Old 11-10-2011, 11:29 AM #1
4RunnerTrail 4RunnerTrail is offline
4RunnerTrail is on a distinguished road
285s or 265s? Do the 285s look that much better?
I have a question. Looking to upgrade tires on my Trail Edition. I'm curious from others, do the 285s look that much better? I would have to mod the fender liner upfront and then upgrade spare or have no spare tire. Hard to tell from pics but do they look noticably different inperson? I'm on the fense. I might even have to install bilstein 5100 set at either 2nd or 3rd setting to work with 285s. i'm running stock trail wheels.
I go back and forth on this. Would like truck to look more aggressive, love the look of off road trail but with the stock hwy tires looks frail. 265s in an at or mt would help.
pics? thoughts?
4RunnerTrail is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 11:39 AM #2
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
IMO, the actual tire chosen makes more of a difference "looks wise" than the size of the tire. When I change I will go for an AT tire like the Duratracs or BFG AT in stock size instead of a larger tire. I will do it because of performance as primary, looks secondary though. Function over form.
1engineer is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 12:24 PM #3
joneseyyy's Avatar
joneseyyy joneseyyy is offline
joneseyyy is on a distinguished road
joneseyyy's Avatar
That's an extremely subjective question. I've run Duratracs in both the stock 265 and now in 285 on the 4runner. Here's my feedback - the duratracs in 265 look remarkably better and more rugged than the stock tires, and perform a whole hell of a lot better. The 285's in conjunction with my lift are (from a looks perspective) significantly better than the 265 Duratracs.
In orders of magnitude, going from stock to something more aggressive in the stock size is probably the most "bang for the buck" in terms of getting the "off road look" you want, while also giving you a better handling truck (in my opinion).
2010 Trail Edition | Not Stock
Scratching the itch for off-road adventure one weekend, one vacation at a time, taking our Toyota trucks well off the beaten path one day and driving them to work the next! Covering the trucks, the trips, the gear, and the lifestyle.
www.dirtroadtrip.com
joneseyyy is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 12:53 PM #4
ChipG ChipG is offline
ChipG is an unknown quantity at this point
Might want to concider....
Gearing. There is a noticable difference in gearing when stepping up to the larger tire.
2011 T4R, JL 8W3v3, JL 700/5, JL C5 3way, AudioControl LCQ-1
ChipG
ChipG is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 03:17 PM #5
UtahSooner's Avatar
UtahSooner UtahSooner is offline
Real Name: Aaron
UtahSooner is on a distinguished road
UtahSooner's Avatar
Real Name: Aaron
pics? thoughts?
I'll x2 joneseyyy's comments here, pretty subjective choice... we're talking about a ~1" difference in overall tire height and ~13/16ths (20 mm) difference in width...That said, I put 285s (GY Wrangler Silent Armors) on my stock 2010 TE after ~ 1k miles and aside from having to move/cut a little plastic (which is no big deal), they've worked well. Now, do they look "significantly" better than if I'd put on the same tires in a stock 265 size? Well, I think they look better... "significantly" better? All in the eye of the key holder I guess... While the Wrangler SA's tread isn't super agressive, the taller sidewalls definitely fill out the wheel wells more (and I like that look personally, some don't...). From the rear I can tell the difference in tire width if I look closely, but 20mm wider isn't much. Just puts the outside wall of the tire a scosh further outboard without haveing to add spacers (which I didn't want to do).
All that said, I had the "+1" size tires on my old 3rd Gen Sport Edition (also GY Wrangler SAs) so I was used to both the look and driving performance/feel of running a slightly larger tire. While there may be some minimal differences in gearing, acceleration, on-road performance, etc, I've never noticed any significant differences while driving. Your gas mileage will take a small hit with the added tire weight, but it's a very small hit especially when you figure that any AT or MT tire will have more rolling resistance than the stock Dunlop "AT" (aka street) tires. I'll also say that I spend a lot of time driving for work, both in town and 2-4 hr trips, and the highway performance of the 285s has been great.
Next up for me is a set of 285 size Duratracs for winter. I've got 30k miles on the current tires now and while there's plenty of tread for another year of "3 season" driving, the tread is a little lower than I'd like for winter driving back and forth to ski resorts and backcountry skiing trailheads around Utah.
Last thought - I don't have any suspension mods on the truck yet but that's the next project I'm considering. At least a leveling kit to raise the front end up just a bit. Got to save up the $$ before I go too far down that road though.
Just my $0.02. I'm pretty sure it'll look great either way (once you get rid of the Dunlops of course) so good luck. And, you asked for pics so here are 2 of my truck - one with the brand new 285s on the stock wheels and the second of the same tires (after 30k miles) on my new TRD wheels. For pics of stock size Duratracs on the same TRD wheels, check out some of 453030's pics in the links below:
Got the TRDs off road
Mag Grey owners have a pretty killa wheel option
285s or 265s? Do the 285s look that much better?-4runner-285s-jpg  285s or 265s? Do the 285s look that much better?-trd-wheels-03-jpg
UtahSooner is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 03:38 PM #6
Y2KSR5 Y2KSR5 is offline
Y2KSR5 is on a distinguished road
I just went with stock size in the BFG AT. Couple pics of it
2013 Black Trail/Destination AT/Leather/Grey TRD Pro wheels
Priors:
2011 Magnetic Grey SR5 4WD
2008 Shadow Mica SR5 4WD
2000 Desert Dune SR5 4WD
Y2KSR5 is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 05:20 PM #7
11TEBLK's Avatar
11TEBLK 11TEBLK is offline
11TEBLK is on a distinguished road
11TEBLK's Avatar
Depends on Lift or not!?!
I was in a similar situation as you are a few months back. If you plan on a lift then I would definately go with 285's it just looks a lot meaner with bigger tires. Nothing worse then a lifted rig with small tires on it, just dosent look right IMO. I chose to go with the stock size Duratrac's. For me their PERFECT!! Aggressive look and feel and no need to upgrade you're suspension.
285s or 265s? Do the 285s look that much better?-4runner-06aug11-001-jpg  285s or 265s? Do the 285s look that much better?-4runner-06aug11-004-jpg
2011 TE KDSS/NAV, TRD CAI, 265/70/17 Goodyear Duratracs
11TEBLK is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 06:27 PM #8
offroadingatc's Avatar
offroadingatc offroadingatc is offline
offroadingatc is on a distinguished road
Agree with this. AT tires have 'squarer' sidewalls, so give a much bigger look.
I plan to put stock sized duratracs on mine within the next month or so. My reasons for staying stock size:
-I dont think they look overly small now, and going AT should sort that out
-I dont want to mess up my odo/spedo, and dont really want to go to all the work of a speedohealer
-I like my fuel mileage
-I plan to use them year round, and wider is worse in snow.
Either way you cant go wrong
2011 Canadian SR5 Premium - Toytec Ultimate Lift - Light Racing UCA's - Rear diff breather mod - Rocky Road Sliders - Goodyear Wrangler Duractracs
offroadingatc is offline   Reply With QuoteReply With Quote
Old 11-10-2011, 06:30 PM #9
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
Looks are subjective! Literally hundreds of pics for you to look at in the lifted sticky section being 2 years into production and many have lifted with and without bigger tires for you to look at.
On road, performance wise you will definitely take a hit in the fuel mileage and quickness as the gearing is better suited to stock size(31.6") and the tires generally weigh more .
However the trade off is better performance offroad with bigger diameter tires by having more ground clearance.There is no substitute for clearance when your offroading and the only way to gain clearance with our 4 link suspension in the rear at the rear differential(pumpkin) and axle is by getting bigger tires.
Stock 265's are ~31.6" diameter and 285's are ~33" which breaks down to about .7" more ground clearance or radial difference. Doesn't sound like much ,right,but I do have plenty of scrape and gouge marks on my pumpkin,lower links and hitch reciever even with the bigger diameter tires. If I had .7" less clearance I would have scraped more or possibly gotten hung up?? For that reason I will eventually have even bigger diameter tires when I get better suited(4.56) gearing.
With gearing,a body mount chop and minor body lift I don't see any reason many people will be running 35's before too long in a 5th Gen.Just look at the 4th Gens and especially the FJ's where 35's are common with basically the same suspension/frame set up as us.
Ground clearance is king in a 4 wheel drive and it also applies to deep snow,logs ,ditches, mud holes and not only rocks. Bigger diameter tires is the only way to gain it in the rear.That's the kind of performance I personally am looking for. They do also look better of course IMO!
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 11-12-2011, 12:43 PM #10
that looks great. C or E rated tires?
now if i could see 285s on stock wheels stock height!
Old 11-14-2011, 10:56 PM #11
Will733's Avatar
Will733 Will733 is offline
Will733 is on a distinguished road
Will733's Avatar
I doubt you'll find anyone with 285 Duratracs on a stock height 4Runner... I just put on a new set a few days ago (will post pics soon) and have more rubbing again. I had already trimmed the plastic fender liner enough to prevent any rubbing with 285 BFG ATs but these must be just a tad bigger and will require me to trim some more.
2010 MAGNETIC GRAY 4X4 SR5
Bilstein 5100's at 1.75" | Rear Driver Side Daystar 1.5" Spacer | 285/70/17 Duratracs | Spidertrax 1.25" Spacers | FJ Wheels | FJ Shift Knob | TE Grille
De-badged | Plasti Dipped Chrome | Pilot Stub Antenna | Shrockworks Sliders | Window Tint | Interior LED's | Air Dam Removed | Side Skirts Removed
Will733 is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 12:26 AM #12
user name: user name: is offline
user name: is on a distinguished road
check out the 265/70r17 cooper stt's
user name: is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 12:42 AM #13
desert pirate desert pirate is offline
desert pirate is on a distinguished road
Hi all, new to the forum and a new TE owner! I have been reading a ton on here but still remain confused about fitting 285s on my rig. The stock tires just dont cut it here in the NM sand with the extremely small contact patch. I dont plan on upgrading the suspension for a while but would love to run 285. I dont mind moving the liners for a bit more room, but dont want to have to trim them. Is this unrealistic?
It seems like Utahsooner is running them fine, but do they rub when off road?
Harper7 can you disclose your rim specs that allowed you to run 305s with just a spacer lift up front? And did that set up rub off road?
I can live with 275s if that is all i can fit stock, but would love to run the 285s (33s) if possible, willing to do the leveling lift if needed and move the liner a bit. Any help on achieving this would be lovely. Like i said i have searched and been reading on here daily for a month, thank you all for the wealth of knowledge already. Loving my new TE!
desert pirate is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 08:49 AM #14
I believe from the research i've seen you will be fine with bilstein set at 1.75 upfront and moving the fender lining with 285s
Old 11-15-2011, 03:19 PM #15
Jtraskell Jtraskell is offline
Jtraskell is on a distinguished road
Much of the rubbing occurs due to "castor" in your alignment. I have 285 Michelin's all season Radials Light Truck tires, Load range D. When first installed no rubbing at all. But after I had the castor changed to a more positive position (for a better steering feel), I got a "little" rub but only in reverse and only if I had the steering cocked all the way left or right. My original Castor was at around 2.0 and I moved it to 3.0.
I moved the inner wheel fenders forward about 1/2 inch or so, no more rubbing. Based on what I have read on this forum, 285 AT tires seem to rub a bit more, but again, I think it depends on your castor position and it seems all have solved the problem by either moving the inner wheel well liners forward, or installing a small to moderate front end lift. So, my suggestion is to put the tires on you want, if rubbing occurs, take a close look and if just moving the inner wheel wells solves the problem, great. If not, then go to a lift. I hope this helps.
Be safe.
2010 Salsa Red SR5, Black Power Leather Seats, Sliding Rear Cargo Deck, Luggage Rack Cross Bars, Black Pin Stripes, Black Body Side Moldings, Front and Rear 120v outlets, Husky Floor and Cargo Mats, Wade Window Vents, Autovent Shade Bug deflector II, Modified Trailer Electrical Connection, Rear View Camera, Michelin LTX M/S2 285/70/17, Load Range D, OEM Hood Insulator. Blacked out front emblem, front, rear and side chrome strips, Blacked out and modified rear emblem, luggage rack and black OEM door handles.
Jtraskell is offline   Reply With QuoteReply With Quote
Gonna adjust the 5100s, 285s or 265s? Sonicpilz 4th Gen T4Rs 4 06-10-2011 10:46 PM
tires so torn. 285s, 265s AT or MT 4RunnerTrail 5th gen T4Rs 11 01-17-2011 01:29 PM
285s vinnysrunner 4th Gen T4Rs 7 10-03-2010 08:49 PM
OME + 285s? hulk311 3rd gen T4Rs 8 11-05-2009 04:31 PM
285s & a V6 ? ChipG 4th Gen T4Rs 2 11-20-2007 08:11 AM
