Old 03-22-2012, 02:02 AM #1
huntsonora huntsonora is offline
huntsonora is on a distinguished road
What's average cost for Icon lift install?
I am trying to budget for my lift and was wondering what an average cost of install would be for the icon stage 1 lift on a 2011 trail edition. I just don't have the time, space or tools to attempt to do it myself.
Thanks
huntsonora is offline   Reply With QuoteReply With Quote
Old 03-22-2012, 06:21 AM #2
limamike's Avatar
limamike limamike is offline
Real Name: Dave
limamike is on a distinguished road
limamike's Avatar
Real Name: Dave
I'm getting mine done on Monday for $710 with UCAs and remote reservoir. Alignment, mounting and balancing new tires is about another $150.
I was quoted close to $1500 at the first shop I called, though.
A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
limamike is offline   Reply With QuoteReply With Quote
Old 03-22-2012, 07:55 AM #3
Ducmonsta's Avatar
Ducmonsta Ducmonsta is offline
Ducmonsta will become famous soon enough
Ducmonsta's Avatar
It's going to vary according to your demographic. It will be more in my area because it's in the DC metro area where it's not unheard of to be at $120/hr. In Kentucky, you could get away with $60/hr.
Lima-That first shop better not have been mine! or you didn't talk to me!
Ducmonsta is offline   Reply With QuoteReply With Quote
Old 03-22-2012, 11:56 AM #4
Mick1's Avatar
Mick1 Mick1 is offline
Mick1 is on a distinguished road
Mick1's Avatar
Lima please be sure to measure the pre lift distance ground to fender and mid hub to fender for each corner.
I want to determine if the rear icon springs stated lift of 2 in is comparable to the sway away stated lift of 1.5 in. i could not find this info anywhere on the web.
I will measure before installing my saw coils with pictures. I may be lower than you currently due to bud built skids and sliders and my cargo platform and junk in the back. Last i measured was lf 34.5, rf 34.25 and 36.5 in both rears
RHINO
'11 Trail
http://rhino4runnersuspension.shutterfly.com/
Mick1 is offline   Reply With QuoteReply With Quote
Old 03-22-2012, 02:18 PM #5
Mick1's Avatar
Mick1's Avatar
Lima the racing adage is only change one thing at a time. Otherwise you have no idea what changes are causing what results. So it is probably a good idea to do the lift first then wait a few days prior to changing wheels and tires. That way you can discern which changes cause any increase/decrease in performance or problems.
RHINO
'11 Trail
Old 03-22-2012, 03:16 PM #6
helocat's Avatar
helocat helocat is offline
helocat is on a distinguished road
helocat's Avatar
For a stage one we charge $400 if the kit was purchased though us. ($500 if not) There is an extra $50 for UCA install. We also provide a free car rental for the day if we do over $300 worth of labor.
Then of course you can add Total Chaos knuckle gussets, to be welded on etc. These do add to the cost as back side knuckle seals are replaced w/ new. Can get real fancy fast!
As for checking heights always a great idea to do so. Just remember to park your truck in the exact same spot every time you check. Concrete and asphalt look flat but it will not be the same. Just note where your truck is parked. Also after the install make sure you drive the truck, hard turns and braking to settle in the springs. Then measure.
Mark
Mark Hawley
Metal-tech 4x4
2016 3rd Gen Tacoma - 2007 FJ Cruiser - 2005 GX470 - 1988 BJ74 diesel Landcruiser - 1987 HJ61 diesel Landcruiser - 1978 FJ40 Ya I like Toyota's!
helocat is offline   Reply With QuoteReply With Quote
Old 03-22-2012, 03:20 PM #7
helocat's Avatar
helocat's Avatar
So true. I learned that one years back in Collage modifying my FJ40 Land Cruiser. Suspension, gears, lockers all at once. Took forever to find the vibration the truck had after all that work. (New rear drive shaft angle with a 25+ yr warn transfer case output shaft = output shaft not happy)
Mark
Mark Hawley
Metal-tech 4x4
Old 03-22-2012, 06:10 PM #8
limamike's Avatar
Real Name: Dave
limamike's Avatar
Real Name: Dave
Got it, Mick1 - I think that adage applies to a lot of things! Fortunately, I'm only changing suspension and tires at this point, so it should be fairly easy to diagnose any issues. I'll take some measurements for you before and after as well.
Old 03-22-2012, 09:32 PM #9
Qjake's Avatar
Qjake Qjake is offline
Real Name: Billy
Qjake is on a distinguished road
Qjake's Avatar
Real Name: Billy
Some good advice here from both Mick and Mark, thanks
Billy a.k.a. Q-Jake
2011 Limited MGM......My Build
Qjake is offline   Reply With QuoteReply With Quote
Old 03-22-2012, 10:08 PM #10
Mick1's Avatar
Mick1's Avatar
Good point about measuring in a set spot. I had not thought about that.
Also, I just thought that I would add. Based on what I saw from the bumper install I would certainly let the ducmonsta shop do work on my truck. They seem like real car enthusiast and interested in doing quality work. The price does not seem that bad either.
Compare that to what I have to deal with locally. The last two places I let work on my truck were a complete disaster. I let a transmission shop install a cooler because I didn't have time and thought they could do it expertly. It was worse than letting monkeys do it.... Slobs, lazy, zero pride in their work, and evidently pretty stupid because it was hooked up wrong.
RHINO
'11 Trail
Old 03-22-2012, 10:36 PM #11
jangoforhire's Avatar
jangoforhire jangoforhire is offline
jangoforhire is on a distinguished road
+1 on this. I was on the phone with Ducmonsta a few days ago about installing my ICON suspension and a rear locker. Real nice guy. His shop is about an hour and half from me but I would gladly make that drive to get a reputable shop and have someone who knows how to work on 5th gens do the work.
2010 T4R LTD - Loaded
My Build Thread
jangoforhire is offline   Reply With QuoteReply With Quote
How much would my lift install cost cgill00 5th gen T4Rs 29 01-24-2019 09:53 AM
Icon Shift Knob Install Write-up limamike 5th gen T4Rs 20 03-13-2012 10:21 PM
ICON Install HELP and Advice Reata 5th gen T4Rs 4 04-23-2011 01:33 AM
Average Cost of a Rear ARB Locker. joem 3rd gen T4Rs 2 08-28-2010 05:54 PM
Cost to remove and install new suspension vancek78 4th Gen T4Rs 5 04-02-2008 02:06 AM
