Old 06-14-2012, 03:17 AM #1
deekoi's Avatar
deekoi deekoi is offline
deekoi is on a distinguished road
deekoi's Avatar
20" Light Bar in stock Grille
After seeing the Tacoma light bar from the hood scoop, then seeing everyone with tons of light setups, I was jealous and wanted more light power. So I threw one of these into the lower grille! 20” rigid industries spot/flood light! As many have said, these lights are very bright and powerful. Very good quality product. Pictures don’t do the lights justice until you see them in person. BRIGHT!
Popped off the grille with flat head screwdriver & towel
A couple of L brackets (had to cut one side down to fit)
Bolt goes up thru the plate. When I made the pilot holes, had to make them wide enough for the bolt to sit into the plate so the plate could sit close to flush with the aluminum bumper still. Should be drilled down to close to flush with the tape level. This is where the 1/8th thickness helped. I wouldn’t used anything less than this, a thicker cut would be more safe. Sorry, forgot to take pictures of this. Used washers to adjust height to fit into the grille
I used 2 steal mounting plates. 12”x2”x1/8” (or you can use 1 24-25”) & double layer (side by side) of 3M taped the bottom of the plates. But removing the tape to mount, I tested the fit and light aim. Aim wasn’t hard since these lights blast all over the place.
Even before I taped it down, the grille held the light fairly well. With the 3M tape, solid. No budge at all. Feels very secure.
Final product! & all nice and clean!
2011 4RAWRner Magnetic Gray | Trail Edition
the Mods - ICON S-2 LR + MT Links | Matte Black Hood | FN Six Shooter Graphite Gunmetallic | 285/70/17 Duratrac | 30% Tint | Shockworkz Sliders | Hybrid Conversion | AFE Intake | 20" Light bar lower grill + a bunch of lights all around | low - Blacked out FX-R IV Apollo HID 4300k | High - Sylvania Ultra | LED Interior | Back up camera switch | Camelback Metalgear Roof Rack - DC Power 270 Alternator
deekoi is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 03:30 AM #2
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
Very nice. Can't wait to get a bar, most likely VisonX 21" Xmitter Prime (5 watt LEDs) on my bumper. Can you try and get some output shots?
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 05:37 AM #3
SigSense SigSense is offline
SigSense is on a distinguished road
Question
Can you still make adjustments to the alignment? Did you consider mounting it behind the grill?
SigSense is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 07:29 AM #4
limamike's Avatar
limamike limamike is offline
Real Name: Dave
limamike is on a distinguished road
limamike's Avatar
Real Name: Dave
Installing mine today! I installed my 6" Rigids up top last night, and holy sh!t are they bright. Thanks for the inspiration!
A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
limamike is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 07:57 AM #5
mace.'s Avatar
mace. mace. is offline
mace. is on a distinguished road
mace.'s Avatar
I have my light bar in the same location, except mine sits further back and I left the grill intact for now. Doesn't seem to obstruct the light too much. It's not bad considering it was a cheapo from ebay.
mace. is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 11:19 AM #6
deekoi's Avatar
deekoi's Avatar
I took some with my phone but they didn't come out well. I'll take some more tonight. But they are very BRIGHT!
I considered it but since these lights are spot & flood, the flood got blocked by the bumper too much, IMO.
I also looked up how much a replacement grille cost, $50. So I thought this would be way better.
Old 06-14-2012, 11:35 AM #7
Keemonrunnin's Avatar
Keemonrunnin Keemonrunnin is offline
Keemonrunnin is on a distinguished road
Thumbs up
Very nice deekoi. May consider doing the same, not sure yet. Still trying figure out what I want to with that space.
2010 LE 4wd Mag Gray Met|tinted front windows 20%| Fuel Boost 18x9|Nitto Ridge Grapplers|285/65/18|Icon stage 2|Demello kick out sliders|SW bumper oval drl|luminic yellow fogs|H9/9011HIR headlight mod|Grill craft w/Toyota emblem|AFE cai|Magnaflow 12256|TE roof rack|stubby ant|cargo door emblem blk/silver|Icon shift knob (short)|weather tech floor mats|Led interior light kit,icon expedition springs,cbi rear bumper w/swing out|ARB onboard air|.
https://www.instagram.com/kymzrnr/
Keemonrunnin is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 11:36 AM #8
deekoi's Avatar
deekoi's Avatar
Can't wait to see it!
Old 06-14-2012, 11:46 AM #9
limamike's Avatar
Real Name: Dave
limamike's Avatar
Real Name: Dave
I just pulled-out the front grille, and did a test with it behind the grille. I think I like it that way, but I bought all of the hardware you recommended to me in PM, so now I'm conflicted!
I think I'm going to run it mounted behind the grille for a bit and see how I like it. Should have pics up this evening.
Old 06-14-2012, 12:29 PM #10
JayBe's Avatar
JayBe JayBe is offline
JayBe is on a distinguished road
JayBe's Avatar
Wow that set up looks great! Can we get a night shot possibly?
2011 SR5 Magnetic Grey, Remote Start, Jaba BT., Yakima 4-Bike bike rack
JayBe is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 03:51 PM #11
Btm02144's Avatar
Btm02144 Btm02144 is offline
Btm02144 is on a distinguished road
Btm02144's Avatar
how difficult is wiring and installing the switch?
Btm02144 is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 03:54 PM #12
limamike's Avatar
Real Name: Dave
limamike's Avatar
Real Name: Dave
How good are you at wiring things? If you know how to route wires through a firewall, and plug a female spade connector onto a male spade connector you'll have no problem wiring them. It's literally plug and play.
Old 06-14-2012, 03:54 PM #13
SOcalTRAIL's Avatar
SOcalTRAIL SOcalTRAIL is offline
SOcalTRAIL is on a distinguished road
SOcalTRAIL's Avatar
Run the negative to a ground. Run the positive to either a switched or constant 12V source, run the harness to the cab through the firewall. Pretty straight forward.
~~~2011 4Runner Trail Edition w/KDSS~~~
Icon - Vision-X - Rigid - Gobi - Hi Lift - V-Leds - Bud Built - Shrockworks - Husky Liner - Viair - Odyssey - Total Chaos - Cobra - Hankook - Firestick - Contura - Intelligent Battery System - CDT - AFE - Yaesu - Line-X - ARB - MY BUILD THREAD!
SOcalTRAIL is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 03:56 PM #14
4-Ripcord's Avatar
4-Ripcord 4-Ripcord is offline
Real Name: Jim
4-Ripcord will become famous soon enough 4-Ripcord will become famous soon enough
4-Ripcord's Avatar
Real Name: Jim
I demand output shots!
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
4-Ripcord is offline   Reply With QuoteReply With Quote
Old 06-14-2012, 06:53 PM #15
deekoi's Avatar
deekoi's Avatar
Can't just take my word for it?! BRIGHT! haha
I'll take some pictures tonight
Rigid had everything all set, relay, fuse, & switch all done. IMO, very easy to connect everything. I have mine always hot.
Routing to the cabin was easy too, get a separate wire, tie one end to a screwdriver, tie the other side to the wires and tape it up, then slowly worm your way in with the screwdriver. You'll realize it's very easy when you do it.
As limamike said, plug and play.
Change out stock 6-spoke 15" steel wheels for stock aluminum 16"? BReel 3rd gen T4Rs 2 09-19-2010 03:19 PM
"TRAC OFF" light + "VCS TRAC" light +"check engine" light... arkrunner 3rd gen T4Rs 8 05-29-2009 05:07 PM
stock grille chaz Engines / Suspension / Wheels / Tires / Audio / Accessories 9 07-17-2008 08:41 AM
