Solved! it was the LED bulbs both failed at the same time. I am guessing it was the high temps we have been having in Utah this July.
I installed LED backup lights (about 1 year ago) Update: Actually after researching my order they are probably more like 3 years old - time fly's
, anyway they worked fine until now. The driver side is so dim you can only see it in the dark. The other one does not come on at all.
This is a 2012 Trail with automatic transmission.
Fuses look ok. One Fuse under the hood is a big unit that apparently controls many different lights it does not have a visual inspection but all other lights work so it's probably fine. Any known issues I can check? I do offroad some so vibration could be a factor.
Thanks
