02-02-2023, 08:59 PM
#49426
Originally Posted by Lexington
Very nice! How do you like the lighting on that?
I've been pretty happy so far. I was running XD LED bulbs in the stock housing before which was an upgrade over stock but still didn't provide great lighting.
This is a night and day difference.
2020 ORP - Dobinson's 302/505, JBA UCAs, 5100s, Cooper AT3 Discoverer XLT 285/70/17
4Runners and Dobermans - https://www.instagram.com/derpydobies
02-03-2023, 09:03 AM
#49427
Originally Posted by TRDHULK
Switched from 315/70 KM3s to 35x12.5 KM3s recently
The tires are definitely 'beefy' but what the heck are you doing to your rear quarter window???
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
02-03-2023, 09:55 AM
#49428
Originally Posted by MtnMike
Installed my "not-pointing-at-the-ditch" lights. Got 'em pointing straight down the trail with spot lenses. All the other lights on the truck give me plenty of flood; I needed something with some reach.
Yes, these are DD SS3 pods, and the keen-eyed observer will notice they are indeed mounted upside down. Necessary for the way I wired them, but with spot lenses, running upside down isn't an issue.
Also yes, the hood opens fine. I get a nice gentle arc in the wire loom, and the connector doesn't contact the windshield.
you could rotate the lense/bezel if it bothers your OCD. looking good tho. I'd love some XL80's in that same spot for the same use. higher up long range lights.
02-03-2023, 09:56 AM
#49429
did you even offroad if you didnt stick a go pro to your window and post it on the instagrams???????
02-03-2023, 12:44 PM
#49430
I guess posting dash cam video just doesn’t cut it anymore? Lol! I have a few hours of video that I can delete now.
02-03-2023, 07:39 PM
#49431
Changed oil/filter, front diff and transfer case fluids. Man i hate the front factory skid plate!!!
I also changed the spark plugs.
Sent from my Pixel 6a using Tapatalk
02-04-2023, 02:17 AM
#49432
second hit n run
My demello bumper has paid itself in full, after 2 hit and runs. Best investment ever!!!!
Only damage is some cosmetic powdercoat on the bumper, shackle mount, shackle, and fairlead.
Damage to other vehicle..BUAAHAHAHHAAHAHAAHA...
I wish i had pictures, but they took off. First time was a little honda civic, and it ruined their bumper, and their tail light.
This time around, some white, old nissan of some kind, took out his entire rear passenger door and rear fender....
All i need is some spray paint n good as new.
02-04-2023, 07:16 PM
#49433
tire carrier safety pin latch upgrade
Accessorizing the accessories!!!!
Since i sheared off my safety pin a few months back on my tire carrier, I had the sheared safety pin sitting on my work bench. I also happen to have a lathe handle sitting nearby from a previous project and decided to put them together.
On the shrockworks bumper, the T handle on the safety pin was captured in between the swing arm bolt and tire carrier tube.....which means..u can only come down from the top and doesnt clear the big swing arm bolt.
The lever handle improves things, you don't have to come down from the top, it also free spins, so you can disengage the pin from different sides of the tire carrier and has more leverage., Also, it happens to be red.... extra 5+HP.
02-04-2023, 08:37 PM
#49434
Real Name: BLACK TRD PRO
Wow. You have a fully armored, accessorized Panzerkampfwagen in gray.
02-05-2023, 11:45 AM
#49435
After almost two years of ownership, I found out I have remote start! Bought the Accessorides remote start to install. While searching YouTube for as many install videos as I can find, I find a dealership explaining which models have remote start from the factory. He explains that if you have the JBL system, then you have remote start. Are you kidding me? Immediately went out to try it and sure enough, started right up!
I asked the salesman when I picked it up and they told me only the Limiteds have it. Why do I ever listen them? I went two Chicago winters not knowing. Couldn’t feel dumber …
2021 TRDP
02-05-2023, 03:43 PM
#49436
Picked up a new toy
Triumph thruxton r
Also used the anytime backup camera to admire her while going dow the road
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
02-05-2023, 07:45 PM
#49437
Real Name: Mark
Real Name: Mark
So, I did a thing today...
I replaced the stock speakers in my 2011 Toyota 4Runner SR5 with Kickers all around then bypassed the hatch speakers so the Rear speakers would work again without PM. Then installed some soundproofing to kill the road noise.
Speakers:
Kicker 47KSC6504
KS Series 6-1/2" 2-way car speakers - Rear door
Kicker 46CSS694
CS Series 6"x9" component speaker system - Lower Front door/Dash tweeters
2 Crossovers
Soundproofing:
Epakh 240 Pcs Square Double-Sided Tape
Artilife Closed Cell Sponge Foam Rubber Sheet Roll, 1/8" T x 17" W x 80" L
Siless 50 mil (1.3mm) 52 sqft Car Sound Deadening mat - Butyl
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
02-05-2023, 11:17 PM
#49438
Semi finished up my drawer system. Just need to paint it with deck paint or something. Pretty happy with the fit and finish considering I’m a newbie at this.
I started with covering the floor with Amazon brand sound deadener. Then used some existing mounting points to secure the base and built the enclosure up from there. Once I got the drawer slides in I was able to make the actual drawer and toss everything together.
02-06-2023, 12:46 PM
#49439
I hope your door actuator motors don't give out any time soon (I've gone through 3 or 4) - peeling back the sound deadener on the vapor barrier to access them is gonna suuuuuck.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
02-07-2023, 03:17 AM
#49440
Window Stops
Random. I have a 2019 ORP and when I close the driver's window on auto and proceed to close the door midway, the window stops moving. It happens to the passenger side as well, but not the rear windows. Is this normal or is something wonky? I still have autonation's limited warranty so planning to take it to the dealer if not normal.
