11-26-2012, 02:39 PM
Winch choices?
I'm looking to put a Budbuilt winch plate on and don't have any idea which winch to go with. A buddy of mine suggested this one, but I will admit I know next to nothing about winches or what to look for other than you need 1.5x your GVW.
Randy
E Tan E Epi Tas
11-26-2012, 02:49 PM
Real Name: Jay
Real Name: Jay
I looked for 1.5x the gross weight and made in the USA.
Synthetic Rope is, in my opinion, superior to steel wire. It's safer and lighter.
I like my Warn M8000-S.
The Warn VR line is cheaper and similar but made in China I believe.
2014 T4R Trail Premium w/ KDSS (Stock, for now)
[SOLD] 2010 T4R Trail Edition (build thread) - 3" Radflo Kit (2.0",600lb)/OME 2889 + Bilstein 5100 - Light Racing UCAs - SpiderTrax 1.25" Wheel Spacers - Total Chaos Cam Gussets/Tabs - PearlJ10 HD/Extended Sway Bar Links - BudBuilt Hidden Winch Mount - Warn M8000-S - 17" Tunda Wheels (SEM Charcoal Metallic) - Goodyear DuraTracs 285/70/17 - BudBuilt Bump-Out Sliders - 42" HiLift+Slee Offroad Yakima Roof Mount - Body Mount Chop
11-26-2012, 03:02 PM
I have been doing some research on this and looking to run the same Budbuilt plate. I agree with mrvandelay on the M8000-S is probably the best option for this application. Not sure if added weight is a concern, but if you were to go with the Smittybilt XRC X20 Comp 8 series winch (an 8000lbs winch also with synthetic line) you'd be looking at approximately 88lbs, whereas the M8000-S is approximately 55lbs. Something worth considering since you're not going with a full front bumper.
2012 Black SR5 4x4, Convenience Package, Auto Dimming/Backup Camera - AVS Vent Visors - Yakima Whispbar Through Bar cross bars - Custom Low Profile Cargo Drawer - Extendable Stubby Antenna - GrillCraft Grille with FJ Toyota Emblem and Matching Lower - 10% rear tint 24% front tint - Tekonsha Prodigy P3 Brake Controller -MetalTech Sliders - Wet Okole Seat Covers - LT265/70/17 Cooper AT3 Load C - Toytec BOSS lift - SOLD
2018 Ford Expedition Max Platinum (current mall crawler) My Custom Dog Crate/Drawer Setup
11-26-2012, 03:09 PM
Real Name: Jay
Real Name: Jay
Also expect to go to Medium Duty coils or crank your adjustable coilovers to compensate for the added weight
11-26-2012, 04:32 PM
I'm planning on a toytec ultimate lift at the same time, would those coils work or do I need heavier?
Randy
E Tan E Epi Tas
11-26-2012, 04:42 PM
Real Name: Jay
Real Name: Jay
Those will work. You may have to preload the spring more to accommodate the weight added by the winch and plate.
11-26-2012, 04:58 PM
I'd get a warn or Ramsey. I have a Shi**ybilt XRC8 right now with a synth line. It does the job, but the clutch gets stuck 99% of the time, so I have to use the remote to spool out.
Andrew
2010 Battleship Grey SR5 4x4
Sweet mod list.
11-26-2012, 05:03 PM
I went with the Warn VR 10,000-S and got the wireless remote control.
However, I switched the line warn synthetic line out for master pull synthetic line with a safety thimble.
I have a lot of pictures of the Warn and Budbuilt plate at this link. http://rhino4runnersuspension.shutterfly.com/pictures
The pictures should help your installation a great deal since BB supplies NO instructions, or even a hint at how it is supposed to be installed. Or even what winches are compatible....
11-26-2012, 05:12 PM
Real Name: Jay
Real Name: Jay
RE: VR Series vs M Series
From some other threads around the internets:
Per Warn, the main differences between the current M8000 and the VR8000 are:
They use a different motor.
They utilize a different gear-train configuration.
They have different hand-held remotes.
The VR8000 uses solenoids in the control pack and the current M8000 uses a contactor.
So I've read countless threads over this and I'm sure this has been posted but I wanted to share with the jeep community anyways. My buddy here in town has finally seen fit to buy a winch, that of course means a new bumper. Since many of us are not made of money price and quality was certainly a consideration. He decided on warn and really there's no better proven brand. So it came down to the vr series or the M8000 like I have. We called warn to see what they said and it was very insightful.
We talked to two reps on different days and they each said that the vr series is designed solely to compete with the other brands lower cost options. It was a business decision to start offering a product in that space. Some people told us the M series was going away. Warn confirmed that is def not the case. The difference between the vr and m is pretty simple. The M8000 can be used continuously where as the vr series can not. So let's say your out on the trail and have either many short pulls or a few long pulls that need to be done. The M8000 is able to be used without delay where as the vr needs to take breaks to let the winch motor cool to avoid any sort of overheating. Both will work and both have the backing of warn's support and warranty but the M8000 according to warn is the better choice. So in short if you want the best bang for your buck, the M8000 is your winner. If saving a few bucks and having a better possibility of not being able to save yourself or fellow jeeper on the trail is more important, go with the vr.
11-26-2012, 06:54 PM
not enough sauce
11-26-2012, 08:10 PM
I use the Warn VR1000-s with a factor 55 thimble. I obviously made a trade-off on my winch. It gets used a handful of times a year, and I can live with a little slower line speed and letting it cool after a long hard pull considering the price differential vs. something top of the line. It is still a Warn; not concerned about reliability.
2010 Trail Edition | Not Stock
Scratching the itch for off-road adventure one weekend, one vacation at a time, taking our Toyota trucks well off the beaten path one day and driving them to work the next! Covering the trucks, the trips, the gear, and the lifestyle.
www.dirtroadtrip.com
11-26-2012, 09:15 PM
Real Name: Sebastian
About winch's, I saw a Champion 10 000lbs winch at Sam's club for 350$.
Would that fit on a 4runner 2011 ? I know it's low budget but all the 10k lbs I saw where I live are 750$ +.
I know prices suck in Canada : /
11-26-2012, 09:23 PM
Originally Posted by H&KRunner
damn sorry to hear that. ive had my XRC 10 Comp damn near 4 years and on two rigs and never had a issue with it. Did you get the lifetime warranty with it?
on my last rig, an 07 GMC 1/2 ton (front/rear bumpers, 4.56s, 6" lift, 35", rear e-locker) the XRC 10 was used for A LOT of long pulls through mud and swamps of GA and SC.
Its not a huge deal to me, just takes a little bit longer depending on the situation. A couple of my buddies ran into the same issue the same day, so i'm guessing its pretty normal. Nah I didn't get a warranty with it, but I did get it for like $200 lol.
Andrew
Sweet mod list.
11-26-2012, 11:22 PM
calcrc I don't think any of us will be able to tell you if that winch fits. Without a link to the specs on it we have no information. You'll have to compare the specs on the winch you are looking at to the ones that are known to fit. Warn 8000 and VR, and the Smitybuilt. Other than that there is no way of knowing. BB certainly does not provide a list of compatible winches. My old superwinch did not fit, by 1/2"
11-27-2012, 12:24 AM
Ok, when I go back to Sam's Club I will take the specs on the box and re-post it on the forum.
