Originally Posted by eptreyg
So, I took the leap and am going from a 2008 Sport to 2013 Limited. I have a mobile rig that I'd like to be able to take in the house for RTTY/Packet. Has anyone done a full side mount against the console on the passenger side?
Question two: What antenna mounts are you using and how have they treated your paint job? Any tricks to keeping the paint job from getting scratched?
73s
Long time listener. First time caller.
Thank you for the best support site on the net. This has done more to sell me on my next truck than my father-in-law, wife or the dealer ever could.
I have been sandbagging for a few months now. Working on saving up for a 4 Runner after the wife shot down the pick-up truck and Jeep. The other alternative I am allowed is a Land Rover Discovery or Defender since she enjoys driving those....all in good time!
I had to post on this thread as someone who is a ham and who does tend to take the current rig into forested areas. My advice:
DRILL THE HOLE!
It only hurts the first time. When you are done you can seek counseling.
Get a real Larsen NMO mount with an NMO 270 antenna. The combination is indestructible and waterproof (and by extension rust proof.) You can mount it either on your roof or hood. Other mounts like those in the fire service between the hood and the quarter panel can work work well if properly installed and sealed.
Some other items:
Mechanically this approach is much safer for you. I have had mag mounts come off at highway speeds from my current 02 Ford Escape (it's what I could afford 6 years ago). These pinch type mounts (couple set screws holding on the antenna to a piece of metal with a strip of aluminum or other metal or just having set screws into the vehicle, will work short term, until you hit a tree or other object (experience here). Then it scratches the paint horribly. Not to mention it cuts through the finish and leaves two tiny areas for rust.
For HF I saw one mount I really liked here. Someone had it mounted on their front brush bar nicely. That is commonly used and, if the guard is welded on, works great. There are plenty of reasons NOT to use the trailer hitch, all due to a lack of electrical or mechanically solid bonds.
Currently I use a Tarheel Model 75 on a mount welded to the back of the truck. With the whip deployed, use a heavy spring in the woods or tie it off to the front of the vehicle. It has survived most everything I hit with it and has an electrically sound connection to the vehicle.
Just my two cents.
Again, thank you and I really enjoy this site. Keep up the great work!
