Old 02-25-2012, 10:55 PM #1
ArcticEd ArcticEd is offline
ArcticEd is on a distinguished road
Jack Stand Paranoia & Lift Questions
I just got the OW 2.5" kit and intend to install it tomorrow. I've done plenty of work on cars over the years but never suspension and never on a truck this big (last vehicle was a CR-V). I've read the instructions and the RM so much I can almost draw it and am looking forward to the challenge.
I've had a 4-ton Craftsman floor jack for some time and have 4 6-ton Torin jack stands. I know these are fine from a capacity standpoint, but after doing a dry run of getting the front up on stands today I guess I'm a little paranoid:
1) The top of the jack stands aren't quite wide enough to straddle the frame, so it doesn't sit in the cradle - just the points. Is that an issue, and if so what do you do about it? I read a post where someone used hockey pucks to fill in the cradle, but we don't have a lot of those laying around in FL. I gave it a couple of good shakes and it didn't seem to move, but it just doesn't look as solid as I'd like it to.
2) With only one end up it doesn't sit completely flat on the stands due to the angle. Any concerns about it sliding forward/backward or the stands moving when lifting up the other end? I'm assuming I don't want to raise the back significantly higher than the front to avoid having it slide forward on the stands, but I also assume you'd have to raise it SIGNIFICANTLY higher than the front for that to happen.
3) I used the cross-member to lift the front and could swear I got the floor jack right in the middle, but the passenger side came up almost a full inch higher than the driver's side - is that normal? It settled on the stands fine but seems strange for it to lift "crooked".
A few lift-specific questions:
1) Anyone have a general idea of how high you need to get the truck for a 3/2 lift? I got it up to the 6th notch on the stands (20.5", see paranoia above) and there seems to be plenty of room for the front, just curious if that would seem to be enough. My tires are still stock.
2) Is there any trick to getting the UCA bolt out? A quick look makes it seem like there wouldn't be enough space but I've never heard anyone talk about problems either. I'll be putting on the Light Racing UCA's in addition to the 2.5" kit.
3) Any other trouble points I might expect and prepare for?
TIA for the time!
Chris
2010 Mag Gray LE; Overland Warehouse 2.5" kit; LR UCA's; hard-wired radar detector; 17x8.5 MB Torque Wheels; 285/70/17 Duratracs (all 5); Bud-Built Bump-out Sliders 1/3 plating; WeatherTech Digiliners
ArcticEd is offline   Reply With QuoteReply With Quote
Old 02-25-2012, 11:53 PM #2
KCcarguy's Avatar
KCcarguy KCcarguy is offline
KCcarguy is on a distinguished road
KCcarguy's Avatar
I'm no expert, but here goes
[B
My jackstands weren't wide enough. I just centered them and went for it....I also have a habit of putting the wheels/ tires under the truck as a "back-up"[/B]
I only raised one end at a time (opposite end chocked). I think it's safer
I raised right and left sides separately and used the frame not the crossmember
Just raise the tuck until the tires no longer touch....this will be plenty of space to install the lift. Wait to raise it more when you mount tires after (safer)
3) Any other trouble points I might expect and prepare for? Get one or two friends to help you.
TIA for the time!
Chris
Good Luck!
2011 SR-5 4x4 w/ TE-conversion:[B] Old Man Emu lift, Light Racing UCAs, ARB skids, Shrockworks step-sliders, Shrockworks front bumper, Custom rear bumper/swingout, Gobi Stealth, ARB awning, ARB compressor, ARB rear locker, Rigid Duallys, Warn M8000, MR301s, Mickey Thompson MTZ, FTS snorkel,
The Overland Adventures
Follow us on YouTube and Instagram
@kccarguy Instagram
KCcarguy is offline   Reply With QuoteReply With Quote
Old 02-26-2012, 12:00 AM #3
tlflow's Avatar
tlflow tlflow is offline
tlflow is on a distinguished road
tlflow's Avatar
TIA for the time!
Chris
I would use 2' jackstands at least. Tractor supply has them. Be safe.
2010 Trail Runner, KDSS;
Overland Warehouse 2.5 HD Kit - tuned to tow, Camburg UCA, 285-70/17 BFG KM2, Gobi Stealth, SW Sliders, SW Bumper, WARN 9.5xp, ProComp 7028 17X8.5/4.75 BS ...
tlflow is offline   Reply With QuoteReply With Quote
Old 02-26-2012, 12:33 AM #4
Mijfwb23's Avatar
Mijfwb23 Mijfwb23 is offline
Mijfwb23 is on a distinguished road
Mijfwb23's Avatar
I used 4 ton stands and had tons of clearance, remember with the wheels off you have a lot more room to move the lower arm outta the way.
I lifted one side and placed a jack stand under it and then moved to the other side and did the same. then I went to the other side and lifted it higher to give me room. I think I had it almost to the last notch, maybe the one before last. Remember to chock your back tires before hand. I never worried about it falling off the stands, also my stands cradled the frame almost perfectly. I just don't like lifting the whole front end from one pivot point that's why I did it the way I did. Also I only lifted the front when I did the front and then the back when I did the back, not the whole truck at once. Reason: I only had two stands.
-- Make sure you support the rotor/spindle when you disconnect the shock so that it doesn't drop and stress the ABS/speed sensor cable.
Haven't done UCAs yet so cant help you on that, but I think I read somewhere on the forums that you need to get them out through the engine compartment not the wheel well.
Good luck, my install was easy except for the KDSS suspension but that only slowed me down alittle.
2010 Trail Edition, Magnetic Gray Metallic, KDSS, Seat Heaters, Infinity Kappa 32.9cf, Bilstein 5100s front/back set at 2.5", Toytec superflex rear coils 2", Goodyear Duratracs 285/70/17, Viair 300P Air Compressor,Cobra 75 WSXT, 10LB Power Tank, RockyRoad Supersliders
Mijfwb23's Build Thread
Mijfwb23 is offline   Reply With QuoteReply With Quote
Old 02-26-2012, 08:57 AM #5
phillyd2's Avatar
phillyd2 phillyd2 is online now
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
phillyd2's Avatar
Real Name: Dave
If I'm not mistaken all 4 wheels need to be up to more easily remove xreas.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is online now   Reply With QuoteReply With Quote
Old 02-26-2012, 10:30 AM #6
Yep - that's why I need it off of all 4.
Got rained out anyway; won't be able to do it until later this week
Thanks for the replies so far; any additional info appreciated
Old 02-26-2012, 01:40 PM #7
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
My jack stands(safety stands) don't have rubber attachments.As stated I always put a couple of the wheels I take off and put them under the truck for extra safety.
Here's the instructions out of the repair manual .
(a) Work on a level surface. Use wheel chocks at all times.
(b) Use safety stands with rubber attachments as shown in the illustration.
(c) Set the jack and safety stands exactly under the specified locations on the vehicle.
(d) Do not work on or leave the vehicle supported only by a jack. Be sure to support the vehicle with safety stands.
(e) When jacking up the vehicle, first release the parking brake and move the shift lever to N.
(f) When jacking up the entire vehicle:
(1) When jacking up the front wheels first, make sure wheel chocks are behind the rear wheels.
(2) When jacking up the rear wheels first, make sure wheel chocks are in front of the front wheels.
(g) When jacking up only the front or rear wheels of the vehicle:
(1) Before jacking up the front wheels, place wheel chocks on both sides of the rear wheels.
(2) Before jacking up the rear wheels, place wheel chocks on both sides of the front wheels.
Jacking(round,front and rear) and jack stand positions
Jack Stand Paranoia & Lift Questions-d103530e01-png
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 02-26-2012, 03:13 PM #8
Thanks Harper - I'll think I'll be putting all 4 tires under the frame in the process.
I don't understand releasing the parking brake & putting it in N - doesn't that maximize the chance of one end moving while the other is being lifted?
Old 02-26-2012, 10:29 PM #9
Mijfwb23's Avatar
Mijfwb23's Avatar
You guys and your crazy Limited's
Old 02-27-2012, 12:04 AM #10
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
Good advice about the tires underneath.
I use 6 stands. 2 are for backup and move around to whichever end I'm working under.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 02-27-2012, 12:39 AM #11
Overland Warehouse Overland Warehouse is offline
Overland Warehouse is on a distinguished road
Good post!!! Safety first.
The wheels under is a nice touch that many use on the trail, when things are not as readily available.
Overland Warehouse is offline   Reply With QuoteReply With Quote
Old 03-01-2012, 11:56 PM #12
Bump for this specific question regarding lifting the vehicle in general; goes against everything I've always thought...
Side note - installing the lift tomorrow - can't wait!
Old 03-02-2012, 12:41 AM #13
Rather use good wheel chocks to prevent the wheels from moving, using the parking brake and driveline can load up a little and cause more shift.
Also it is best to get all 4 wheels off the ground with the wheels still on the axles, till everything is stable. This way of something happens the truck will land on the wheels.
I will also be easier to lift and stabilize the front with IFS first before the rear axle.
Old 03-02-2012, 08:45 AM #14
tlflow's Avatar
tlflow's Avatar
let us know how it turns out (pics)
Old 03-02-2012, 10:42 AM #15
M1911 M1911 is offline
M1911 is on a distinguished road
Me too. I always place the truck in park, set the parking brake firmly, and place chocks.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
M1911 is offline   Reply With QuoteReply With Quote
Precursor to pink milkshake or paranoia? RunninInGA 3rd gen T4Rs 25 01-19-2012 10:45 AM
Floor Jack and Jack Stands for Lift Install EEtM33t General Discussions 7 09-30-2010 04:45 PM
Best Jack and Stand for 4runner bryantn 4th Gen T4Rs 3 09-05-2010 10:42 AM
Lift Jack AlexJet 4th Gen T4Rs 1 02-04-2006 11:18 PM
High Lift Jack Questions. Koz Off-Roading 4 04-14-2005 03:57 PM
