04-04-2020, 04:05 PM
#42091
Real Name: Jim
Real Name: Jim
Originally Posted by pookguy
Got a smoked brake light off eBay. Quality is ok but the stock plug will absolutely not fit. I had to cut up the light to get it to fit.
I had the same problem. I gave mine to my son and it fit on his wife's 2019 Highlander. Go figure. I used tint spray paint on my stock one and it came out perfect.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
04-04-2020, 04:15 PM
#42092
I wanted the RED 3rd Brake light. Mine came OEM White!!Let me guess that light was from. CARID? Lumen(R) - Toyota 4Runner 2018 Black/Smoke LED 3rd Brake Light[]=SUBMODEL|TRD+Pro I can tell just looking at the connector. I had the same issue last summer. I bought it from there site WHICH Claims it fits 2018 4Runner NO It does NOT. I had to go through A LOT of BS to get my $$$ Back. I took pic of my OEM next to their's, it was SO obvious the connector was NOT close. I'll try to load the pics. I'm new to this site & not great W/adding Pic yet
Take Off You Hoser
Boston Bruins #1 2018 TRD OR Super White, Few Mods: Tinted Frt windows,Eibachs Set @ 0.85 up Frt, , Cooper Discoverer ST/MAXX 275/70/17 Interior LED's, H9 Lo Beams, Anytime LED Fog lights, Led Backup lights, CF overlays above Glove Box, Steering Wheel & all Door Control Panels to match OEM CF Center Console, Pro Grill, Fangs, Bruins on Startup Screen.
04-04-2020, 04:25 PM
#42093
Finally finished installing my LEDs from Arclightleds. They are ridiculously bright!
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
04-04-2020, 04:26 PM
#42094
Take Off You Hoser
04-04-2020, 04:27 PM
#42095
Originally Posted by hwnrunner
those jack stands look solid, what brand?
I believe they are ESCO, not the cheapest but they are well built.
04-04-2020, 07:07 PM
#42096
Installed my eibach lift! First time doing a lift. Wasnt too bad and KDSS wasnt too much trouble. About 4 hours for the fronts and 2.5 for the back. Got about 2.5 up front and .75 in the back which is perfect for having 200 lbs in the trunk right now and the bumper/winch.
Align tomorrow and check torque and its done!
Sent from my SM-G973U using Tapatalk
04-04-2020, 07:11 PM
#42097
Topped off the tank with $1.64.9 / gal regular unleaded.
04-04-2020, 07:12 PM
#42098
Banned
Real Name: Mark
Banned
Real Name: Mark
I’ve always had trouble seeing the HVAC position knob pointer in the shadows in daylight. So I added a little piece of yellow nylon tape at the end of the red indicator bar. Works for me!
04-04-2020, 07:19 PM
#42099
Mounted my sliders
04-04-2020, 07:32 PM
#42100
Originally Posted by TXTRDPRO
Mounted my sliders
Did the same today. Looks good!
04-04-2020, 08:08 PM
#42101
Changed the oil filter and install aluminum oil filter housing. Almost impossible to get the plastic one off. The process took a lot longer than I anticipated mainly because I had to loosen my custom bumper to access the skid plate etc. I will definitely be researching and considering getting the upgraded skid plate with the oil filter access panel.
I dropped the transmission pan and changed the filter and added new tranny fluid. I wasn't exactly sure of the torque setting on the tranny pan bolts so I did around 8 ft pounds based on a quick Google search, does that sound about right?
I used all Toyota brand oil because the dealer gave me 20% off. The tranny filter was a wix brand.
Sent from my Pixel 3a using Tapatalk
04-04-2020, 10:15 PM
#42102
04-04-2020, 10:40 PM
#42103
Real Name: Joe-Runner
N̶a̶h̶ ̶m̶a̶n̶.̶ ̶T̶h̶i̶s̶ ̶i̶s̶ ̶f̶r̶o̶m̶ ̶a̶ ̶T̶a̶c̶o̶ ̶f̶o̶r̶u̶m̶ ̶b̶u̶t̶ ̶i̶t̶s̶ ̶i̶d̶e̶n̶t̶i̶c̶a̶l̶ ̶t̶o̶ ̶o̶u̶r̶s̶.̶ ̶Y̶o̶u̶ ̶n̶e̶e̶d̶ ̶a̶ ̶f̶e̶w̶ ̶m̶o̶r̶e̶ ̶l̶b̶s̶ ̶o̶n̶ ̶t̶h̶a̶t̶ ̶w̶r̶e̶n̶c̶h̶ ̶[̶e̶m̶o̶j̶i̶1̶2̶]̶
DIY: Full Flush for Automatic Transmission | Tacoma World
Correction: you were talking about the pan, I'm an idiot, my bad. He torques the pan at about 16 mins on this video. I just asked him what he torques it to. Maybe someone can quote some service manual.
https://www.youtube.com/watch?v=PPhiIxs0VQM&feature=youtu.be
2021 ORP, Naut Blue, sunroof, Gunmetal TRD wheels w/265 Falkens, NFAB steps, 1.75" 5100s front, 1" Cornfed spacer rear / 2̶0̶1̶3̶ T̶r̶a̶i̶l̶, K̶D̶S̶S̶, / 2̶0̶1̶7̶ O̶R̶P̶
https://badges.fuelly.com/images/sig-us/1038471.png
04-04-2020, 11:36 PM
#42104
Thanks for the great youtube video. I don't know how I would survive without YouTube lol.
I found this during the search in the forum and maybe it helps somebody else out in regards to transmission pan bolt torque.
Seems like other people are torquing it to 62-in pounds which equates to roughly 8-ft pounds. I guess that's all that's needed.
transmission pan bolt torque specs
04-05-2020, 01:44 AM
#42105
Drove to Belmont Mountain.
