Old 04-13-2012, 07:30 PM #1
GrantK's Avatar
GrantK GrantK is offline
GrantK is on a distinguished road
GrantK's Avatar
Torquing locking lugs?
When I had my new rims/tires installed today I also had them install Gorilla lug nuts and locks. These are ALL spline cut, even the locks. The shop said they only torque the locks to 50lbs so the splines won't strip out. This doesn't seem right to me. I think they should be torqued to full spec, just like the regular lug nuts.
I'm going to contact Gorilla but wondered what others think as well.
This space for rent.
GrantK is offline   Reply With QuoteReply With Quote
Old 04-13-2012, 11:10 PM #2
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
Grant,
The formula for bolt Torque is simple:
T = K × D × F (short equation)
where T = torque, K = nut factor, sometimes called the friction factor, D = bolt diameter, and F = bolt tension generated during tightening.
In this formula "K" is probably the only thing that could change by using different lug nuts. It could be material, grade of material, actual strength of flats or splines, etc. You did not change studs so the nut is the determining factor. It could even be the yield strength of the nut.
While this formula above is simple, it is derived from more complex formulas and many different knowns go into the longer calculations such as thread pitch, joint type (lubricated or non-lubricated) effective seat area and on and on. Here is a link to an excellent article from machine design: A simpler way to predict bolt preload | Machine Design
on bolt preload.
I hope this helps you to understand why there COULD be a different torque spec as it depends on several factors. Now, determining if the new spec is right or not is a question only the manufacturer can answer.
1engineer is offline   Reply With QuoteReply With Quote
Old 04-13-2012, 11:12 PM #3
Mick1's Avatar
Mick1 Mick1 is offline
Mick1 is on a distinguished road
Mick1's Avatar
Post a picture of them so we can see how stout or fragile looking the spines are.
I previously had spline wheel locks and always torqued them the same as the others with no problem. The spines on mine were pretty good size.
RHINO
'11 Trail
http://rhino4runnersuspension.shutterfly.com/
Mick1 is offline   Reply With QuoteReply With Quote
Old 04-13-2012, 11:42 PM #4
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
That's a good question really as the stock nuts which are not conical are torqued to 82 ft/lbs but they are only a clamping force as the hub centers.
However,the conical nuts for aftermarket wheels are clamping and centering with friction between them and the wheel when tightening so you would think the torque would need to be a little more.
That being said....lol
I have had spline cut conical nuts on mine for over 2 years torqued to 82 ft/lbs and the wheels haven't come off yet and I've had them off and on at least 20 times with no broken studs or stripped nuts.Knock on wood!
When I have seen stripped spline nuts is when they use an impact to install them.Sucks even worse when they strip the special keyed socket with half the nuts off! Hand tightening with a 4 way lug wrench is the best and then bring them up to torque in a criss cross pattern.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 04-14-2012, 12:06 AM #5
GrantK's Avatar
GrantK's Avatar
I think I need to add a little better explanation...
As I mentioned, the shop only tightened the locking lugs to 50lbs, the regular lugs they tightened to 85lbs. All lugs are spline cut. The shop said they don't tighten the locking lugs to full torque to protect the splines from stripping.
All the lug nuts (regular and locking) are hardened steel and the only difference between regular and locking is the placement of the splines. I think the shop is wrong and that all the lugs should be torqued to the same value. I'm of the opinion that the splines won't strip (all the same material) and the different torque values could possibly cause the rims, or worse, the rotors to warp. Also, the lower torque value on the locking lugs could let them work loose and come off over time (not likely, but possible).
Old 04-14-2012, 09:20 AM #6
1engineer's Avatar
Moderator
Real Name: Greg
Moderator
1engineer's Avatar
Real Name: Greg
Sorry. I misunderstood.
Old 04-14-2012, 09:26 AM #7
GrantK's Avatar
GrantK's Avatar
Ain't no thing. It helps to be reminded of related info when working on things so I don't F'em them up beyond repair.
Old 04-14-2012, 09:43 AM #8
Gstick Gstick is offline
Gstick will become famous soon enough
Not to steal your thread GrantK, but what is the thread pitch & diameter for our wheel studs (5th Gen) ? I want to buy some Gorilla locks.
Gstick is offline   Reply With QuoteReply With Quote
Old 04-14-2012, 09:47 AM #9
GrantK's Avatar
GrantK's Avatar
Gorilla part #21631BC (12mm x 1.5, acorn style)
Old 04-14-2012, 09:49 AM #10
Thanks !
Old 04-14-2012, 07:15 PM #11
Marlin 444 Marlin 444 is offline
Marlin 444 is on a distinguished road
I have the gorilla locks on mine and put them on myself.
I used the lug wrench that came with my 4runner. Removed one lug nut and put a locking lugnut in its place. Nothing special.
I'm sure it isn't exactly torqued to 82lbs, but it as tight as I can get it and never had a problem with it. I check it every so often and I never had to tighten it yet.
To the OP - just make sure it is tight and you'll be fine.
Marlin 444 is offline   Reply With QuoteReply With Quote
Old 04-14-2012, 09:43 PM #12
||ReT4Ribution||'s Avatar
||ReT4Ribution|| ||ReT4Ribution|| is offline
||ReT4Ribution|| is on a distinguished road
OOPS...I have all of mine set to 90...
I would think as long as your lock splines are not just two splines and super shallow, they can take a full spec torque...
check your key, if you feel there is enough meat on the key, set the locks to full spec.
2011 Black on Black SR5
500GB Music Server~AVS Bugflector II~Wade In-Channel Vent Guards~TRD T-Case Knob~3M CS 20% Tint~Pilot Stuby Antenna~17x8 Matte Black Konig Countersteer Type X~265 GY Duratracs~Debadged~AFE Stage 2 Pro Dry S Intake~TE Roof Rack~Plastidip'ed Chrome~Weathertech Front & Rear Liners~Husky Cargo Liner~MOMO Shifter~RAM GPS Mirror Mount~More To Come...
||ReT4Ribution|| is offline   Reply With QuoteReply With Quote
Old 04-14-2012, 09:58 PM #13
Qjake's Avatar
Qjake Qjake is offline
Real Name: Billy
Qjake is on a distinguished road
Qjake's Avatar
Real Name: Billy
I would tend to agree that all the lug nuts should be torqued to the same ft lbs. The gorilla locks seem to be good quality and don't think you'd have any issues taking them up to the recommended 82 lbs.
Billy a.k.a. Q-Jake
2011 Limited MGM......My Build
Qjake is offline   Reply With QuoteReply With Quote
Old 04-17-2012, 08:09 AM #14
GrantK's Avatar
GrantK's Avatar
In case anyone was wondering... Gorrilla says to torque their locks and regular lugs to full spec.
Old 04-17-2012, 12:14 PM #15
bofa's Avatar
bofa bofa is offline
bofa is on a distinguished road
bofa's Avatar
I've had locks on most of my cars, usually the Gorilla style, although I got some different ones this last time. I always torque them to OEM spec. I've never had one strip.
bofa is offline   Reply With QuoteReply With Quote
center locking diff VS rear locking diff 410toy 3rd gen T4Rs 14 11-25-2015 12:55 PM
Daystar level installed...having trouble torquing Ricky Booby 4th Gen T4Rs 3 11-23-2009 01:39 AM
WTT 4 Locking Lugs , For 4 Standard Lugs. bgmac Classifieds - buy & sell (no commercial ads please) 2 10-06-2009 05:53 PM
5 Lugs vs 6 Lugs VQD83 4th Gen T4Rs 4 02-11-2007 05:41 PM
