07-16-2020, 10:53 PM
#43711
Installed our SSO Hybrid Bumper + Winch + Light Bar.
Some install notes: - We installed the smittybilt winch with the solenoid on the side. No clearance issues there.
- We needed bolts for the Rigid light-bar that were about 1/4 inch shorter than those supplied with the light-bar. (the only needed trip to the hardware store for this project).
- The ears for mounting the light-bar in the bumper were bent outward a bit, and even when bent back to perpendicular were still spaced too far apart. Used extra bracket material as a spacer.
- Not sure if this is specific to 2020 versions, but the attachment point for the top part of the wheel-well fascia is a different type than the clips below. Before trying to pull of the front fascia you need to lift it up and around the small black plastic protuberance.
- 2020 4Runners have to disconnect the TSS module wiring and two bolts in the center of the engine compartment in front of the radiator.
- The lower brackets look like they are pushing the fascia out and forward.
- The bull bar for the 2020 seems high enough to not interfere with the TSS in my limited driving so far.
I'll chat with SSO about possibly updating some of those points in their install notes, and see if they can guide me as to what is off with the lower brackets.
But the end result sure is good looking:
07-17-2020, 12:21 PM
#43712
Real Name: Dave
Real Name: Dave
Originally Posted by Blue 4ever Runner
Gorgeous! I wish there was something like this near me. NY just doesn't have this kind of stuff.
Yes, but you have TREES! Unless you live in NYC. Then you have deep man made canyons. Used to enjoy the views from the top floors of the Trade Center while wishing to be back home; used to work for a company who headquartered there and would be in the city a few times annually. The view north from the office level was if you were looking down onto deep canyons.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
07-17-2020, 01:38 PM
#43713
Real Name: Jim
Real Name: Jim
True but we also have over crowding that's horrible but you know that if you worked in Manhattan. The view from the Towers was pretty amazing. I worked in a few buildings over the years including the UN for 25 years and for a year in
the Deutsche Bank Building across from the Trade Center that was heavily damaged on 9/11 and had to be demolished. I love up state NY but the taxes etc. here are ridiculous. I'll be moving to NC soon to get away from this state that once was actually nice to live in. Sorry, rant over lol.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
07-17-2020, 08:26 PM
#43714
Real Name: Luke
Real Name: Luke
Finally started wiring the aux fuse block. I managed to cuss, swear, and sweat just fine. Really though, I mounted the circuit breaker and ran the positive wire all the way to the fuse block. In the process of attempting to crimp the first ring terminal onto the 6 awg wire I destroyed it. So I didn't have enough connectors to do the negative wire. Next time I'm out I'll grab some, and some more for the upcoming accessories too.
07-17-2020, 11:59 PM
#43715
Real Name: BobH
Real Name: BobH
Thursday
Went to Sandlake dunes south of Tillamook, Oregon yesterday, no problem keeping social distances. Rented a quad and took our new R/C truck, Traxxas E Revo 2 VXL. It really will do 50 mph. Good area for dirt bikes and quads, fair for full size trucks. Two big bowls with narrow clearance on the sides to get by. Leaned this after having to turn down to the bottom due to sliding sideways for a while.
____________________________
07-18-2020, 03:33 AM
#43716
Changed low beams to LED Morimoto 2stroke 2.0
Im used to HIDs in my previous cars. these LEDS seems like the best bang for the buck. going to convert the rest of the fogs, highbeams and other interior lights to LED soon.
07-18-2020, 01:42 PM
#43717
Baja Designs S1 in tow hitch, wired to 7-pin trailer plug to trigger when in reverse.
07-18-2020, 02:02 PM
#43718
CarTrimHome flip key. Key cut at hardware store, then swapped transponder from original G key using heat gun and xacto knife to loosen glue (you do not have to destroy original key if you go slowly and use heat). Wrapped in gloss white to match Super White.
07-18-2020, 02:09 PM
#43719
Baja Designs S1 pods mounted behind grill with Trigger ONE bluetooth relay to allow dimming. Mounted to 1/4" thick aluminum plate, drilled to accept original Baja mounts and bolts to stock grill mounting locations. Wrapped plate in gloss black to match TRDP grill valance. Can act as 'raptor lights' when dimmed, but provide a significant lighting boost when fully powered.
07-18-2020, 02:39 PM
#43720
Interior LEDs are fine as they don't really need to project distance. As for your headlights, I recommend staying far away from LED bulbs. I had those exact ones and they are poorer performing than stock. Here is a review showing why:
3rd Gen HID vs LED vs Halogen H11 projector headlights | Page 106 | Tacoma World
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
07-18-2020, 02:42 PM
#43721
Nice work! Is that a MESO customs part or did you make it yourself?
Nice. I also used those grill locations for auxiliary high beams. The dimmable option is a great touch.
-Tory
07-18-2020, 02:48 PM
#43722
Thanks for the kind words. The reverse light and grill lights are DIY. Used a Curt 58140 Trailer-Side 7-Way Harness to create a custom plug and avoid running wires to the engine bay. Just wire up the harness to the light and plug in. No cutting/splicing of stock wires necessary. It's easily removable, but neither the plug nor light will fit through the tow hitch, so removing wiring from plug is necessary for removal. Could easily wire a small plug inline to make removal even easier.
07-18-2020, 02:52 PM
#43723
Banned
Real Name: Mark
Banned
Real Name: Mark
Great idea. Did you use the Spot, Cornering, or Scene version? Can you post a night photo? Thx.
07-18-2020, 05:18 PM
#43724
I used the wide cornering initially, and the throw was excellent, but it did not illuminate the periphery to my satisfaction. I switched the lens to a scene/work lense and it is much more diffuse light and seems to have a wider spill. I’ll try to grab some night shots tonight for you.
07-18-2020, 06:08 PM
#43725
While waiting for my lift/tires (seems ARB can't get product here in a reasonable time ) I decided that I didn't like the OEM wheels anymore. I thought they would grow on me but they never did. I like the wheel style and but I just couldn't stand so much shiny steel all over them. I was on the fence with Plasti Dip or powder coating or just buying new wheels until I ran into these. I like how it turned out. Easy going on and if/when I get some trail damage I can just remove and replace.
It's subtle but I think it makes the OEM wheels pop a little ...
