05-23-2012, 09:23 AM
Need help with new Duratracs
Hey Everyone,
Just got some 265/70R17 Load E tires on my 2012 TE and I don't understand if I have set something up wrong or if the tire guys did.
My problem being is that at anything over 60 mph they feel very unstable, and pull hard over every single uneven surface on the road. What I am asking is, anything I can do to help reduce this?
Tire pressures I have tried so far 44psi (cold) and 40psi (cold).
40 at the moment feels a little better.
Thanks for any help.
05-23-2012, 09:29 AM
Real Name: Dave
Real Name: Dave
Have the exact same tire / size and had the same issue, I think, since "unstable" is a subjective term.
In my case they are not balanced correctly. I took mine back to the GY dealer for rebalance and its all good now. They did the original balance too. Make sure they balance all 4. They only wanted to do the front two but I insisted of all so I would not have a issue after tire rotation.
This should be your first step, assuming you are aligned correctly.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
05-23-2012, 09:33 AM
Thanks a lot for the info, I thought though that I would have a shaky steering wheel if they weren't balanced correctly. Though I am not a expert.
I will do as you prescribed... back to this worthless tire shop.
Thanks again.
2012 4Runner Trail Edition w/ KDSS & NAV.
GY Duratracs 265/70/R17 Load E
05-23-2012, 09:38 AM
5th Gen Moderator
5th Gen Moderator
if balancing is the issue, and you're not fond of the shop, have them balanced elsewhere. I've always had best luck with road force balancing
Originally Posted by 7harper
First 5th with real CO's
2017 White TRD OR, Icons, BFG Mud-Terrains, Konig Countersteer, Retro Headlights, Gobi stuff
05-23-2012, 09:39 AM
Hmmm... I think your pressure is in the sweet spot, I ran my 265 E Duras at 42 and loved them. They do need a few hundred miles to break in, and I remember they were slightly squirmish on the highway the first few days.
If you check the balance is OK and there is still an issue, you might have a bad tire. I moved up to 275 Goodyear MT/Rs recently. I could tell instantly the truck pulled to the right at all speeds. Discount recommended I roll them for 2 weeks and it did not go away. They confirmed they were all balanced properly and then rotated only the right side of the truck. Pull went away immediately. They ordered a replacement from GY and swapped out the right rear. It was determined to be defective. Rare but it happens. I'm so glad we tracked it down because I would have otherwise always had an issue when that tire was up front.
2010 Magnetic Grey Trail ~ KDSS ~ Nav ~ OW2.0 ~ LR UCAs ~ BB plates ~ MT/R Kevlars ~ DigiLiners ~ AVS smoke ~ El Grandes ~ Shrockworks ~ TRD CAI ~
05-23-2012, 09:41 AM
Real Name: Dave
Real Name: Dave
Which is why I added the caveat of defining "unstable" ;)
These tires are famous for being hard for some to balance. Where did you buy and who installed them? With most reputable places, as soon as you mention feeling "unsafe" should work diligently to find and fix the issue.
05-23-2012, 10:06 AM
^^^^ THIS (both on the shop and the Road Force Balance): I've been very happy with my local Discount Tire. And make sure you ask for the local guru at the store; not the kid that is doing it for the first time. (although the guru may be a kid like at my store; but he's very professional about it.)
Okki
Okki's Build Thread - 2010 Limited: Shrockworks Rock Rails & Full Skids, Gobi Rack, OPT7 LED Roof LIGHT Bar, Rigid E-Series Bumper Light Bar, Hella Horns, Auxiliary Fuse Box, Cobra ST75, TRD Rims, Discoverer ATP LT265/70R17, Rotopax, ARB Twin Compressor, Cargo Area Pressure Gauge and Chuck, Icon billet trailing- and A-arms, Dobinsons Shocks/Coils, Fumuto Oil Valve, Northstar Group 31M, CBI Front & Rear Bumpers !!!
Any time...Anywhere.. My cat can take you.
05-23-2012, 10:23 AM
Thanks again guys for the info..
I had them installed at a local tire shop that has been in business here for over 30 years. They always have done me right in the past and nearly everyone in the area use them.
I don't know if this information is helpful but I noticed the machine they were using utilized to balance them was a Hunter... Does that help?
Thanks again
05-23-2012, 10:51 AM
5th Gen Moderator
5th Gen Moderator
pretty contradictory. if they are a good shop, go back and tell them the problem and they will fix it. if they are worthless take your truck somewhere else.
05-23-2012, 10:58 AM
Will do!
I will keep you guys posted and hopefully this issue is resolved.
Thanks to everyone!
05-23-2012, 10:59 AM
Hope you get everything worked out but you should really post some pics of your new tires.
2012 Silver TE KDSS / NAV / NFAB
05-23-2012, 12:01 PM
As requested, here she is sitting with 190 miles. I will post some better pics later.
05-24-2012, 03:59 PM
Well I had the tire shop look at it and he stated everything looked fine.
They said they would drop the pressure down to 35 to see if that would help any.
He also noted that sometimes with that aggressive of a tread on a vehicle it will tend to have a little road walk at higher speeds, but he said that it wouldn't always happen that way. He said he could put the same set of tires on 4 different other vehicles and it may not have any signs of road walk, but then on mine might still have some.
He also noted that it may improve after driving on them for a couple of weeks.
What do you guys think?
05-24-2012, 04:21 PM
My first thought is 35psi is too low for the E rated 265/70/17 DuraTrac. Many of us have or had that tire and run it at 42-44psi with very positive results.
Did you read my earlier reply about checking for a defective tire?
05-24-2012, 04:54 PM
I have ran them at 40-44psi and still the same results on either. Also, I did note your reply about a possible defective tire.. though this tire shop does not seem to think so. I think I may drive to the nearest Discount tire and have them check it out.
Am I crazy though for thinking road walk is not normal??
The tire shop owner thinks that this is just going to happen with some setups... no matter what they do....
Doesn't sound good to me... I think im gonna go somewhere else soon
