on so I could still work them into place, then carefully lined them up and added more solder for the permanent joint.
I think the weird burned-looking spot you noticed on the screen may be where they purge/fill the glass envelope with inert gas (or maybe neon) and then seal it off during manufacturing.
“Engineers don’t idle well.”
'99 Limited 4WD
Upgrades: BFG AT T/A KO 265/75/16, Husky floor liners, WeatherTech window deflectors, Silverstar Ultra headlights, TaskLED Dome lights, Red & White LED maplights, LED tails & 3rd brake light, 35% tinted front windows, TrueFlow air fliter, hardwired V1, Scion T1807 HU w/ Aux input, Masterflow MF1052 in rear side storage
Mods: Deckplate/ISR, independent fog light control, rear diff breather, constant hot 12v outlets, seat-mounted LED Maglite
