06-13-2015, 04:30 PM
#46
Originally Posted by 1000MPH
It took me 1/2 an hour to find this thread. Bumping to the first page. Going to do my T/C and front Diff this weekend. At 48.5k miles.
I did lots of dusty 4WD this past year.
Going with the Delvac again.
OP said: "The rear diff uses two silver gaskets and the front diff uses the silver for the fill and the copper for the drain.
The gasket part numbers from Toyota are:
x3 12157-10010 (Silver)
X1 90430-24003(Copper)"
you seem to have a lot more gaskets in there. For the t case? Also did you use the same oil in the both diffs and the t case?
4RUNHER Owner: October 2014-October 2020
SOLD 2010 MGM TE w/ KDSS SOLD
Consolidated Slider Info Thread :: 5th Gen Features/Models/Differences :: New member? Please read this.
09-04-2016, 05:43 PM
#47
I have a '04 4Runner can't find the diff oil in manual to use. Recommendations? Thx
09-04-2016, 06:28 PM
#48
I just checked my rear diff after less than 5000 miles. Black! I do alot of off roading. Going to change it soon as the dealer opens. They said their 80W90 is only $5.50 a quart. Thanks for the thread. May have saved my gears.
2016 TRD Pro: Husky Weatherbeaters \ ARB Breather \ RCI Sliders & belly Skids \ C4 Fab Tank Skid \ Engo 9000S Winch on Pelfrey Hidden Mount
The Tanks Mods & Adventures http://www.toyota-4runner.org/5th-ge...-my-build.html
10-03-2016, 03:38 PM
#49
I have a new TRD Pro. Don't really do much off roading. Use 4wd when winter arrives. When would be a realistic time to change the diff fluids? 40k? more, less?
thanks
10-03-2016, 03:44 PM
#50
Real Name: Charles
Real Name: Charles
thanks
When Toyota tells you to, its in the manual. ( I would tell you but don't recall the exact mileage)
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
11-10-2016, 12:06 PM
#51
Real Name: Jason Koertge
Firstly, great write up.
I referenced this post continually while preparing for and performing this yesterday.
All in all, this was super simple.
Just to help others venturing into this task, I have a couple comments to add:
Make sure you have a 10mm Allen wrench. I assumed I did because I have no less than 4 sets of allen wrenches lying around. BUT, (I'm sure I'm showing my naivety here) a 10mm wrench is bigger than what's included in any of those sets and I had to run to the hardware store after I dropped the front skid.
Also make sure you have a shallow 24mm socket. The one I got with my set (24mm was also larger than anything I had just laying around) was too tall/long to fit between the diff and the rear sway bar. Yep, I had to run to the store AGAIN. Haha.
Next time I do this I'll lay copious amounts of cardboard down to prevent spillage from hitting my paver driveway.
2016 4Runner Trail (not the fancy premium) | CBI Front/Rear Bumpers and Skids, Lightforce USA Lights, Icon Stage 7, 285 KO2's, Spidertrax Spacers, IconAlloy Wheels, FrontRunner Slimline Rack, SDHQ Dual Battery with Odyssey Batteries, SPOD, Dometic Fridge, Aux Power from GoalZero, Mounting by PowerTrays, Xenon Depot Xtreme HID Kit, Slee Offroad Sliders.
Us on YouTube | Us on Instagram
12-16-2016, 04:58 PM
#52
2014 4runner SR5
I am getting ready to change the oil on both Diff's and trans case, what size socket and allen do I need? I have looked everywhere and cant find what I need.
12-16-2016, 05:40 PM
#53
Read the whole tread, start from the beginning please for sake of Pete...
04-01-2017, 12:34 PM
#54
Bumping to the first page for reference. Approx 38k on my rear dif fluid. It seems like a good time to change again since I expect a busy Spring/Summer. I'll be using Delvac again.
24mm or 5/16" socket.
2.75 to 2.85 US qts (Trail)
2 - 12157-10010 Silver washer/gasket
36ft·lb
04-01-2017, 01:42 PM
#55
First checked for leaks then cleaned up around the bolts. Then pulled the filler bolt. It came undone easy with a tap of the palm on my big breaker bar. I forgot the dif gets pressurized so there's a hissing sound. I checked the level with a wood dowel and it's right where it should be. Fluid is very clean looking but I'm here so I might as well change it.
Drain bolt was easy to remove as well. Hardly any gunk on the magnet compared to the first change.
I cleaned up the bolts then replaced the washers. 15mins later and the fluid is still draining.
04-01-2017, 03:02 PM
#56
Fluid finally stopped dripping. Drain bolt was reinstalled and torqued to 36ft-lb.
New Delvac pumped in. Slightly over 3 qts go figure. Same as drain amount it turns out.
I took a pic after three fillings and decided it was close enough to full. 0 to -5mm is the spec. Fill bolt reinstalled and torqued. Old oil will go to Walmart. Time for chorizo and eggs.
06-07-2017, 11:04 AM
#57
Thank You !!
Very helpful....nice job.
06-07-2017, 12:42 PM
#58
Great write up! Thanks for showing everyone how simple and straightforward this is.
2016 4runner SR5 Premium
2007 4runner Limited
1998 Camry (almost 300,000 miles)
06-09-2017, 11:22 PM
#59
Real Name: Ben
Real Name: Ben
So, I thought I should inform everyone that Redline Oils is shortchanging their customers. 3 "quarts" of Redline 75w85 does not fill a rear diff on a 5th gen 4Runner. In fact, it took most of a 4th "quart" to do it, and after driving a few miles, it took 4 full Redline "quarts" to fill my rear diff.
I cannot remember the last time I was this upset about something, as it rendered my car inoperable for over a week while I made enough of a fuss to get the 4th quart overnighted to me for free.
I will never use a Redline product again, and will do everything I can to ruin their name. They are liars. Based on this experience, I am draining their fluid tomorrow and replacing it with something from someone who can at least be honest about the quantity of product sold.
I am disgusted with Redline and the Pennzoil Group. I piss on you from a considerable height.
2019 Midnight Black Limited with Beige Interior
275/70R17 Nokian Hakkapeliitta LT3 on FN FX Pro -- Winter
275/70r17 BFG KO2 on stock Trail wheels for summer/shoulder seasons
H11 to H9 low beam conversion
06-09-2017, 11:47 PM
#60
Real Name: Logan Turner
Spend the coin and go OEM fluid.
'15 TEP. | ICON Stage 3 w/ Overland Springs & 700lb Coils | Billet Upper & Lower Links | ICON Track Bar | 285/75 Nitto Trail | Gobi Stealth | ARB Awning | ARB Twin Comp. | ARB Breathers | Geared and Locked | ARB Skids | Pelican Storage | Rigid Ind. | Switchpro | Rago Fab Molle | Pelfreybilt Front | Pelfreybilt Sliders | CBI Rear | Safari Snorkel | Vinyl Wrap | Warn Zeon 10-S |
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
