Old 05-06-2012, 07:52 PM #1
GrantK's Avatar
GrantK GrantK is offline
GrantK is on a distinguished road
GrantK's Avatar
Rear door panel installation tip
I was a little concerned about doing Antman's door handle light mod because he and others have warned that re-installing the door panel is a pain in the butt and takes a lot of patience, which I don't have. So after doing the mod I tried to refit the panel only to have trouble getting the pins and weather stripping to line up as predicted. After several tries and words that would make a hooker blush I surrendered my Man-Card and read the PDF repair manual (thanks to those that made it available).
The trick makes re-installing the panel soooooooo easy that I installed it in 15 seconds! While the panel is off, pull the top weather stripping off. It is held in place by three clips and you just, carefully, pull it straight out from the panel. Then when re-installing, mount the weather stripping to the door and the panel goes on with no arguments at all!!! I now have no concerns about doing it again for installing speakers or any other dumb ideas I come up with.
BTW - A couple of tips for doing the door handle LED mod (everyone does things different). I used 3mm 12v pre-wired orange LEDs from Ozium. I carefully drilled a hole from the back with a Dremel without taking the panel apart. Then I super glued the LED in place and wired it to the window switch's LED power wires. The orange LED seems to match the amber LEDs in T4R very closely.
This space for rent.
GrantK is offline   Reply With QuoteReply With Quote
Old 05-06-2012, 08:21 PM #2
terra4r's Avatar
terra4r terra4r is offline
terra4r is on a distinguished road
terra4r's Avatar
very nice, i know that part was a pain in the butt
-Jim
'11 Mag Grey SR5 4WD Premium Pkg.
OEM door handle LED's, Mud and hood protectors, Infinity 32.9cf's
terra4r is offline   Reply With QuoteReply With Quote
Old 05-06-2012, 09:16 PM #3
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
Pics or it didn't happen!
Been there done that on those door panels! Mentioned before on the other "door panel removal" thread..........Rear Door Panel Removal - any hidden screws?
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 05-06-2012, 11:45 PM #4
GrantK's Avatar
GrantK's Avatar
Good thing I hadn't don't the other door...
First the panel with the weatherstrip and taking it off. Then the weather strip going onto the door. After that, the panel goes straight on.
Rear door panel installation tip-doorpanel_wweatherstrip-jpg  Rear door panel installation tip-doorpanel_wweatherstrip1-jpg  Rear door panel installation tip-doorpanel_wweatherstrip2-jpg  Rear door panel installation tip-doorpanel_noweatherstrip-jpg  Rear door panel installation tip-door_weatherstripinstall-jpg  Rear door panel installation tip-door_wweatherstrip-jpg
Old 04-25-2013, 09:59 PM #5
dpr422 dpr422 is offline
dpr422 is on a distinguished road
Grant -- thanks for posting this. I front doors are easy compared to the rears... I almost committed Hari-kari trying to get the rear panels back on, but found this thread....
I put some 6.5 JLs in the doors. Next is the amp...
dpr422 is offline   Reply With QuoteReply With Quote
Old 07-25-2017, 09:24 AM #6
Sam1Am's Avatar
Sam1Am Sam1Am is offline
Sam1Am is on a distinguished road
Sam1Am's Avatar
Sorry to ressurect an old thread, but it must be done for sake of a HUGE thank you to GrantK! You saved my sanity and my rear door panel which was >this< close to getting stomped and thrown in the dumpster . That or I would have had to slink to Toyota with my tail between my legs and reveal to them how much of a dummy I am.
Sam1Am is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 11:30 AM #7
Dirty Dan's Avatar
Dirty Dan Dirty Dan is offline
Dirty Dan is on a distinguished road
Dirty Dan's Avatar
I was moments from lighting the truck on fire and walking away forever, when my passenger rear door panel magically snapped into place after a literal hour of fighting it. I only wish I’d have had the wisdom to search the forum before starting the job! Thanks so much for posting this. I now feel a lot more confident about applying sound deadener to the driver rear door and hopefully not losing my mind.
Dirty Dan is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 12:02 PM #8
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I've shared this tip several times, I literally drove around without my rear door panels for a couple days before figuring out this trick. Definitely a life saver after much frustration
Old 12-21-2020, 12:57 PM #9
Dirty Dan's Avatar
Dirty Dan's Avatar
Before and after of passenger rear door sound deadener. I installed deadener on the inside of the door skin as well as sealing the inner door in preparation for my planned speaker install.
Rear door panel installation tip-6230554d-1ed3-49fa-856e-d5246aa8e32f-jpg  Rear door panel installation tip-8b88d6d1-8b52-48e1-90da-f6268af8a327-jpg
Old 04-13-2022, 11:29 AM #10
Ace5477 Ace5477 is offline
Ace5477 is on a distinguished road
Massive thank you to this thread. I was about to have a meltdown putting the rear door panel back on. Sweating profusely, cussing, and about to give up after and hour and a half. Then discovered this thread and it was back on on in 3 minutes!!!
Ace5477 is offline   Reply With QuoteReply With Quote
Old 10-01-2022, 02:07 PM #11
kdf39 kdf39 is offline
kdf39 is on a distinguished road
I also thank you tremendously !
This was the best advice ever !!!!
kdf39 is offline   Reply With QuoteReply With Quote
Old 10-03-2022, 03:24 PM #12
sympley76 sympley76 is offline
sympley76 is on a distinguished road
Did you went over the moisture barrier with your sound deadening material, or did you take the barrier off?
sympley76 is offline   Reply With QuoteReply With Quote
Old 10-04-2022, 06:30 PM #13
gakattack gakattack is offline
gakattack will become famous soon enough
reallllly wish I saw this before installing oemaudio+ in the 4R
2018 ORP, 2001 S4 Tial605, 2001 Maxima, 2013 GS350
gakattack is offline   Reply With QuoteReply With Quote
Old 10-04-2022, 06:35 PM #14
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
yea, no kidding.. lmao. I got my panties in a bunch and just cut off the white stub.
MasterFoo is offline   Reply With QuoteReply With Quote
Old 10-04-2022, 06:36 PM #15
Oh man, glad I'm not the only one that threw a fit.
used every swear word in the book.
4th Gen Rear Door Panel Separation xlaxx 4th Gen T4Rs 5 02-27-2012 01:00 AM
How to remove panel on rear door? neffmoore 3rd gen T4Rs 4 02-10-2012 02:34 AM
How do i get the rear door panel off? tvbuster1 3rd gen T4Rs 4 10-14-2008 12:13 PM
Rear Door Panel Removal? sant6236 4th Gen T4Rs 1 09-03-2008 06:03 AM
Rear Pass Door Panel f/s! cover8 Classifieds - buy & sell (no commercial ads please) 0 12-22-2006 01:37 AM
