Old 12-08-2012, 08:11 PM #16
mgrande's Avatar
mgrande mgrande is offline
mgrande is on a distinguished road
mgrande's Avatar
Originally Posted by kbaum11 View Post
Recommended PSI is for passenger rated tires not LT or light truck rated tires. PSI on a P rated tire is less to achieve given weight objective LT is much higher.
I am think you have it turned around. LT's can be run at lower psi
2011 DCSB TRD Offroad, kings front and rear, TC UCA's, All Pro leafs, Timberin bumps, Relentless front bumper, CBI rear bumper and sliders, and other goodies
mgrande is offline   Reply With QuoteReply With Quote
Old 12-08-2012, 08:27 PM #17
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
I think you have it turned around. I run my e-rated LT KM2's at 44psi and have worn perfect.
Where's JB. ? http://www.toyota-4runner.org/genera...-pressure.html
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 12-08-2012, 09:54 PM #18
mgrande's Avatar
mgrande's Avatar
I did. But I still think 55 psi is crazy high
Old 12-09-2012, 02:49 PM #19
BEAST-IV BEAST-IV is offline
BEAST-IV is on a distinguished road
Yep. 55 psi in a 4Runner will rattle your teeth out. The tire shop set the tires at that psi and I could feel every pothole and rock...it was bad.
2010 4RUNNER TRAIL W/KDSS
1982 BJ42 - NZ SPEC
BEAST-IV is offline   Reply With QuoteReply With Quote
Old 12-09-2012, 06:49 PM #20
Koz's Avatar
Koz Koz is offline
Koz is on a distinguished road
Koz Koz is offline
Koz's Avatar
Through the years I have experimented with tire pressures on many LT and passenger tires for many different vehicles (SUVs, Pickups, motorcycles, hotrods, travel trailers). I demand a lot out of tires because of the way I drive. That said, I have found that using higher pressures (all within OEM specs) has provided better performance, mileage and still got the rated tread wear. For passenger tires (on 4500 to 5500 lbs 4x4 SUVs) I found 38 to 40 psi is best and with LTs 50 to 55 psi. Also each tire (model) will have their pros and cons. I have found that tire reviews by owners will give you a very good idea of each tires pros and cons. Not to push any one tire on anyone but the Michelin LTX MS2 LTs are in a class of their own (the passenger tire is also top rated). I'm running them at 55psi and they ride better (handling) and smoother then the OEM Passenger HPs. They weigh 15 lbs more and are and 1.5" bigger in diameter and still maintained the same gas mileage. I attribute that to the greenX rating and running them at 55 psi.
Try running the higher pressure for a couple weeks, you can always drop the pressure if you don't like it!
Koz
Koz is offline   Reply With QuoteReply With Quote
Old 12-10-2012, 02:16 PM #21
Greg_Canada Greg_Canada is offline
Greg_Canada is on a distinguished road
Koz
I get good mileage with my ltx m/s2's at the factory PSI (32psi or w/e)... i've gotten up to 10.9 L/100km highway, average 11.5 L/100km in the summer....
Greg_Canada is offline   Reply With QuoteReply With Quote
Old 12-10-2012, 05:54 PM #22
harper7's Avatar
Real Name: Gary
harper7's Avatar
Real Name: Gary
I agree 55psi seems high but alot depends on the tire and personal preference too. When I was running the 285/70/17 Duratracs I ran them at 50psi as the sidewall felt soft from what I was used to and the tread contact on the ground was still good at that psi.
Need to chalk them or just check your tread contact on the garage floor as you pull in the dry garage from wet and raining outside . If you have too much air in them you can actually see the outside lugs are not wearing.
That,personal road feel/comfort and if they are wearing uniform makes it so there is more then one absolute exact tire pressure IMO.I experiment with new tires to see what works for me and I could probably get better gas mileage running higher pressures but sacrifice comfort.44 psi seems to be my sweet spot with E rated KM2's.
2001 Tacoma TRD 5sp
4.56 , e-rated , re-gear , regear , trail
2010 4Runner Trail Edition or 2013 FJ Trail Teams mideastbeast61 5th gen T4Rs 22 11-11-2012 03:31 PM
2010 Trail vs. 2012/13 Trail Big Lou 5th gen T4Rs 25 10-04-2012 05:33 PM
NIB: 67" Trail Gear Rock Sliders xskydivingdudex For Sale: T4R Items 14 09-29-2012 01:06 PM
New Trail-Gear rock sliders shiftmx For Sale: T4R Items 3 02-09-2012 10:39 AM
Off-Road Trail Gear? rdgt4r 3rd gen T4Rs 4 12-29-2008 07:18 PM
