Originally Posted by terra4r
amp research's boards look very very very similar to the 4runners design, as in they probably made them. Quick look on the site didn't yield results fast enough, but if you found it, at least you could compare.
I checked around on the AMP Research website and toward the bottom of
this page it says the weight capacity of each side is 600 lbs.
I'm sure the capacity is similar for our 4Runners. Toyota had to plan for at least two adult males to be on there at any given time.
