Old 04-02-2013, 08:10 AM #1
duckman06's Avatar
duckman06 duckman06 is offline
Real Name: Adam Whatley
duckman06 is on a distinguished road
duckman06's Avatar
Leveling Kit Question???
I just had the Daystart 2.5 front leveling kit installed and while it looks great it makes the back look lower then expected. It just like it offset it by rasing the front and then lowering the rear. I know that is not what happened but just wanted to give a mental pic.
My question is will this leveling kit settle down somewhat once it is driven and front end is alligned? The company that installed said it should after a while? So what if anything can be done to this and or what are you guys doing to offset the diffreance? I was thinking could get the rear kit also but then I am right back to sqaure one with the back being higher then the front.
As it stands right now looks good but again you can tell that it is not level but just by a little bit as the rear end looks lower. Please any help with this would be great.
thanks
2008 Toyota Tundra 4x4
2013 Toyota 4 Runner
duckman06 is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 08:17 AM #2
5POINT56's Avatar
5POINT56 5POINT56 is offline
5POINT56 is on a distinguished road
5POINT56's Avatar
You're talking about the kit that also levels the back by 1.5"?
5POINT56 is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 10:59 AM #3
duckman06's Avatar
duckman06's Avatar
No just the front leveling kit Daystar 2.5 was installed!
Old 04-02-2013, 11:13 AM #4
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
Then that's a problem as most guys go up to a max of 1.75 to level and .85 for a little rake. 2.5 might be truly level but could give the impression of backwards rake because of the body lines.
1engineer is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 12:13 PM #5
moconst moconst is offline
moconst is on a distinguished road
thanks
can u post a pic?
2013 metallic silver SR5 4x4 (wife) daystar 2.5f 1.5r, ultra guantlets w/ 265/75/17 cooper stt
2012 Ram 2500 diesel (me)
moconst is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 12:45 PM #6
Stifler Stifler is offline
Banned
Stifler is on a distinguished road
Banned
get a cornfed 1" rear coil spacer kit and call it a day
Stifler is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 12:56 PM #7
duckman06's Avatar
duckman06's Avatar
where do you get that from?
Old 04-02-2013, 01:12 PM #8
I pm'ed you but doesnt seem to be going thru
Old 04-02-2013, 01:23 PM #9
FatTiresRollin's Avatar
FatTiresRollin FatTiresRollin is offline
Real Name: Brian
FatTiresRollin is on a distinguished road
Real Name: Brian
Definitely will have reverse rake w/ only a 2.5" front spacer. I have 2.5" of lift in the front and then the 1.5" Daystar rear spacer to level everything out....
A front only leveling kit should not lift more than 1.5" or so. You may notice that all the lift and/or leveling kits advertise that they raise the front about 1" more than the rear. That is why you will see them labeled as a 2.5/1.5 leveling kit or a 3/2 lift kit.
In the end you have 2 choices to correct the problem. Install the 1.5" spacer for the rear or swap your front 2.5" spacer for something 1.5" or less.
2011 Blizzard Pearl SR5 4Runner, AMI 12" Big Stick Antenna, Rocker Panels Removed, Yakima Load Warrior w/ Extension, Plasti-Dip Black Out, Bilstein 5100s On All 4 Corners (Front @ 2.5" Setting) and Toytec Superflex rear coils, 285/70/17 Falken Wildpeak A/T3W, LR UCAs, Front Air Dam Removed, Level 8 MK6 17x8 with 0mm Offset, BudBuilt Bump-Out Sliders
FatTiresRollin is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 01:54 PM #10
Banned
Banned
03-09* Toyota 4Runner Cornfed Suspension Lift kits
scroll down to custom size. 1" is in stock and shipping just talked to him yesterday
Old 04-02-2013, 04:04 PM #11
duckman06's Avatar
duckman06's Avatar
Thanks for the input. I just ordered the 1.5 inch rear kit from them. Also pictured below is the way it looks now.
Another couple of questions. 1. since will have 2.5 leveling kit on the front and 1.5 on the rear. 1. What are biggest size tires can I run without rubbing or causing problems? 2. This is stupid but i have to ask, Do i have to have the rear end alligned after the install of the 1.5 inch rear leveling kit? 3. Will there be any problems with running 2.5 daystar up front and cornfeed 1.5 in the wear.
Thanks to all who helps and who will be helping.
Leveling Kit Question???-photo-jpg
Old 04-02-2013, 05:32 PM #12
Banned
Banned
1. you can run 285s with minor inner fender modification 2. NOPE 3. NOPE
Old 04-02-2013, 07:29 PM #13
Newf4R's Avatar
Newf4R Newf4R is offline
Real Name: Tom
Newf4R is on a distinguished road
Newf4R's Avatar
Real Name: Tom
The rear wouldn't need to be aligned as well after the 1.5 lift installed?
OP, check out the many lifted T4Rs in this thread. You will notice many people post their specs in their signatures. May give you a better idea of what you want yours to look like.
Post your LIFTED pix here!
'15 Tundra TRD 5.7 Crew Max TRD Pro conversion, XD Addict 18x9 Matte Black
'12 4Runner SR5 w/ Upgrade Package: Mickey Thompson Baja STZ 265/70/17, Bilstein 5100s (front:2.5" rear:1.5" daystar spacers) SOLD
Newf4R is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 07:38 PM #14
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
thanks
Ya, you need the rear spacer to complete the kit to make it close to level .A rear spacer is a rear spacer is a rear spacer and not much technology involved with about 10 different people making them . Here is the rear one by Daystar that goes with the front one you installed......Daystar KT09127BK Comfort Ride 1.5" Rear Coil Spring Spacer Kit : Amazon.com : Automotive
And here's the whole kit..... http://www.daystarweb.com/productdet...productID=1236
http://www.amazon.com/Daystar-KT0913...ords=KT09134BK
And you will need an front end alignment any time you do a lift or the camber and toe will be off. No rear alignment needed as it's a straight axle and the rear alignment won't change much.My rear tires have shown no effect in 50k miles since a lift but I do rotate them every 3k miles.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 04-02-2013, 09:18 PM #15
duckman06's Avatar
duckman06's Avatar
And here's the whole kit..... Daystar? - Driven by Design
Daystar KT09134BK Front and Rear Suspension Lift Kit for Toyota 4Runner : Amazon.com : Automotive
Harper7,
Thanks for the info. I wished I would have talked to you earlier. As someone posted above about cornfeed rear kits and I called and ordered that rear kit for $120 and has already been shipped what a rip off then. That's what I get for not doing my homework.
Man oh man what a day!!! All I can do is laugh or throw up. oh well time will go on. I have already had my front end aligned today right after install of front leveling kit. Plus I am good at keeping tires rotated, pressures correct etc...
As far as tires go without rubbing and or cutting is there any bigger tires that will work weather it be wider or taller? I will be keeping OEM rims. Again thanks for all the help and guidance!
Shock Leveling Question - SR5 agjake01 5th gen T4Rs 0 01-29-2013 06:11 AM
leveling kit question deedst4r 4th Gen T4Rs 7 07-09-2011 02:48 PM
Leveling Question jlm6985 4th Gen T4Rs 5 04-21-2011 10:31 PM
leveling kit question......help!!! matthewy03 4th Gen T4Rs 37 06-24-2010 02:28 PM
Another lift/leveling question.... mtnc 4th Gen T4Rs 2 02-08-2007 09:52 AM
