Originally Posted by Hbryanlopez
Doing my TE conversion and running into problems removing the fender liners. There are these plastic retainers pictured bellow, that are PITA! I'm stuck. Anyone with experience removing them?
Probably thee biggest PITA for doing the TE conversion is the front fender liners. Those fasteners fit in square holes have a pinch release on the back side. The problem is getting to the backside with all the stuff on the inside fender wells . Start at the front working thru where the headlight was and work backward is what I did,one at a time. Those poly liners are real tough and you can bend it out of the way as you work back!
A square part 3/8" socket with a little tape on it will fit over the back side and compress the pinch locks,then just use something to pull it out.Take one of the easy ones out and you'll see what I mean.
If I had to do it over again ,the ones that are real hard to get to I would have just used a 5/16" drill bit and drilled them out and replaced with new.
