Originally Posted by jspagna1
Put the 1" (1/2") on the front about 6 months ago and very happy. No need to compress spring. Use the bolts provided with the kit and remove the sway bar out of the way and your good to go. Make sure you get a front end alignment after install.
Sorry to revive an old thread.....but im a little confused. Does the Cornfed 1 inch spacer provide 1 inch of lift after install or is the spacer itself 1inch thick and will yield a 0.5inch lift?
Also did the OP install a front spacer lift and a custom spacer in the rear?
