02-07-2012, 12:44 AM
#16
The dealer has taken the 4 runner all down to the lowest setting and the issue went away we currently have it back to the second setting on the front strut. I have not had any issues yet. The stock springs are also back on the rear. From what we can tell the yaw sensor is getting out of it set parameters and that is what was causing all of the issues. My 4 runner looks wounded at its current height so much so that my 4 year old told my wife that we no longer have a monster truck. But the family is safe. I will keep you updated.
02-07-2012, 12:49 AM
#17
Originally Posted by Rayb
... My 4 runner looks wounded at its current height so much so that my 4 year old told my wife that we no longer have a monster truck. ...
that had to hurt hearing that.
2010 Mag Gray Trail Edition
Good Year Wrangler Silent Armor | Scuba Mod | Removed Rear Cargo Stop | THULE xb-16s | Yakima FatCat 6 | Canvasback liners | FIAMM El Grande's | Blacked Out Badges | AVS Bug Deflector II | AVS Rain Guards | Aries Offroad Grille Guard | 4x ARB IPF968CSG | 42" curved LED light bar | N-FAB nerf steps | DAYSTAR Rocker Switches RED and BLUE |
02-07-2012, 06:31 PM
#18
I just had 5100's set at 2.5" installed with rear 1.5" lift coils in the back, I made sure the dealership had their head Toyota tech put the stuff on. So far so good no issues.
02-09-2012, 12:03 AM
#19
May be my issue is that I did the 2.5" and have 2" rear springs so my ride rake is messing with the yaw sensor????
02-09-2012, 09:16 AM
#20
Ya maybe I actually ended up with just a bit of reverse rake, when I took it in I told them about this all they said is after it was installed they would wait to see if any lights came on but they never did. I think that they might have hit one of your sensors on the install or one possibly went bad, but then again you said it was fine once you lowered it. I hope everything works out for you.
02-15-2012, 11:02 PM
#21
got it back and it is doing good. we are at the 2nd from the top position with the stock rear springs. so we will wait and see. my 4 year old says it a monster truck again so he is happy.
02-16-2012, 01:24 AM
#22
Installing my Bilsteins and 2 inch lift rear springs this weekend, esentially the same setup as you. I hope I dont have any issues. I will post my out come and final settings. I am installing 285/70/17 Duratracs.
2010 Trail Edition, Magnetic Gray Metallic, KDSS, Seat Heaters, Infinity Kappa 32.9cf, Bilstein 5100s front/back set at 2.5", Toytec superflex rear coils 2", Goodyear Duratracs 285/70/17, Viair 300P Air Compressor,Cobra 75 WSXT, 10LB Power Tank, RockyRoad Supersliders
Mijfwb23's Build Thread
02-16-2012, 08:31 AM
#23
Nice! I'm glad it worked out for ya.
02-16-2012, 10:00 PM
#24
I put the 285/70/17 Duratracs on but they rubbed too much so I went with the 265/70/17 and they still rubb but I still have a little more trimming to do. Hope you don't have the issue like me, I love the lift, ride, look and clearance it is perfect for us.
02-17-2012, 10:37 AM
#25
Registered User A.K.A. "elias"
Interesting thread. Been keeping up with it. Hope all works out for everybody. I am subscribing since I too want a lift similar to the OP's and am interested in any news!
[SIZE="1"]2010 Black TE*ATX American Racing Ledge*GY Silent Armor "C" Tires*GoRhino RearStep*Husky Liners*Gladiator RunningBoards*AvicX920BT*Custom storage box with sliding drawer*Magnaflow 12586*aFe Pro-Dry S AirFilter*Custom Aries GrillGuard*Yakima Megawarrior*Hella Fogs
02-18-2012, 09:38 PM
#26
Finally installed my Bilstein Height adjustable front and matching 5100 Rear shocks, Rear 2 inch lift Toytec superflex rear coils. Took it to Firestone and had the alignment c/w. It rides great so far and I got lucky and didn't get crazy dash lights. My front is sitting at 37.5" both sides and my back is at 39.5" both sides. Figured with the front shocks set to 2.5 and the rear 2" rise coils it would be closer to level but I guess not. Install was easy except for the KDSS, which made everything just a tad tougher.
Reason: Got tires installed, still no dash lights
09-08-2013, 07:04 PM
#27
Ok so here is an update. After we put the stock rear springs on and set the front to the 2nd position on the shocks we have not had any issue that I know of. The issue is if we load the back with gear we have so much sag in the rear end the lights blind other drivers. I had a wild hair and asked the shop to reinstall the 2" springs and the issue came back. So they adjusted the front up to see what it would do. If you click the link you will see the issue. Any ideas?
https://www.youtube.com/watch?v=kco0...e_gdata_player
09-08-2013, 07:18 PM
#28
Real Name: David
Real Name: David
That's due to a bad zero point calibration. Quit accepting that the same dealership that has done it wrong multiple times is resetting it properly. Take it somewhere else or do the zero point calibration yourself (I know you can manually reset on Tacomas, assume you can on the 4Runner also).
I've lifted 3 different Toyotas (2 Tacomas, 1 5th Gen 4Runner), 3 different ways - never had that problem. The shop that does the install is resetting the zero properly...
Take it somewhere else.
David
09-08-2013, 07:45 PM
#29
Thank I think this is the info I was looking for.
09-08-2013, 08:20 PM
#30
Banned
Banned
you issues started back on post one of this thread: YOU TOOK IT TO A DEALERSHIP! They dont know what the fug they are doing.
