03-01-2013, 11:35 PM
Nightshade Disaster
I wanted to tint my lenses on the runner. I decided to start with the DRL, had them out and washed and everything, got cold feet. So I wanted to start with something smaller. Tried the puddle lenses in the bottom of the mirror. Turned out horrible. So I need new ones, can't find the part number. Looked on a few parts sites mentioned. Any help fella's? Next question, what else can I do besides nightshade since I suck at it?
03-02-2013, 01:08 AM
Haven't used nightshades myself but have been researching. Those who rave about it have done one thing in common. Surface prep. Very thorough surface prep including wet sanding and compounding. What prepping did you do? For that matter, what was horrible about your results?
Others have used vinyl wraps with much success. I don't know how much curves the lights can have before it becomes too difficult to wrap. I used it on fairly flat lenses a couple of years ago and it was super easy to apply and squeegee. The vinyl available today is supposed to be much better than what I used. More durable, more flexible and easier to apply.
Good luck!
03-02-2013, 01:23 AM
Real Name: Gary
Real Name: Gary
Not cheap for new ones!
Mirror Lamp, Signal
R- 81730-52071 $112.14 msrp
L- 81740-52031 $112.14 msrp
About $80 a piece at Camelback Toyota online... Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
and $84 a piece at Toyota of Dallas... Toyota Part Sales of Toyota of Dallas
Not easy to change either.You should be able to just wet sand them out back to original finish and most tint shops can tint them for you if you don't want to do it yourself.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
. ...........Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
03-02-2013, 02:42 AM
Real Name: Jake
Real Name: Jake
There are a few people on dipyourcar.com that have used one or two light coats of plastidip to darken the lenses. Not sure how it would work for you...
03-02-2013, 07:39 AM
Originally Posted by harper7
I think he meant the puddle lights!
2011 TE KDSS NAV- K&N drop-in, Toytec/Eibach, Bilstein 5100's, Diff Drop, 295 Cooper STT Pro, OPOR Sliders, 17X9 XD Addicts, Sonoran Steel Panhard Bar, SPC UCA, RCI Skids
'97 Corolla, 90 Alltrac Celica, 94 Camry, 99 Solara 5spd, 98 GS400, 93 Accord, 97 Avalon(current daily), 2010 T4R LE sold, 2011 T4R TE
03-02-2013, 12:43 PM
Ye it was the puddle lights
03-02-2013, 02:59 PM
5th Gen Moderator
5th Gen Moderator
these can be fixed!
wetsand them as much as you can, they should almost be clear again when you're done. reapply the VHT until they are your desired darkness.
at what point did you decide they were ruined? VHT does't look its best until you clear coat, then wax and polish.
this is the DIY I've always used. follow to the letter and you'll be happy!
How to Smoke Taillights - Nissan 350Z & 370Z Wiki
Originally Posted by 7harper
First 5th with real CO's
2017 White TRD OR, Icons, BFG Mud-Terrains, Konig Countersteer, Retro Headlights, Gobi stuff
03-02-2013, 07:18 PM
I used the Nightshades tint on my taillights and had to sand and buff the high parts off so they could be seen at night. I think they look a lot better than stock now.
2011 4x4 SR5
American Racing ATX Slot Chrome, Cooper ZEON ltz LT285/70/17, Toytec Ultimate Lift, Trail Headlights, Custom tinted taillights
03-02-2013, 07:37 PM
They just look like crap when lit up. Maybe it will help a little if I put led bulbs in.I want to do those but can't keep them straight and figure out which ones I need. I'll try what Jesse said.I did clear them and prep them correct. Honestly another problem I had was to get a nice even coat they are just black. Don't know why couldn't get it to come out smoother.
03-02-2013, 08:07 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
Originally Posted by Jesse1983
these can be fixed!
Go to Jesse's build thread and look at his results. He did a great job!
03-02-2013, 11:31 PM
Real Name: Gary
Real Name: Gary
Doh!!oh ,de poodle lamps! lol
I searched a couple of parts catalogs and most of the diagrams and the parts manual I have and it looks like those come with the outside mirror cover. They are #4 in the picture and are pretty cheap at $36.23, just have to match your color and with or without w/o signal lamp(turn signal). If you still really want new ones then call the parts dept and ask them to be sure.
SR5 Outside Mirror parts
2001 Tacoma TRD 5sp
03-03-2013, 12:11 AM
Thanks harper. I might try to salvage them. Study a few more examples and how-tos. This is hard for me as I am usually pretty good at this stuff. If not thanks for the help in finding them. Might get a new set anyway.
03-03-2013, 01:53 PM
on a side note... has anyone added the SR5/Limited mirrors with the puddle and turn signals lights in them on to a Trail? i wonder if all the wiring is there for it..
03-03-2013, 02:29 PM
Moderator
Real Name: Greg
Moderator
Real Name: Greg
I'm pretty sure they didn't put them on the TE because if using the TE as intended, you usually hit stuff with the mirrors, hence the unpainted finish. I am off road quite a bit (no rock crawling) and I have hit lots of bushes and twigs with the mirrors.
Your question if they included the wiring for the additional lights - I would say probably not. Everything else about the wiring harness has been model and option specific. That is, no additional wiring or plugs for options has been found so far. If you have a base radio then the wiring does not include a plug for nav. If you don't have a heated windshield the wiring is not there for it either.
03-03-2013, 02:55 PM
hmm from what you've said, you're probably right i was thinking it could be an easy direct swap... i liked having them on my previous Limited.. granted i may ruin them on the trails lol.. i just think its safer for lane switching and left turns since our front turn signals only face directly forward. thanks for the reply!!
