12-21-2012, 10:39 PM
Sound deadening -- WOW!!!
I finished installing sound deadening to the main cabin floor and doors last night and took it for a test drive today. I drove on city streets, freeway, rough streets and a gravel road. The difference is night and day. The entire drive I was trying to convince myself that I was imagining the difference but even allowing for wishful thinking it is much quieter. Tapping on the outside gives a nice dull thud with no resonance at all. The stereo's bottom end also sounds better even with stock speakers, probably do to the Ensolite. I only wish I had taken SPL measurements before and after to have an accurate comparison.
Here's what I added:
Floor: One layer of RAMMmat. I still need to do under the center console but that will happen when I pull the console to install switches and other goodies.
Door Outer skin, One layer of RAAMmat and one layer of Ensolite. I left a good inch at the bottom for the weeping holes and didn't go over the horizontal brace bar to make sure and moisture didn't get trapped. I did put a strip on the front of the brace bar to deaden and vibration it picked up.
Door Inner skin: One layer of RAAMmat. I pulled it tight over the holes instead of re-using the factory plastic film.
I estimate the weight added to front doors is about 3 lbs., the rear doors have less of course.
I can hardly wait to do the roof, cargo area floor, side panels and lift-gate. I also need to find some filler mat to go on the back of the panels and behind the roof liner. For that I want some sort of thick synthetic felt or other matting that will help more with temperature than sound.
This space for rent.
12-21-2012, 11:20 PM
So how long did it take, and what $$ do you have invested??
Thanks!
12-21-2012, 11:32 PM
so you just pulled the carpet for the floor deadening?
curious on cost as well... tired of hearing the ticking of my engine
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
12-21-2012, 11:58 PM
This is on my list as well. Although I think I will just drop it off at Duc's shop. Sound deadening is one of those things that seems like it would be extremely tedious and time consuming.
2010 T4R LTD - Loaded
My Build Thread
12-22-2012, 12:11 AM
seems like it. I know there's a lot more electrical connections and tabs etc on fifth gens versus my second, though.
I used to entirely strip out the interior of my focus every weekend (minus the dash and drivers seat) got pretty good at it... 20 minutes in or out. the 94 seems easier.
12-22-2012, 12:12 AM
Yes, I pulled the entire rear seat, front seats I did one at a time. trim panels then pulled the carpet up and laid down the RAMMmat. There's a LOT of cutting and fitting to get around all sorts of things. I also am going to need a new pair of kitchen scissors.
Doors I did each in an evening, about 2.5-3 hrs a piece.
Floor about 8 hours. Times include disassembly, install and reassembly.
Cost, I'm not sure. I purchased it back in the spring and got enough to do everything. If I recall, I spent about $200.
[EDIT]
Rethinking the coast, I'm pretty sure that $200 is WAY low. I vaguely remember joking with friends back in the spring that I had $500 worth of deadening sitting waiting to get installed, so I'm going to up the cost to $500.
[/EDIT]
12-22-2012, 12:15 AM
that's not bad at all
12-22-2012, 12:54 AM
It is tedious and time consuming, which equates to labor costs. Figure I've got about close to 20hrs into so far and I still have the roof, tailgate and entire cargo area to do. I don't know Duc's labor rates but at $50/hr for labor that $1000 plus materials for the floor and doors.
12-22-2012, 01:07 AM
Ha I don't know if it will be that bad. I have a friend that just opened his own car audio shop and he quoted me $700 for .60 Accumat for the floors from the cargo area to the pedals (including rear wheel wells) as well as trunk lid and inner and outer in all 4 doors. He's charging me $400 for parts and 50 cents on the dollar for part cost for labor (about $200) plus tax. I'll probably go that route because of the labor intensity and I'll combine it with new speakers, new head unit, and wiring since all the panels are already off. Can't wait to do it.
2012 Black SR5 4x4, Convenience Package, Auto Dimming/Backup Camera - AVS Vent Visors - Yakima Whispbar Through Bar cross bars - Custom Low Profile Cargo Drawer - Extendable Stubby Antenna - GrillCraft Grille with FJ Toyota Emblem and Matching Lower - 10% rear tint 24% front tint - Tekonsha Prodigy P3 Brake Controller -MetalTech Sliders - Wet Okole Seat Covers - LT265/70/17 Cooper AT3 Load C - Toytec BOSS lift - SOLD
2018 Ford Expedition Max Platinum (current mall crawler) My Custom Dog Crate/Drawer Setup
12-22-2012, 01:12 AM
Well you have to remember, those guys do that stuff probably every day. they know the shortcuts.
12-22-2012, 01:43 AM
Seems like alot to just deaden the sound. I guess I'll just turn my stereo up lol congrats though that deff determination to take on that job.
12-22-2012, 01:44 AM
Sounds like a lot of work but well worth it I'm sure. Did the outer skin and got rid of the tin can sound a while back. Based on your experience, I'll be adding ensolite and then take on the floor. Tailgate is a pita. Very cramped. Did you mat the inside of the inner skin or the outside? For stereo, inside probably more effective but seems like another pita.
12-22-2012, 01:54 AM
Originally Posted by G8RB8_12SR5
I have a friend that just opened his own car audio shop and he quoted me $700.
Exactly. There is a HUGE difference in understanding the concepts of the fabrication process and actually being proficient in materializing those concepts (this is true of most anything). Unless you actually strip interiors on a regular basis - you'll never match the speed AND precision of a pro-installer's sound deadening capabilities and efficiencies IMNSHO. It took me over 14 days (spread out over a month +) to complete the audio install in my T4R (almost done!) - and I STILL had to out-source a few items to a "pro"! I took some vacation time and used up my weekends, so you have to consider the "cost" of that as well (used up lots of benefit time and general "free time" due to my inefficiencies that a "pro" would have done in 1/4 the time)...
"DIY" in any capacity isn't generally looked at as a time-saver (any "pro" will generally destroy a shade-tree DIY'er in efficiency and experience). If your time is worth more than what you'd pay someone to execute the task at hand, then go ahead and pay them to do it! Or, go-ahead and DIY if you you are really into "being a part of" your install and the associated self-gratification rewards (assuming your capabilities are up to par). I'm in with the latter for sure - this is the first time I've paid anyone for their audio installation capabilities in my 20+ years of car audio...
Randy V
2013 4Runner * SR5 * 4x4 * Leather * Convenience Package * Black-on-Black *
* BFG KO LT265/70R17/C * SR5 Wheels + SpiderTrax * 5100's @ .85" * GrillCraft Grill Mods & TOYOTA Emblem * H9 & H9011 Headlight Swap *
* Alpine W910 DVD/NAV + H800 DSP * ARC Audio * JBL * JL * Morel * DieHard Platinum 31M * Total system power = 4,048 Watts RMS ! *
12-22-2012, 02:01 AM
Cabin side, everything bolts to the backside and would require full disassembly to do.
12-22-2012, 02:26 AM
Agreed, that's why I'm paying someone else to do the sound deadening and audio and I'll save my DIY for fabbing a custom cargo drawer. GrantK, glad to hear a good review on this (pun intended), looking forward to when I finally get it done.
