Old 01-26-2013, 12:17 AM #1
PopsSmith PopsSmith is offline
PopsSmith is on a distinguished road
Bilstein 5100 w/Eibach Springs
Got the springs and shocks today. After doing a bunch of reading, I think I am even more confused on which setting the Bilstein 5100s should be set at with the Eibach springs. So far I have read the bottom setting or the middle setting. I know the springs alone are supposed to give 1.6" of lift. Looking for around 2.5" to 3" lift. Any help or guidance would be much appreciated. Thanks.
PopsSmith is offline   Reply With QuoteReply With Quote
Old 01-26-2013, 12:03 PM #2
Bump. Does anyone know or am I going to have to do trial and error?
Old 01-26-2013, 08:29 PM #3
ATL4R ATL4R is offline
ATL4R is on a distinguished road
I ran this setup for a good while. I was sitting at 36.8 inches at the fender on 265/70 tires. That was on the LOWEST setting. I wasn't interested in added any pre-load to the springs. The setup ran great with no additional weight up front... it had a nice ride and handled well.
I added a shrockworks bumper and a winch later and it lowered it about .5 inches but the ride suffered a lot - it was very harsh. Switched to the Old Man Emu setup and it's riding good again.
2011 Trail Edition (Black) -/- Front Suspension: OME 2887 on 90010 OME Struts -/- Rear Suspension: OME 889 with 60080 OME Shocks with Stone Guards -/- 285/70R17 BFG KO Load Range D -/- CounterSteer X Wheels -/- SPC Upper Control Arms -/- Shrockworks Sliders -/- Shrockworks Front Bumper -/- WARN M8000s with Synthetic Line -/- Full BudBuilt Skids -/- ConsoleVault -/- CBI Rear Bumper -/- Infinity Dash Speakers -/- 3rd Row from a Limited -/- WeatherTech Floor Liners -/- 20% Tint -/- Roof Rack Delete -/- Trimmed 6" off Factory AM/FM Antenna
ATL4R is offline   Reply With QuoteReply With Quote
Old 01-26-2013, 08:36 PM #4
Ducmonsta's Avatar
Ducmonsta Ducmonsta is offline
Ducmonsta will become famous soon enough
Ducmonsta's Avatar
I would recommend contacting Toytec as this is what they use in one of their kits. The Eibach spring rate will also determine overall height.
Ducmonsta is offline   Reply With QuoteReply With Quote
Old 01-26-2013, 09:13 PM #5
Going to wait and call Toytec on Monday especially since they sent me the wrong rear springs and one rear shock wrong. Definitely a pro now at removing and installing the XREAS system with no loss. Thanks for the inputs.
Old 01-27-2013, 10:13 AM #6
homeyclaus's Avatar
homeyclaus homeyclaus is offline
homeyclaus is on a distinguished road
homeyclaus's Avatar
Arguably if you add the lift amounts together you'll get close. The four positions on the front Bilsteins are 0", 0.8", 1.5" and 2" of lift respectively. Add 3.6" or whatever the Eibachs have and you'll be pretty close, up to the maximum extension supported by the shocks.
And new springs will settle some, so if you have a choice between .5" high and .5" low, go high.
'13 Spruce Mica Tundra CM 5.7L Trd, EXP1 front bumper, Transforce AT LT275/70R18s, White Knuckle Sliders, Leer 100XL cap w. Wilderness Package, Line-X.
Sorry, I can't help but think less of you when you won't take the time to spell things right or use proper grammar. Deal with it. I don't care if you're ESL either, because I am too.
homeyclaus is offline   Reply With QuoteReply With Quote
Old 01-27-2013, 03:33 PM #7
H&KRunner's Avatar
H&KRunner H&KRunner is offline
H&KRunner is on a distinguished road
H&KRunner's Avatar
second notch (.85) is the highest you can go w the eibach springs. i ran that set up for a few thousands miles and it was noticeably stiffer then stock but still a comfy ride.
like mentioned above, the set up rides and performs good for a stock weight vehicle. when i add the BB hidden winch mount + winch and sliders the front it dropped.
ETA i believe i was at 2.5" w this set up.
H&KRunner is offline   Reply With QuoteReply With Quote
Old 02-17-2013, 03:25 PM #8
Thanks for the replies. Got the springs, struts, and shocks installed yesterday. Went with the second notch and everything leveled out pretty well. Definitely happy with the ride quality, better than XREAS, and the height.
Old 02-17-2013, 04:23 PM #9
H&KRunner's Avatar
H&KRunner's Avatar
nice! but where are the pics?!??! lol
what rear set up did u go with?
Old 02-17-2013, 06:58 PM #10
Oh how did I know that was coming. Here you go.
Rear springs are: 2" Rear Lift "Superflex" coil springs. They haven't completely settled yet so they are a little high.
Old 02-17-2013, 11:37 PM #11
H&KRunner's Avatar
H&KRunner's Avatar
truck looks great. good job.
Old 02-18-2013, 12:32 AM #12
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Ultra Gauntlet?
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 02-18-2013, 10:12 AM #13
Originally Posted by Jono.ful View Post
Ultra Gauntlet?
Yep. 18x9
Old 03-09-2013, 11:55 AM #14
Jono.ful's Avatar
Jono.ful's Avatar
Yep. 18x9
Did you reuse your stock tpms sensors? Just about to pull the trigger on a set of Gauntlets and I'd rather not have to shell out for new sensors.
Old 03-09-2013, 12:06 PM #15
They were rebuilt and transferred over by discount tire when I had the wheels and tires mounted. Cost sub 50.
Eibach/Toytec springs with Tundra 5100's? hungryeddy 3rd gen T4Rs 44 02-25-2013 04:50 PM
Bilstein 5100/eibach coils 1bad4r 3rd gen T4Rs 7 02-14-2012 04:41 PM
Toytec/Eibach Coils & Bilstein 5100's jrebolloso 3rd gen T4Rs 7 05-23-2011 11:23 PM
Toytec/Eibach front coil lift springs /bilstein 5100 rayny1014 Classifieds - buy & sell (no commercial ads please) 1 05-08-2011 04:30 PM
Bilstein 5100 + FJ springs Or Bilstein 5100 + stock springs Morrobayrunner Engines / Suspension / Wheels / Tires / Audio / Accessories 16 09-23-2010 06:03 PM
