04-10-2012, 01:07 PM
Real Name: Carl.
Real Name: Carl.
XM Presets 12 LE WITHOUT Entune
OK I have a 2012 LE with out the Entune.
When I listen to sat radio it will not let me choose any pre-sets. AM & FM have 6 preset tabs that hold the radio stations.
When in Sat mode it does not gve me the option, my manual says I should have 3 Sat modes with 6 presets in each one but mine does not, if I press the sat (On the Nav screen) it just goes to Sat 2 and if I press again it goes to Sat 3.
Any ideas please
2016 Storm Trooper White
I'm 10-32
04-10-2012, 01:26 PM
Real Name: Ken
Real Name: Ken
Any ideas please
When my NAV system is in "SAT" mode, I have 6 programmable presets for each SAT mode (SAT1, SAT2, and SAT3) for a total of 18 presets. When you're in SAT mode, what's on your NAV screen? You can't see the presets if your looking at your map so you'd need to press the "AUDIO" button to toggle the MAP to AUDIO mode. Then you should see your presets. To set a preset, just press and hold it until it changes. Repeat for each one.
2010 Limited Magnetic Gray Metallic
with Navigation system
04-10-2012, 01:28 PM
Real Name: Carl.
Real Name: Carl.
Exactly the same in my wifes Lexus, when I am in "Audio" listening to XM I don't see any presets at all just the channel number in the top right of the Nav screen. I'm at work right now but I'll try and post some pictures later today. No presets at all
I'm 10-32
04-10-2012, 01:31 PM
Real Name: Ken
Real Name: Ken
Something seems wierd there. If I'm in audio mode, across the top, I have "AM/FM/SAT/CD/USB/BT" As I click thru each source, I can see the different presets. I'm a bit puzzled as to why you wouldn't have them. Seems very odd. I'll have to take a pic of mine for reference.
04-10-2012, 01:35 PM
Real Name: Carl.
Real Name: Carl.
Yup I have 6 presets in AM and FM. I don't get presets in SAT/CD.USB or BT
I'm 10-32
04-10-2012, 02:46 PM
You don't see the presets because the initial screen just shows artist/track information. There's another soft key to press to get the presets to appear. I can't think of which one off the top of my head, but after I drive home this evening from work I'll post back if someone else hasn't already.
2012 Magnetic Gray Limited 4x4
LS460 HID Projector Retrofit
ICON Stage 6
Konig Countersteer Type X - 285/70/17 Duratracs
04-10-2012, 02:49 PM
Real Name: Carl.
Real Name: Carl.
I hope your right otherwise it's a trip to the dealer....
I'm 10-32
04-10-2012, 04:19 PM
Moist, did you do the following;
Radio "on".
Press "setup".
Press "6" (More)
Press "2" (Preset)
Here it will show you how many "presets" have been chosen and it should show 6.
After you choose the number of presets, that will be 6, let the screen return to normal.
Now press your preset button and it should go through all AM, FM and 3 pages of SAT.
HINT: Don't rely on the "mode" button on the steering wheel to go through your presets. I thought it would but the correct way (according to the dealer) is to press the preset button to change your AM/FM/SAT/etc....
Hope this helped.
Wandering aimlessly.....
04-10-2012, 04:45 PM
Real Name: Carl.
Real Name: Carl.
Radio "on".
Press "setup".
Press "6" (More)
Press "2" (Preset)
Hope this helped.
I'll give it a try, but from memory I don't have preset numbers on my nav screen....may be wrong but I'll give it a try when I get off work.
I'm 10-32
04-10-2012, 09:10 PM
Real Name: Ken
Real Name: Ken
When you press SAT, then audio, do you see the song thats playing? If you do, press the "text" button near the bottom left and your presets should appear.
04-10-2012, 10:06 PM
Real Name: Carl.
Real Name: Carl.
Ok here are some pictures the first are of AM then FM both of the AN and FM have pre-sets, when I switch to SAT 1 I dont see any pre-sets, when I press SAT again it just goes to SAT 2 and again to SAT 3 when I press the SAT tab
I'm 10-32
Real Name: Carl.
Real Name: Carl.
Ill give that a go too thanks
I'm 10-32
04-10-2012, 10:19 PM
Yep, press the "Text" button. That'll reveal your presets.
ICON Stage 6
04-10-2012, 11:59 PM
Real Name: Carl.
Real Name: Carl.
Thanks guys I'll give it a go in the morning, thanks again for your help. I'll keep you posted
I'm 10-32
04-11-2012, 12:38 PM
Real Name: Carl.
Real Name: Carl.
Yipppee It worked, thanks guys
I'm 10-32
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
