04-16-2013, 07:23 PM
Door panel Removal... where is the screw behind the door?
Ok, taking the door panel off should be really easy... Well, I cannot find a picture of the final screw that must be taken off to get the panel off. The ones hidden behind the trap doors are easy, but has anyone seen a picture of the one behind the door panel?
I could not get the panel off and did not see this elusive screw...
Just curious - why did Toyota put an extra screw in behind the panel?
04-16-2013, 07:26 PM
Real Name: Jeff
Real Name: Jeff
http://www.toyota-4runner.org/5th-ge...tml#post774421
HERE FISHY FISHY FISHY!
04-16-2013, 08:41 PM
Removable panel behind the interior door handle.
04-16-2013, 09:04 PM
ok... thanks.... I do wish SP8 would have put a picture of this on his photo log... this is the one thing missing... I will try again tomorrow. I was afraid of damaging the panel.
I was under the impression that there was another screw (after you pull all of the exterior screws behind the trap doors) that only became accessible once you pop the panel from the door... Is this correct?
04-17-2013, 01:56 AM
In the front doors, there are 3 screws. The rest is held on with the plastic trim clips. 2 screws behind trap doors, 1 screw behind panel behind the door handle.
04-17-2013, 06:22 AM
Sp8Ball's thread is pretty thorough. Take another look.
2011 SR-5 4x4 w/ TE-conversion:[B] Old Man Emu lift, Light Racing UCAs, ARB skids, Shrockworks step-sliders, Shrockworks front bumper, Custom rear bumper/swingout, Gobi Stealth, ARB awning, ARB compressor, ARB rear locker, Rigid Duallys, Warn M8000, MR301s, Mickey Thompson MTZ, FTS snorkel,
The Overland Adventures @kccarguy Instagram
04-17-2013, 09:56 AM
Thanks... this does make sense... I will give it another shot this week....
04-17-2013, 10:14 AM
Dumb question. What are the "trap doors" considered. Not removing the panel any time soon but just wondering for future purposes.
2011 Magnetic Gray SR5: 3rd Row Seats, Stubby Antenna, AVS Window Visors and Bugshield, OEM Exhaust Tip, OEM All Weather Mats, 20% Tinted Windows, 4300k Hid's, LED Interior and Tag Lights, Black MB TKO wheels with 265/70/17 Nitto Crossteks
04-17-2013, 11:15 AM
Real Name: Jeff
Real Name: Jeff
04-17-2013, 11:16 AM
Real Name: Jeff
Real Name: Jeff
04-17-2013, 11:37 AM
One other thing to make note of.
Remove the weather strip from the top of the panel before putting things back. Then when putting things back together, put the weather strip on the door first then mounting the panel is easy.
This space for rent.
Originally Posted by Antman
Thank you sir! Much appreciate
04-17-2013, 12:00 PM
Grant - did you install a new set of speakers? If yes, what did you put in?
I am going to try to put some JL 6x9s in this week -- swapping out some Bostons that will be moved to our other car... The Bostons sound really good, so I am not sure I am wasting my time
04-17-2013, 12:11 PM
Good tip Grant. I really struggled getting the rear door panels back on. I'll try that next time.....I still haven't fixed my child locks yet.
04-17-2013, 02:11 PM
I put Focal PC690 in the front doors and Focal PC165 in the rear doors. They are powered with an Alpine head unit going through an AudioConcepts DQXS anda JL 900/5 amp (100watts/each door). The speakers required building custom mounts so they would clear the glass and I still have to install the subs but the sound difference is AMAZING already. Crystal clear, nice even reproduction and enough power to make it hurt.
