Real Name: Dave
Real Name: Dave
Originally Posted by toyslug
limamike; did you do a write up on that?
No, sorry I did not. It's very straightforward. I purchased the receptacle from Amazon (maybe $9 or so), and it comes with an easy wiring diagram on the back: one terminal for + and one terminal for -/ground. I ran a positive wire from the engine bay through the firewall, down the threshold/kickpanel of the door back into that rear hump. I drilled a 1" hole to receive the new outlet, then simply connected the positive to the positive terminal, and ran a short ground wire from the negative to the top of the wheel well.
Not sure how familiar you are with wiring stuff, so let me know if you need more detail. I might be able to take a couple of more pictures later today.
A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
