Old 02-10-2013, 01:41 PM #1
optik's Avatar
optik optik is offline
optik is on a distinguished road
optik's Avatar
Exclamation ** HELP PLEASE ** KDSS sway bar reconnect trouble!!
I've finished installing the 2.5" Daystar spacers in the front, and am now trying to reconnect the sway bar.
I can't get the sway bar to move enough to line up to reconnect it. I've read some comments about compressing / jacking up the KDSS cylinder to assist... but I don't understand how to do this.
Can anyone please help? We're completely stuck.
optik is offline   Reply With QuoteReply With Quote
Old 02-10-2013, 01:47 PM #2
optik's Avatar
optik's Avatar
Does something like this exist for the TE? Valve to relieve pressure so that I can move the sway bar around? http://trdparts4u.toyotaofdallas.com...%20system).pdf
Old 02-10-2013, 02:04 PM #3
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
DO NOT release any valves! This will cause a major and expensive headache requiring dealer service according to several threads I have read. Put a floor or bottle jack under the KDSS piston on the drivers side of the vehicle. It looks like a shock boot attached to the sway bar. Jack it slowly up to lower the passenger side of the sway bar enough to reattach. You may also have to use a ratchet strap to pull the bar back towards the lower A arm. I had to do this when installing my front Bilsteins.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 02-10-2013, 02:54 PM #4
optik's Avatar
optik's Avatar
Ok, I've got that going. Driver side attached fine, but the top bolt on the passenger sway bar bracket won't line up even with much prying with a screwdriver via the alignment holes on the top of the bracket.
Anything I'm missing to make this easier?
Old 02-10-2013, 02:58 PM #5
Vegas's Avatar
Vegas Vegas is offline
Vegas is on a distinguished road
Vegas's Avatar
Do a search for SoCalTrail and KDSS help... Not sure who he was giving instructions to but I used them and the KDSS went on in 5 mins.... And the KDSS was what i expected to be the hardest part of the install... Find the post it is step-by-step and is way better than my memory....but here goes: with the truck in then AiR attach the passenger side first then put on tires and drop car to the ground and jack up under KDSS piston(front driver side) use blocks of wood to get the jack high enough and you can also try using a wretched strap to help muscles it in place if you're solo....then all you do is take a big punch and stab it in the guide hole to line it up so you can get the first bolt started...
Good luck
2012 Toyota 4Runner Trail, Black, NAV & KDSS My build thread:
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Vegas is offline   Reply With QuoteReply With Quote
Old 02-10-2013, 03:17 PM #6
optik's Avatar
optik's Avatar
Found it - Help - Installing Icon lift on TE w/KDSS
Hopefully it'll help someone else in the future.
I haven't done the back spacers yet, but am hesitant now because I can't find any step-by-step guides for rear suspension spacer/lift installs. :/
Old 02-10-2013, 05:29 PM #7
optik's Avatar
optik's Avatar
Still having trouble getting the passenger top bolt of the sway bar bracket to line up.
The bolt won't line up and thread properly. Driver side wasn't a problem. Not sure what to do.
Old 02-10-2013, 05:33 PM #8
Go JayBee's Avatar
Go JayBee Go JayBee is offline
Real Name: Joe Bloomstone
Go JayBee is on a distinguished road
Go JayBee's Avatar
I coulda swore I just read: do the passenger side 1st, put tires back on, then jack up under drivers side, etc.
2012 Trail Edition, Magnetic Grey, NAV, EnTunes, KDSS, Factory Running Boards, Stainless Exhaust Tip, HuskyLiner Weather Beaters, CravenSpeed Stubby, Toyota Emblem Black-Out, Ifinity Kappas throughout, LED Upgrade for Interior, LED Exterior: Tail/Brake, Reverse, Rear Turn, Front Turn/DRL, & Front Parking. Built-In Compressor (AntMan Style), Painless Fuse-Box, Cup Holders (AntMan Style), LED Under Hood Lights, NAV Override, Hella Horns x 4!!!
I've been a T4R owner since 1997....
Go JayBee is offline   Reply With QuoteReply With Quote
Old 02-10-2013, 05:37 PM #9
optik's Avatar
optik's Avatar
Right, the brackets are both in place, and the bolts on the driver side are good.
The passenger side bracket's BOTTOM bolt is fine, I'm just having trouble with the TOP bolt of the passenger sway bar bracket. So, 3 out of 4 are ok, just having trouble getting one to line up so that it threads properly (and as easily as the other 3 did).
Old 02-11-2013, 12:07 AM #10
STLDAVE's Avatar
STLDAVE STLDAVE is offline
STLDAVE is on a distinguished road
STLDAVE's Avatar
This was a pain when I did mine too. Without actually seeing your install all I can do is offer a couple of suggestions of thing to check.
Are you sure the bracket is on the sway bar correctly? Does it match the other side?
Have you tightened the bottom bolt already? If you back it out until there are only 2-3 threads still in the hole, then pull the bracket away from the lower control arm might give you enough play to get the top bolt started.
It may take a while, but if the bottom bolt is started the top one will line up. You just need to figure out how to get enough play in the bracket to pry it into a position that will allow the top bolt to start.
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
STLDAVE is offline   Reply With QuoteReply With Quote
KDSS Sway Bar Prevents Oil Change? prplegophr 5th gen T4Rs 12 04-04-2018 10:24 AM
TE w/ or w/o KDSS...Should I go new? Goyo 5th gen T4Rs 30 02-28-2013 01:36 AM
Does anyone know where any TE are w/ kdss+nav Wakeborder556 5th gen T4Rs 13 02-28-2012 06:05 AM
Trouble finding a TE without KDSS Ben_Mueller 5th gen T4Rs 17 10-18-2010 11:23 PM
Waking from winter storage: Battery reconnect txtroutbum Classic T4Rs 0 06-04-2007 06:28 PM
