Real Name: Dave
Real Name: Dave
Originally Posted by KCcarguy
Well, I sold my third vehicle and I think it's time to go all-out on the 4runner. I've got some newb. questions for you guys: I'm trying to decide between a full TE conversion or steel bumper with TE rockers and rear bumper-cover. What"s the advantage of a steel bumper vs just a winch plate? Steel is obviously more durable, but I'm not sure it would be worth the extra weight up front. Both have recovery points available, both have a winch. I almost wonder if a plastic OEM set-up would be safer in a accident (crumple zones and all). Do airbags still work with a steel bumper? Are there any true practical advantages of steel? Thanks!
I recently had the same decision to make, and I decided to go with a full steel bumper up front. The biggest point in favor of the steel bumper was the approach and departure angle advantage Joneseyyy had when we were out in Moab with his Shrockworks bumper. I think it very much depends on what you call "practical" when it comes to a front bumper because there isn't much practical about it if you don't plan on taking it offroad or you don't work on a ranch. However, around town the steel bumper will obviously give you a much higher level of protection up front if you deal with parallel parking and parking garages a lot. I think the advantages of having a steel bumper in a low-speed collision are apparent. As you mentioned, it gives you some really good recovery points and a super easy way to get in and manipulate your winch.
The weight is certainly a consideration as well. Joneseyyy's truck weighed about 6,200# fully loaded whereas mine was right at 6,000#. With a bunch of aftermarket stuff you're going to have to drive your truck differently, but you get used to it quickly. The good thing for you is that you don't have the roof rack, full steel skids, fridge, etc that Joneseyyy and I both have. So, I doubt you'll be close to 6,000# even with the bumper.
Long story short, if you're considering a steel bumper now and you have the funding available to support it, I can't imagine you'll regret getting one over a front TE conversion. However, if you do a TE conversion and get on the trail with someone that has a steel bumper you'll likely regret not doing the steel bumper when you could have.
A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
