I have seen a lot of questions about part numbers, what fits, what doesn't, etc. This is an attempt to answer a lot of those questions in one place. It will be a work in progress. If you notice something that is incorrect and you know the correct part number, please feel free to let me know and I will update the list.
-courtesy of
Toyota Reference
Warranty & Maintenance Guide 2010
Warranty & Maintenance Guide 2011
Warranty & Maintenance Guide 2012
Warranty & Maintenance Guide 2013
Warranty & Maintenance Guide 2014
Warranty & Maintenance Guide 2015
Warranty & Maintenance Guide 2016
2010 4Runner Brochure (pdf)
2011 4Runner Brochure (pdf)
2012 4Runner Brochure (pdf)
2013 4Runner Brochure (pdf)
2014 4Runner Brochure (pdf) (
early)
2015 4Runner Brochure (pdf)
2016 4Runner Brochure (pdf)
-courtesy of
auto-brochures.com
2010 Factory Service Manual by
nashman69g
Toyota Accessories
Remote Start
PT398-89120 (previously PT398-89100)
PT398-89140 may be the newest version
Installation Instructions
Without Smart Key
With Smart Key
Technical Service Bulletins (TSB)
T-SB-0141-10 Upper/Lower Windshield/Rear Glass Tick Noise
If a creak, tick, or rattle noise is heard at the top or bottom of the windshield, or at the top of the rear glass, the source of the noise may be the two stoppers bonded to the top of the windshield/rear glass, or the windshield retainers bonded to the lower edge of the windshield. This bulletin provides the recommended repair procedure to eliminate these types of noises from the windshield/rear glass area.
T-SB-0081-12 Headlamp Surface Oxidation
Some 2010-2012 model year 4Runner vehicles may exhibit a condition where the top, horizontal clear plastic surface of the headlamp appears to be oxidized or has a hazy appearance. Improved headlamp assemblies have been developed to address this condition.
T-SB-0166-10 (June 29, 2010)
Some vehicles may exhibit a harsh shift on acceleration below 20 mph during the 2-1 downshift on vehicles equipped with an A750 transmission. The Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) calibration has been revised.
T-SB-0051-12 - Driver’s Seat Popping/Creaking/Squeaking From Lumbar Area (March 1, 2012)
Some 2010 – 2011 4Runner vehicles may exhibit a condition where the driver’s side seat back lumbar area makes a pop, squeak, or creak noise while driving. The condition may become more evident when driving on rough or uneven road surfaces or while moving around in the seat, especially if the lumbar support is fully extended. Replace the front seat back spring assembly to address this condition.
T-SB-0040-12 - 4WD Rear Propeller Shaft (Driveshaft) Clunk/Thunk Noise
Some 4WD equipped 2010 – 2012 model year SR5 and Trail grade 4Runner vehicles may exhibit a clunk/thunk noise from the rear of the vehicle or a “bump-from-behind” sensation just before a stop or when accelerating from a stop. Improvements have been implemented on the rear propeller shaft (driveshaft) to reduce this condition.
T-SB-0013-11 - USB/iPod Not Recognized
T-SB-0092-11 - MIL "ON" DTC P2111/P2112 AUG 09, 2011
Some 2010-2011 4Runner vehicles 1GR-FE (4.0L) may exhibit an intermittent MIL "ON" condition with DTC P2111 and/or P2112 (Throttle Actuator Control System stored in the ECM.
Oil & Filter Change 1GR-FE (4.0 V6)
Interval 10,000 miles (Severe Service Interval 5,000 miles)
Pictorial How-to by Antman
Capacities:
Drain and Refill w/o Oil Filter Change 5.7 liters (6.0 US quarts)
Drain and Refill w/ Oil Fitler Change 6.2 liters (6.6 US quarts)
Dry Fill 7.1 liters (7.5 US quarts)
Oil
ILSAC multigrade engine oil 0W-20 (Full Synthetic)
Toyota 0W-20 (part # 00279-0wqte-01) single quart
Filter
Toyota Element Kit, Oil (part # 04152-YZZA5)
TRD high performance oil filter PTR43-00079
Remove:
Engine Under Cover Seal (oil drain cover)
2 x 12mm (21 ft lb)
Oil Pan Drain Plug / Gasket (non-reuseable part)
14mm (30 ft lb) part # 90341-12012
oil drain plug gasket part # 90430-12031
Fumoto (QuikValve, Quick Oil Drain Valve)
F-103 standard
F-103N w/ nipple
F-103S w/ short nipple
Front Bumper Cover Lower
7 x 10mm (71 INCH lb) (3 on each side and one is hiding in the middle)
bolt part # 90109-06330
Cool Air Intake Duct (4x4) (not required? but may make things easier)
4 x Push Pins (? part # 90467-09227 ?)
No. 1 Engine Under Cover Sub-Assembly (front skid)
4 x 12mm (21 ft lb)
Oil Filter Drain Plug (10 ft lb)
part # 15643-31050
Oil Filter Cap (18 ft lb)
SST (Special Service Tool) 09228-06501
64mm x 14 flat oil filter wrench
-use with 15/16” or 24mm socket
Assenmacher Specialty Tools (AST) Toy640
Engine
Cold Air Induction
TRD Cold Air Intake PTR03-89100 (
Install by TOYSTRY)
aFe Cold Air Intake
51-81932 Stage-2 Si PRO DRY S
54-81932 Stage-2 Si PRO 5R
54-81932-0V Stage-2 Si PRO 5R Value Pack (5R + Pro Dry S)
75-81932 Stage-2 Si Pro-GUARD 7
Element, Air Cleaner (Engine)
Toyota 17801-38050
TRD High Flow PTR43-00083
aFe Pro Dry S OEM Replacement 31-10208
aFe Pro 5R Oem Replacement (oiled) 30-10208
Exhaust
Magnaflow 12586 stainless steel muffler
Other Part Numbers:
T-O-Y-O-T-A grill emblem for Satoshi 75311-90K00
Element, Air Filter (Cabin)
81739-30040 (per collision manual) misprint
87139-30040 (old part number)
87139-YZZ08 (normal)
87139-YZZ10 (premium)
Wiper Blades
85214-06130 Insert, Wiper (right)
85214-06140 Insert, Wiper (left)
Limted hood insulation liner 53341-35160
Installation clips 90467-A0003 (x10)
PCV Valve 12204-31110
Lighting
Daytime Running Lights / Turn Signals
Standard Replacement 1156a (amber)
Optional Replacement 1156 (clear)
-also known to work
Piaa Xtreme 1156 (Super White)
Rigid Industries
Dually
SR-Series
E Series
Suspension
Airbag Load Levelers by
Antman
Air Lift 1000 Series 60809
Bilstein Shocks
5100 Series
24-196499 Front (Adjustable Ride Height)
33-187174 Rear
Wheels & Tires
Lug Nut Torque - 83 ft lbs (
make sure mating surfaces are clean and free of oil, grime, or lubrication)
Stock Wheels & Tires
6 lug x 5.5" (139mm)
hubcentric - 106mm bore
4.5 back spacing
SR5
17x7 P265/70R17
Trail
17x7.5 P265/70R17
Limited
20x7 P245/60R20
I found
this little calculator that may be of some help for those of you considering different wheel widths, tire sizes, etc.
http://www.toyota-4runner.org/5th-ge...ml#post1550444 by
1engineer
Extended Warranty
Apparently this contact is no longer handling extended warranty. Stay tuned for updates.
Jerry Johnson
Midwest Superstore
Hutchinson, Kansas
[email protected]
1.800.530.5789 dealership
620.664.8844 cell
His prices on 4Runner 4x4, as of 2/2012
6/125 Platinum $0 deductible - $1019
7/125 Platinum $0 deductible - $1144
Prices are no taxes or fees unless you live in Kansas.
Cleaning & Detailing
Simple Green All-Purpose Cleaner & Degreaser
Mothers Clay Bar
Meguiar's Clay Bar
Foam Gun (Cannon)
Optimum No Rinse (ONR) Wash & Shine
Car Wash Bucket with Grit Guard
Porter Cable 7424
Flex XC 3401
303 Products Multi Purpose Protectant
Stoner Glass Cleaner
Miscellaneous
Console Vault
Plasti Dip
Plasti Dip Spayer (Wagner 0518080)
3M matte black vinyl wrap
Monitoring
ScanGauge II Ultra (this newest version will monitor transmission temps from the computer's OBDII port without having to install a separate trans temp monitor/gauge)
Fiamm El Grande 74100 install thread by
Titanpat57
