Old 12-03-2020, 01:38 PM #106
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Originally Posted by IASTATE01 View Post
I have a install question. I have been wanting to do this for a while, but life has other priorities for my money.
I have been wondering if there is an easier way to install spacers using spring compressors or maybe a couple ratchet straps?? Instead of removing all the extra suspension, can you jack up the front, pull the wheels, loosen the top strut mounts, and then just compress the spring enough to slide the spacer in? Am I missing something that would prevent this from working?
I understand that people fear spring compressors because a failure could take your head off, but if you don't disassemble the strut, that shouldn't be an issue.
Maybe the slight binding of the suspension would make re-aligning bolt holes impossible?
Thanks,
Ryan
Absolutely not. You’d have to compress the springs way too far and those autozone compressors are not designed for a strut as it is. It would take you longer to attempt that than it takes to do it right. Put the truck up on jack stands. Put a jack under the lower control arm, remove the 2 lower ball joint bolts, swing the lower control arm down. This will allow the coil over to be fully extended. Remove the lower shock bolt and swing the lower control arm lower and out of the way. Remove the 3 upper shock nuts and the whole shock comes down as an assembly.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 05:46 PM #107
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Originally Posted by 2016 4Runner SR5 View Post
Glad you’re happy! If anyone needs a Cornfed kit, please PM me!
Any difference in ride quality with this small of a lift?
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 05:50 PM #108
Real Name: Chris
Real Name: Chris
Zero, you won’t even know it’s there. PM me if you’d like to place an order!
Old 12-03-2020, 05:51 PM #109
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
A spacer lift with no other changes shouldn't have a noticeable effect on ride quality.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 03:21 PM #110
Cajun_TRD's Avatar
Cajun_TRD Cajun_TRD is offline
Cajun_TRD is on a distinguished road
Cajun_TRD's Avatar
No difference at all in the ride
TRD OFFROAD PREMIUM WITH SOME STUFF BOLTED TO IT
My Fuelly Log
Cajun_TRD is offline   Reply With QuoteReply With Quote
Old 12-18-2020, 11:33 PM #111
phesoj16 phesoj16 is offline
phesoj16 is on a distinguished road
Anyone looking for cornfed spacers please let me know! I am a dealer, all in stock and ready to ship!
How much for 1" cornfed front spacer only?
phesoj16 is offline   Reply With QuoteReply With Quote
Old 12-19-2020, 05:31 AM #112
Real Name: Chris
Real Name: Chris
Feel free to shoot me a text or give me a call 631-202-8245
Old 12-19-2020, 12:54 PM #113
j-dub j-dub is offline
j-dub is on a distinguished road
I installed a Cornfed 1" front spacer lift on my 2021 SR5 last weekend and it worked out great. Easy to install, the ride was not affected and there are no weird creaks or clicking noises. I know it is sort of a cosmetic mod but I like it, I used the simple version that goes on top of the strut top.
Before measurements was 35" from the ground to the front fender opening and 37" to the rear. After the spacer it is 36/37" and to my eye it does not look nose down anymore.
j-dub is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 10:06 AM #114
duketbrd88 duketbrd88 is offline
duketbrd88 is on a distinguished road
Did it help with the front end nose dive when braking? I'm thinking of doing the same thing for now.
duketbrd88 is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 05:30 PM #115
I have read about this concern on here before but on my '21 I don't notice nose diving upon braking, not sure if it is different on different years or it is my driving style. I am actually more concerned that I can bounce up an down on the rear and get the thing to start cycling.
Old 01-28-2021, 01:30 AM #116
PCMSF PCMSF is offline
PCMSF is on a distinguished road
Went back and forth about doing the 1" front lift (Cornfed spacer) versus vs. Eibach Pro Truck lift and I'm super happy with how the 1" spacer lift turned out. It looks really great in person and no noticeable change in driving quality. And only took 1.5 hrs shop labor. New wheels and tires (275s) going on in a couple weeks.
PCMSF is offline   Reply With QuoteReply With Quote
Old 01-29-2021, 12:36 PM #117
Real Name: Chris
Real Name: Chris
Thank you for your order. If anyone else is looking for a kit, please send me a PM or reach out to me at 631-202-8245
Old 02-10-2021, 12:44 PM #118
Got my 1" front spacer on yesterday and some new 265/70r17 KO2s. So happy to ditch those OE Bridgestones
Before:
After:
Old 02-10-2021, 02:00 PM #119
Real Name: Chris
Real Name: Chris
Before:
After:
Looks great! Thank you for your order!
Old 03-03-2021, 04:25 PM #120
NEdude NEdude is offline
NEdude is on a distinguished road
Originally Posted by jbinmd View Post
Yep. 6 nuts, 2 spacers, instruction sheet, and a sticker.
Here's a shot of the spacer installed using the low profile nuts. Looks like any thicker and the nuts wouldn't fully thread onto the OEM studs.
Hello -
New to me 2018 SR5 Premium. At the risk of totally beating a dead horse I would like some thoughts/opinions.
My initial plan is to do suspension lift etc. etc. when my kid finishes school (fingers crossed). For now I want to lift/level front end and add 'better' A/T tires. I am thinking the 1" spacer for now but where I am struggling is that this truck seems to not have as much rake as I have seen on others. But I am assuming it is 100% stock.
Can someone comment on pic and confirm it indeed appears stock.
Thank you.
Cornfed 1" front spacer to level only...-resized_img_3380-jpg
NEdude is offline   Reply With QuoteReply With Quote
All I want to do is get the front level. What would be the best spacer to use? Jeff T 4th Gen T4Rs 49 08-30-2016 11:52 PM
4th gen Supreme suspension 2.5" leveling kit + Cornfed 1" rear spacer black_120 For Sale: Suspension/Wheels/Tires 12 02-09-2013 06:57 PM
FS: Cornfed 1" Front Leveling Spacer bigwebb83 Classifieds - buy & sell (no commercial ads please) 12 04-05-2011 08:42 AM
Cornfed 2" rear Spacer, Ready Lift 2.25" Front Spacer bt216 Classifieds - buy & sell (no commercial ads please) 18 08-08-2009 05:40 PM
Will a 3" cornfed lift level my 06 ? Kirby 4th Gen T4Rs 1 06-29-2006 12:28 PM
