11-25-2020, 03:24 PM
#45031
Banned
Real Name: Tobias Fünke
Banned
Ordered and mounted in less then 5 days.
11-25-2020, 07:02 PM
#45032
I finally ordered & received a set of the Toyota OEM/Chinese LED fog lights and installed them today
Jim _ My Adventure Blog: http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
11-25-2020, 07:06 PM
#45033
Originally Posted by WMims
...and they'll fit on my stock TRD wheels...hmmmmmmmm
Originally Posted by DannyLlama
Why do I find out about this stuff right after the installs!
Oh well, I like the look for now.. Haven't taken them off toad yet. I'm hoping they at least perform better than the Toyos
I am at a little over a year with my 255's and I love them. I highly recommend them, especially if you are concerned about mileage and power.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
11-25-2020, 07:10 PM
#45034
Swapped the TRD Pro 4Runner 3x13inch springs, and took out the ToyTec 1inch perch for TTUE FJ TRD 3x14inch 600lb springs. Gained an additional .75inches of lift. After research, and talking with some members here, I found out the old setup wasn't really giving me a 2inch lift. Now after the swap my measurements make sense, and is about 2.25 front lift now
Top picture is before, bottom is after spring swap
Very happy with the look, and surprised by how much better the ride is
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
11-25-2020, 08:42 PM
#45035
Noticed what appeared to be water marks on the headliner after driving through a rainstorm. Can't yet tell if the rack is leaking or my son somehow got it wet when he was taking his jacket off and playing in the back.
Panic ensued so I took a garden hose to the potential problem areas and let it go full blast to see if that would exaserbate the issue.
No sign of water intrusion and the spots are nearly gone now, but I'm not 100% convinced yet that I don't have a big problem on my hands. Time will tell.
2020 TRD ORP XP Predator - Classic Silver - 265/70R17 Nitto Ridge Grapplers - Moonroof - Sliding rear cargo tray - Dual front USBs
Mods in order of install: Screen protector, Badge delete, Pin stripe delete, Husky floor liners, Center console organizer, Predator step delete, Kicker dash tweeters, Prinsu full no-drill rack, Toyota rock rails, Low profile rain guards, Interior, reverse & turn signal LEDs, Lasfit Pro LED low beams
Awaiting: Roam 5ft awning
11-25-2020, 09:40 PM
#45036
What kind of rack do you have, and how did you seal it? Aftermarket rack manufacturers are rather famous for vague instructions on how to seal the roof rack. If they address it at all, it's usually just "find a tube of silicone goop at a hardware store" which, as it turns out, is not a great way to seal holes in a vehicle roof.
Another place to check is behind your front kick panels (the plastic vertical interior walls next to your pedals). Water tends to run down the door seams into these pockets, which can lead to some pretty nasty corrosion of important wire harnesses and connectors (some of which can immobilize or limp-mode your truck).
See the story at Trail4Runner here. The author goes through a bunch of diagnostic checks, but ultimately it was found to be corroded connectors due to a roof rack leak.
Limp Mode on 5th Gen 4Runner & Zero Point Calibration (SOLVED)
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
11-25-2020, 10:01 PM
#45037
In addition to the Tory said, check your sharkfin antenna and the rear of the headliner... The seal around mine was f*cked and the fin itself was warped upward slightly. During a particularly rainy day I noticed a puddle of water in the rear trunk area and looked up to find the edges of the headliner wet from the rear all the way to around (both sides) to the passenger doors. I did an emergency silicone job and duck-taped a plastic bin over the sharkfin to cover it overnight while the silicone dried.
Next couple of days it was a warm sunny so I kept the windows cracked and ran a fan in there, dried everything up no problem. Did some research and ordered a used tacoma antenna that matched my paint color and installed it. Problem solved.
Anyway, best of luck finding the leak, it definitely sucks having to deal with water inside the vehicle. :/
Here are some pics:
Note the drops of water forming under the antenna nut and connection...
Had to do the silicone in the rain, huge PITA...
To keep the rain off the silicone overnight and hope the wind didn't blow it off:
Rode around like this for about a week, ghetto but it worked like a champ. There is extra in the front because the sharkfin was sort of warped up from sun damage I assume...
And for the record... this is what was inside the nearly empty shell of a stupid sharkfin on mine:
Installed the tacoma antenna with some fresh silicone to ensure it never leaks again
Looks factory!
[ Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
11-26-2020, 01:50 AM
#45038
Real Name: BLACK TRD PRO
Looks good! Looks like a lifted 4Runner now. I need to keep this setup in mind down the road. Did you add a spacer back upfront to to the 3x14" springs? Also, what did you do in the rear?
11-26-2020, 02:38 AM
#45039
Thanks to you and others I talked to. Haha. Made me realize something was up. Removed the ToyTec 1inch perch spacer, and put back the stock perch, so no more spacers. The front now is stock TRD Pro Bilstein setup + FJ 3x14inch spring which gave me about 2.25 - 2.5inches of total lift for a non-Pro trim. I have Bilstein 5160s in rear + Eibach 1inch lift springs.
After I upgraded to 285\70\17s it totally looked like a stock Runner witt no lift in pictures. Haha, now it looks like it's got a lift again
11-26-2020, 10:11 AM
#45040
nice man. beefy af. i'll flip you off and t bone you next time i see you lmao
11-26-2020, 11:46 AM
#45041
Polished and ceramic coated the entire truck for the first time yesterday. I do not think it has ever been this shiny or clean before lol.
My goose gear plate and mlv also came in the mail! Waiting on some closed cell foam, then can begin that project.
2013 Classic Silver TE w/ KDSS - 125k miles
Raptor lined bumpers, fender flares, valences, badges | Goose gear plate | Sound deadening | Hood scoop delete | Tundra fogs | H9 + 9011 bulbs | RCI Skids | Dobinsons C59-300 and C59-599 | Ironman UCAs | 285/70/17 Maxxis Razr ATs
11-26-2020, 03:24 PM
#45042
Here are some pics:
Looks factory!
Wait, what!? Why is the shark fin so much bigger than it needs to be then? Is there metal in the larger fin acting as some larger antenna/amplification?
11-26-2020, 03:29 PM
#45043
Banned
Banned
Just be sure to bend the frame ;)
11-26-2020, 03:43 PM
#45044
00-JZX100
10-Trail Ed.
11-26-2020, 06:04 PM
#45045
Real Name: Joe
Real Name: Joe
Originally Posted by s13koop
Scored this one owner '10 Trail. Sold my '88 and needed something a bit more modern.
Its been a fun 2 weeks with a few aesthetic fixes. One being the decaying clear bar and faded headlights. A trip to Toyota for some OEM's worked out nicely. After some trial and error I finally got the bra and adhesive off without scratching the paint. Go this stuff was everywhere, hood, doors, door trim, under the handles.
Got some more upgrades coming for this weekend's camping trip to Hidden Falls
I have the same bad clear bra on my ‘ 06. What did you do to remove it?
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
