Old 02-10-2012, 12:07 AM #1
RiDE's Avatar
RiDE RiDE is offline
RiDE is on a distinguished road
RiDE's Avatar
Question Lifting a LE
Yes, i've searched almost every LE lift thread but I couldn't find a definitive answer.
I'm looking to install a spacer lift on my LE and i'm stuck between the Toytec Spacer lift with rear coils or the Daystar Lift kit.
Toytec- 3" front / 2" rear - $320 shipped
Daystar- 2.5" front / 1.5" rear - $135 shipped
Is the Toytec kit going to be worth the extra $200 for the .5" front and rear? What is involved with the install since I do have x-reas? I do not tow often and am just getting into OR. I'm mainly lifting for extra clearance. I do have a Shrockworks front bumper arriving in the next couple months and will try to fit 34" or 35's with the gained clearance.
I would go with a full CO setup but I do not want to scrap the x-reas system so soon. Seams wasteful.
Should I go with Toytec or save a couple hundred and go Daystar? Your thoughts? TIA!
IG: RiDETEQ
RiDE is offline   Reply With QuoteReply With Quote
Old 02-10-2012, 12:40 AM #2
Wakeborder556 Wakeborder556 is offline
Wakeborder556 is on a distinguished road
I think if your going to do it, do it right
Wakeborder556 is offline   Reply With QuoteReply With Quote
Old 02-10-2012, 03:26 AM #3
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
With the added weight you are going to want the front to be easily adjustable, ie coilovers. That front bumper is going to be heavy and will bring the front end down with just a spacer, which arent ment to hold extra weight.
I would go with a full CO setup but I do not want to scrap the x-reas system so soon. Seams wasteful. Sell it!
Should I go with Toytec or save a couple hundred and go Daystar? Your thoughts? TIA! If I end up going wheeling this weekend with you guys hop in my truck for a bit and you will be getting coilovers.
Originally Posted by Wakeborder556 View Post
I think if your going to do it, do it right. Agreed, learned this by modding other vehicles suspensions. Do it right do it once.
My recommendation would be to definitely get coilovers, which ones that is up to you after you research. I too originally only planned on getting spacers but then figured I would be adding weight as you are going to be. Remember you ordered a bumper and skids. I knew with the weight the suspension will settle a little lower and would need to raise it back up to get the lift I desired. Oh and the coilovers come assembled so there is less work to install. I feel as though I am rambling at the same time brain dead. If I am not there on Saturday be sure to talk with everyone about lifting and get their opinions.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 02-10-2012, 04:58 AM #4
RiDE's Avatar
RiDE's Avatar
I know it's best to do it right the first time. It's how i've done it with most of my cars but I just can't justify scrapping a perfectly good x-reas system. Plus I do like the way the LE drives with the x-reas. I've been tossing around the idea of swapping it all over for either Icon stage 2, OW w/ LR UCAs, or King w/ LR UCAs. The good thing is I do have 3 months to decide since the SW bumper won't be in for a while. That should give me enough time to beat up the stock system. On the other hand, a $130 lift compared to a $1700- $3000 lift can't be that bad of a mistake if i'm not going to do it "right" the first time. It's a relatively small investment with not much to lose. I think I may have just answered my own question. Thanks guys.
IG: RiDETEQ
Old 02-10-2012, 10:59 AM #5
2011T4RLE's Avatar
2011T4RLE 2011T4RLE is offline
Real Name: Joe
2011T4RLE is on a distinguished road
2011T4RLE's Avatar
Real Name: Joe
Unless you also want to install 4:56 gears you do not want to go with 35 inch tall tires. To fit 35's you will need more than a 3 inch lift as well. Also, if you are going to get that bumper you need to avoid spacer kits altogether. You are going to need more spring rate up front to compensate for the weight.
-2011 4Runner LE - ARB Deluxe Front Bumper - Apex Overland Dual Swing-Out Rear Bumper -Shrockworks Rocker Covers - RCI Sliders - Total Chaos Upper Control Arms - Dobinsons Extended Travel Front - Dobinsons Long Travel Rear - Dobinsons Adjustable Rear Control Arms and Panhard - Metaltech Extended Brake Lines - LFD Offroad Wide Engine Skid - Orangeboxx Fabrication PSD Racks - Gobi Stealth - Dobinsons Awning -17x9 Fuel Warp Wheels - 305/70/17 Kanati M/T - EIMKeith PCK - Apex Overland Auxiliary Lighting
2011T4RLE is offline   Reply With QuoteReply With Quote
Old 02-10-2012, 11:05 AM #6
phillyd2's Avatar
phillyd2 phillyd2 is online now
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
phillyd2's Avatar
Real Name: Dave
Seems wasteful to scrap the factory bumper so soon.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is online now   Reply With QuoteReply With Quote
Old 02-13-2012, 01:43 AM #7
Keemonrunnin's Avatar
Keemonrunnin Keemonrunnin is offline
Keemonrunnin is on a distinguished road
I had spacers at first. As I started going offroading, I just didnt like the thought of over extending the shocks. So I went with icon stage 2. I'm very happy with it. Since you're gonna get a front bumper, I suggest a full coilover. Who knows since you'll have the bumper off already, might as well through on a winch. Good luck with your choice
2010 LE 4wd Mag Gray Met|tinted front windows 20%| Fuel Boost 18x9|Nitto Ridge Grapplers|285/65/18|Icon stage 2|Demello kick out sliders|SW bumper oval drl|luminic yellow fogs|H9/9011HIR headlight mod|Grill craft w/Toyota emblem|AFE cai|Magnaflow 12256|TE roof rack|stubby ant|cargo door emblem blk/silver|Icon shift knob (short)|weather tech floor mats|Led interior light kit,icon expedition springs,cbi rear bumper w/swing out|ARB onboard air|.
https://www.instagram.com/kymzrnr/
Keemonrunnin is offline   Reply With QuoteReply With Quote
Old 02-13-2012, 01:52 AM #8
RiDE's Avatar
RiDE's Avatar
Going full CO's this week. Xreas will be pulled out.
IG: RiDETEQ
Old 02-13-2012, 03:21 AM #9
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
Originally Posted by Keemonrunnin View Post
I had spacers at first. As I started going offroading, I just didnt like the thought of over extending the shocks. So I went with icon stage 2. I'm very happy with it. Since you're gonna get a front bumper, I suggest a full coilover. Who knows since you'll have the bumper off already, might as well through on a winch. Good luck with your hoice.
Good luck with your Hoice too Keemo
DannyLlama is offline   Reply With QuoteReply With Quote
Old 02-13-2012, 07:28 PM #10
Fixed
4runner , 5th gen , lift , limited
help lifting 3rd gen MIN2187 3rd gen T4Rs 6 08-08-2011 08:46 AM
Lifting the FJC way sheik Engines / Suspension / Wheels / Tires / Audio / Accessories 5 05-26-2010 12:29 AM
lifting a 2nd gen help? 4Runner8 Classic T4Rs 29 04-08-2010 05:25 PM
Lifting a 1st gen what do i need? Iroke17 Classic T4Rs 7 01-11-2010 12:07 AM
Lifting. 94Beast4Runner Classic T4Rs 0 10-07-2009 06:35 PM
