01-04-2012, 08:54 PM
Tire rotation
I have the car for 2 years now, rotate the tires according the service books , but my spare is brand new!!! Last time i checked spare should be included in rotation, wright? What should I do?
01-04-2012, 09:23 PM
Your spare is most likely on a steel wheel that doesn't match.
08 G35x (mine/hers)
12 4runner Limited (ordered/mine)
08 Taco 4x4 TRD OR (hers/sold)
01-04-2012, 09:30 PM
There are people out there that do that and including the spare (5th) tire should result in increased overall tire longevity. Additionally that would also mean that you replace your spare along with the others when it's time so you end up buying 5 tires. I've never done this and probably will not start now. Short of buying a new rim, the steel rim on my TE would require me to remove it and mount on one of the other rims with each rotation. Simply not worth it to me. I do try to check the tire pressure on that spare every so often though and I do realize that over time that spare may get old, crack etc but seriously, I've never had that happen with other vehicles either.
01-04-2012, 11:29 PM
I believe the spare doesn't have the TPMS so the light will always be on if your spare is on.
2011 Silver SR5 4x4
01-05-2012, 01:18 AM
Well if they are going to swap rims (as i doubt he would run with a mis-matched rim) they will swap the TPMS as well. Now if he has a LE that would be different.
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
01-05-2012, 07:11 AM
Surely the LE doesnt have a 20" rim for a spare?
08 G35x (mine/hers)
01-05-2012, 09:27 AM
Real Name: Dave
Real Name: Dave
Has it been confirmed that the actual tire location matters in regards to TPMS? I'm thinking it does not.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
01-05-2012, 09:57 AM
Notwithstanding wheel matching or TPMS issues, it would seem to me that by rotating 5 tires instead of 4, eventually your going to have 2 tires that need replacement and 3 tires that can go another (X) amount of miles before you need a new one. If that is the case, then what are you going to do? Buy 2 new tires? Keep the 3 with x amount of miles left? Buy 5 new ones?
Let's say you have tires that normally would need replacement at about 50K and you rotate (for example only) every 10K miles. I see no benefit by adding the spare into the mix. Radial tires should only be rotated front to back, etc., keeping the drivers side tires on drivers side and the passenger side tires on the passenger side. So where you first put the spare, it will only be rotated on that particular side every 20 miles. So as I understand it, 3 tires on one side of the car should go to 70K miles. The 2 tires on the other side will still need replacement at 50K. I would simply rotate and use the 4 you have on, keeping the spare where it is.
2010 Salsa Red SR5, Black Power Leather Seats, Sliding Rear Cargo Deck, Luggage Rack Cross Bars, Black Pin Stripes, Black Body Side Moldings, Front and Rear 120v outlets, Husky Floor and Cargo Mats, Wade Window Vents, Autovent Shade Bug deflector II, Modified Trailer Electrical Connection, Rear View Camera, Michelin LTX M/S2 285/70/17, Load Range D, OEM Hood Insulator. Blacked out front emblem, front, rear and side chrome strips, Blacked out and modified rear emblem, luggage rack and black OEM door handles.
01-05-2012, 10:12 AM
Real Name: Ken
Real Name: Ken
Actually, it does. My LE has a 20" spare rim that matches the other, albeit it appears to be a different color. It also doesn't have the TPMS sensor. So, to rotate it in, I would still have to swap rims and TPMS each time. I just don't rotate the spare.
2010 Limited Magnetic Gray Metallic
with Navigation system
01-05-2012, 10:25 AM
The non-TPMS spare has nothing to do with "the light".
2010 Trail Edition with KDSS
DuraTrac 265/70R17E • PIAA 60XT Driving Lamps • Wolo Horns • Fogs-Enabled-With High Beams • Fumoto Valve
01-05-2012, 11:20 AM
That's right. It just doesn't have TPMS
2011 4Runner SR5 4x4, Black, Sand Beige Leather, 3rd row.
AVS Bugflector II, OEM Mudguards, SPAREBUMPER SP424 - Black, Infinity Kappa 32.9cf Dash Speakers,
GY Wrangler Silent Armor, 265/70R17, Load C, Weathertech side visors, Husky WeatherBeaters, ~16.5 MPG
01-05-2012, 01:32 PM
No TPMS on the spare?!? That seems incredibly cheap of Toyota. My Infiniti has all 5 monitored and good thing it does. My spare went low and on came the light. Words cannot describe how pissed I would be to need the spare only to discover its flat. Damn.
08 G35x (mine/hers)
01-05-2012, 01:47 PM
Real Name: Jordan
Real Name: Jordan
And my BMW didn't even have a spare, had to buy it seperately for $400 after I went to non run flats.
01-05-2012, 03:55 PM
I noticed that my BMW does not have a spare either and as soon as spring rolls around to these parts I plan on getting rid of those run flats that cause my teeth to rattle and ass to ache. So once you replaced your run flats, did you go with a full size spare? I have the Z4 and there is not much room in the trunk but they make a donut spare that comes with a jack kit etc for about $375 I believe.
01-05-2012, 04:39 PM
Our '07 Tacoma came with TPMS on the spare.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Tire rotation...
EDness |
4th Gen T4Rs |
17 |
08-13-2010 10:45 PM |
Tire rotation
JAC |
4th Gen T4Rs |
3 |
07-23-2009 10:58 AM |
Tire rotation
chunderboy |
4th Gen T4Rs |
17 |
05-01-2005 10:50 PM |
Tire rotation........
2003_4Runner |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
2 |
07-21-2004 06:07 PM |
Tire rotation
Larry |
Maintenance/Detailing |
2 |
02-21-2004 07:48 PM |
